Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
TBM 50cc 30% Magic Hand Yak 54 Build Thread
Reply
Old 03-26-2009, 05:07 PM
  #51
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: TBM 50cc 30% Magic Hand Yak 54 Build Thread
That flex is just after i landed it was still "loaded" from the wieght of the plane. I glued around the landing gear really well, so far it has stayed together without any problems. I think you should be fine, but i dont know how your field looks. The flexing part of the landing gear is nice, it will keep you out of trouble on a hard landing, also it wont want to bounce on landing. Which is really nice since this plane doesnt need alot of airspeed to fly. I have flown it since then two more times, and i reccomend toaning the elevator down alot for the first flight, it is really sensitive!
cam17 is offline
Old 03-27-2009, 06:44 AM
  #52
Rush7
Rush7's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: cam17
very cool. keep us posted as you build. What are you going to do on the set up for everything else?
I will run the Torch 60 on a Vess 23A until broken in and then go to a 24x8 of some sort. I will use a JR 8611A on the rudder and I will be using the Power HD 9150Mg on all of the other surfaces. I have been wanting to try them out and see what they can do. I figured this would be just the plane to try them out on.
As soon as I get my Carden finished I will start building this one.
Rush7 is offline
Old 03-27-2009, 06:49 AM
  #53
Rush7
Rush7's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: cam17
Toning the elevator down???????? Man that makes for better waterfalls!
Rush7 is offline
Old 03-27-2009, 07:53 AM
  #54
dragnbye
dragnbye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cam you fly jr or futaba ??
dragnbye is offline
Old 03-27-2009, 09:21 AM
  #55
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I fly JR. I have had nothing but great servos from them. But I have never tried Futaba servos, other than on my first plane i had Futaba servos and radio, but they were 17 years old, still worked too.
Rush I would like to know how those Power HD servos work. I have not tried them yet.
Also I mainly suggested to tone down the elevator because come landing time it is really squirrly. Just something to be cautious for on the maiden, but nothing that cant be handled.
cam17 is offline
Old 03-27-2009, 12:19 PM
  #56
dragnbye
dragnbye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cam what is are you using for your expo's rates
dragnbye is offline
Old 03-27-2009, 12:36 PM
  #57
1994toy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have this same Yak and need to know were the manual says the cg sould be since I don't have manual.
1994toy is offline
Old 03-28-2009, 10:54 PM
  #58
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For expo I set every surface around 50% expo. And for deflection on rudder tone it down to about half its max throw. Elevator is about 13 degrees of deflection, its enough on the maiden for me. And aileron is about 15 degrees of deflection, but i have increased its throws so proboly more.
1994toy, according to the manual it is 185mm from the leading edge, it works for the maiden, but i would put it so it was nose heavy.
cam17 is offline
Old 03-28-2009, 10:58 PM
  #59
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got 13 more flights in today, spent about 10 hours at the field flying. I mainly practiced IMAC for my first competition next weekend. I feel the plane flys great it does nothing wierd, great power with a DA-50. Floats for landings, but slows down real quick once leveled. Still loving the plane.
cam17 is offline
Old 04-05-2009, 10:13 PM
  #60
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finished 1st place this weekend in basic at Salinas IMAC with the yak. I've only been practicing since last weekend i was happy with how i did, it was my first competition. Thank you Joe, Dennis, and everyony else who helped me this weekend could not have done it without you.
How is everyones build going? Any Maidens??
cam17 is offline
Old 04-06-2009, 11:04 AM
  #61
dryverman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still no flying at our field yet, access road is gated and locked. (Mud season
follows winter here) Couple of weeks yet....
Congratulations on the 1st place! That tells me you are already getting comfortable
with the yak...great news!
1994toy...you can download the "manual" from the Troybuilt website.
dryverman is offline
Old 04-06-2009, 04:51 PM
  #62
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sorry that you still got some time before you can fly that sucks.
I like the way the plane flys, with some work anyone can have this plane turned into a good IMAC plane. The next couple weeks im going to put it through some 3d. Ill let you know what i think, also the engine has about 3 gallons through it so it is done with break in. Im going to replace the 22x8 wood prop with a 23x8 Carbon Fiber prop soon. Ill keep everyone posted.
cam17 is offline
Old 04-14-2009, 01:20 PM
  #63
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well after many flights i do not like the tail wheel or main landing gear provided. The main landing gear does not spring back to the original position it started, it flexes and then does not return if it was a big flex or hard landing. The rudder tail wheel does good but it is also deforming some now. I am going to replace the stock tail wheel with a carbon fiber one from TBM. I am also going to replace the landing gear with either a carbon or thicker aluminum gear. Does anyone know of a company that makes a gear for this plane other than TNT landing gear? I think that is the last thing i will need to change other than that it has been great.
cam17 is offline
Old 04-15-2009, 05:30 PM
  #64
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finally got around to weighing the plane and lets just say i wasnt too thrilled. It came out at 20 lbs. I am very dissapointed, i really dont see what i coud do to lighten it other than 1 less battery, no servo tray. And even with that it still does not drop below the high 19 lb range. that is also with a carbon fiber wing tube. So 3d is pretty much out of the question. Also just to get the CG right took 12 oz. to the nose, everything is as far forward as can be and i have an aluminum spinner on. Does anyone else have any idea what the weight is on there plane, is this just me having a problem or is this common to every MH yak 54?
cam17 is offline
Old 04-16-2009, 01:24 PM
  #65
MarkF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mines electric but it weighs 19+ lbs and 3Ds just fine.
Mark
MarkF is offline
Old 04-16-2009, 02:30 PM
  #66
dryverman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I havn't weighed mine yet but I'll do it this week-end and let you know.
I was afraid that main gear wouldn't hold up over time, way too much
flex just sitting still...and the excessive weight sure doesn't help! The
plane still should 3D fine though.
You might try Graphtech, they make carbon fiber gear for several mfgrs,
maybe one of their sizes will fit.
www.graphtechrc.com
Old 04-16-2009, 03:09 PM
  #67
dragnbye
dragnbye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what size spinner are you useing ??
dragnbye is offline
Old 04-18-2009, 04:48 PM
  #68
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay i will try this next weekend, i checked graphtech and they didnt have one, i am having one custom made out of thicker aluminum, should fix the problem.
i am using a 3.5'' tru-turn spinner. And it 3d's decent just power is not great, not enough to really pull out if needed, but im trying a new prop and break-in is done so we will see.
cam17 is offline
Old 04-19-2009, 07:08 AM
  #69
dragnbye
dragnbye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: cam17
is this with the carbon prop or that 22x8 your using also it seems that people are haveing good luck with the vess 23 a
dragnbye is offline
Old 04-19-2009, 09:13 PM
  #70
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this is with the wood 22x8 the carbon 23x8 is on its way. I havent really tried the vess but i know a few people who have and they have no issues with the prop.
cam17 is offline
Old 04-20-2009, 04:50 PM
  #71
dryverman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got mine on the scale yesterday, 18lbs 5oz. This is basically the same set up
as you have, except mine has a pitts muffler (DA). I also have a cf wing tube,
everything else stock. The reciever and ig. batteries are mounted on the motor
box, cg is per instuctions with no extra nose weight added.
Still have not test flown yet, we have been working on getting our field in better
shape, looks like the middle of May....
Anyone else flown your Yak yet?? dragnbye??
Old 04-20-2009, 07:24 PM
  #72
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
okay well let me know when you get it in the air im excited to here what people think. good luck on the field.
cam17 is offline
Old 04-20-2009, 08:23 PM
  #73
dragnbye
dragnbye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
not yet i still nrrd to balance it my wifes engine blew in her car so all my free time is going to that right now but i am itching to get this thing up
dragnbye is offline
Old 04-21-2009, 09:20 AM
  #74
cam17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sorry to hear that, i hope yours will need less weight then mine in the end.
cam17 is offline
Old 04-24-2009, 05:33 AM
  #75
SENZA
SENZA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know of a way to shed 3.5 oz and more, get rid of the regulators and fromecos and ad one A123 2300 battery 6.6 v , takes minutes at the field to charge as well ! i have been flying mine for over a year now. fromecos regs/battery's for sale
SENZA is offline
Reply
Display Modes
