Where can I order the slimline F1 or Excel fueler?
My Feedback: (10)
GA
Ok guys,
Finally got Slimline's website to load, and I see the two probably aren't interchangeable.
Here is a question:
Which exact o rings do I need to have replaced with the new Viton rings?
Is it just the rings in the fuel dot/ plug that mounts to the plane, OR do I ALSO need to replace the o rings in my M1 fueling systems' probe?
Here is a question:
RE: Where can I order the slimline F1 or Excel fueler?
I have been using the fueller (methanol) for several years now on multiple planes, with no issues at all. You do have to mount it robustly on the plane so you can tighten/undo the cap without it moving, but other than that, it works for me.
jp
jp
