250° F - is that too hot?
#52
My Feedback: (61)
NJ
RE: 250° F - is that too hot?
ORIGINAL: bubbagates
Now that's a good lookin baffle setup right there
ORIGINAL: Tired Old Man
Yep, but with all that white I think he needs to sell some advertising space on the front of the baffle
#53
My Feedback: (41)
ORIGINAL: Josey Wales
Are you talking about the open tunnel holes in the tail in Joe's pic ?
ORIGINAL: RTK
Put a couple of good sized lips, louvers, etc., in front of those back cut outs and it should increase draw. More air flow is always better.
#54
My Feedback: (61)
NJ
ORIGINAL: JoeAirPort
I'm tempted to do what Joe did and also block my pipe tunnel but have no temp measurment tool to verify if this works.
If Im wrong about what he said Im sure he will check in
#56
My Feedback: (41)
I was doing a re-engine over the weekend on an Extra with a DLE-55. I used a piece of balsa angle stock and some balsa sheet to make a lip on the bottom opening of the cowling. I covered the lip with matching covering on the outside. I'll post pic's. I'm hoping this will help keep it cool. One thing though, the inlet area is too big IMO but I don't want to fugly it all up with blocks. Plus I need to see the needles from the front opening.
#58
My Feedback: (61)
NJ
Got a chance to fly my 110" EF Yak with the new baffle today. I noticed that the engine was running a lot richer so Im assuming the baffle was doing its job. I leaned it out about 1/8 turn and it cleared right out.
