Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Burble During Inverted Flight
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 04-19-2008, 10:07 PM
T-ster
Default Burble During Inverted Flight
I have a 3W100 on an AW Edge 33% and brought it out of retirement. Flies very well however I'm getting a burble when flying inverted. I have soldered a tube to the diaphragm opening and vented it into the airframe (which was done years ago but don't remember this being a problem) and have tried leaning the low end.
Any ideas?
Old 04-19-2008, 10:16 PM
Hammbone
My Feedback: (309)
Default RE: Burble During Inverted Flight
You could try leaning the high end to see if that will help. Also, 3W has a new reed block that is supposed to help with the problem, I'm not sure if they make one for the 100, but if they do, you might try that.
Jim
Old 04-19-2008, 10:29 PM
krayzc-RCU
My Feedback: (31)
how much did u lean the low end so far?
Old 04-19-2008, 11:28 PM
T-ster
I leaned the low end enough to stop the burble during upright flight.
