Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Sbach 342 The wait is over!! FINALLY RC!
Reply
Old 08-10-2009, 07:20 AM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sbach 342 The wait is over!! FINALLY RC!
RC- Xtreme Machines are proud to present the first RC 30% Sbach 342 ARF.
RC-Xtreme Machines is based in Pakistan. We have been producing planes in the local market for over 16 years. We finally decided to expand and become a global manufacturer and what better plane to do it with other then the SBACH 342. Our hats off to the designer and flyer of the full scale SBACH 342 Mr. Phillip Steinbach. Not only is his plane one of the most beautiful performing pane, but his aerobatics routines on it are simply breath taking. The moment I first saw the plane I decided to build one. We quickly made the prototype and flew it in April this year and we knew then we had something special.
After successfully testing the prototype we started to develop our production models and finally after many sleepless nights and hot flying sessions it is ready.
The Specifications of 30% Sbach 342
Dimensions:
Wing Span: 89 inches
Wing Area: 1585 Sq inches
Fuselage Length (including spinner): 80 inches
Stab Span: 38 inches
Flying Weight: 16 – 16.5 lbs
Wing Loading: 23.27 oz/sq inch
Engine Recommendations: 50 cc – 60 cc Gasoline Engine.
Features:
The whole kit including the design of the aircraft has the single purpose to make the plane perform unlike any other aerobatic RC plane. It should not simply look like the Sbach 342 but also perform like it. The internal design concept, helps make the plane xtremely (couldn’t help myself!) light weight and rigid. The plane has all balsa sides, premium grade plywood parts, carbon fiber parts and Kevlar hinges.
Composite Parts:
1. Carbon Fiber Spinner
2. Fiber Glass Cowl with Carbon fiber reinforcements.
3. Carbon fiber/balsa firewall.
4. Carbon fiber firewall L-Bracket support.
5. Carbon fiber Fuselage wing rib – part of the new design concept.
6. Carbon fiber base plate/rudder servo plate- part of the new design concept.
7. Carbon fiber L supports at various places in the fuselage.
8. Carbon fiber Latch mechanism for hinged canopy!
9. Carbon fiber Wing tube.
10. Carbon fiber dowels.
11. Carbon fiber tail tube.
12. Carbon-Kevlar Main Landing Gear.
13. Carbon fiber reinforcement of landing gear plates.
14. Carbon fiber tail landing gear.
15. Fiber glass wheel pants.
16. Carbon fiber push rods.
17. Carbon fiber Servo control arms including a whopper 5 inch rudder servo arm.
18. All Carbon fiber Control horns.
19. Kevlar Hinges
Most of hardware is custom carbon composite as you can see from the list but other stuff that is included in the kit includes
1. Dubro Wheels (Mains and tail)
2. Dubro tygon extra large fuel tubing
3. Dubro Ball links on all our carbon push rods
4. Dubro Fuel tank converted for gasoline operations.
5. All nuts and bolts are included to complete the kit.
6. Also included will be a template to cut the covering in case you want to
epoxy your plug-in stabs in place. Which we recommend doing.
7. Detailed/entertaining instruction manual.
8. The plane is Pre-hinged (Glued).
9. Covered in Ora cover.
Additional Features.
The canopy is hinged. Makes it whole lot easier plus that’s the way it’s on the real thing
I hope you enjoyed the brief introduction to our plane.
As aero-modelers we have tried to incorporate what we have learn over the last 18 years or so into a plane that is a joy in the air as well as on the ground. We feel ‘the experience’ of an ARF start as soon as you open the box. We have put in a lot of thought process and hard work to make sure that every step from opening the packaging to the perfect soft landing exactly in the middle of the runway is a pleasure and a joy.
Each plane is assembled before putting it in the box. At this stage the wing and stab incidences are checked making sure they are correct, no plane can leave the factory if the final tests are not cleared. In fact at each stage of assembly the builder signs off on his work, so when a plane finally goes in the box we guarantee all parts will fit together as they should and the plane will be true and straight.
When designing the plane all the bolts and screws on this plane are placed at locations that are comfortable to work on. So no tighter cowl bolts that you have to reach way inside to tighten or wing bolts that should have been just a inch away from the former or the fuel tank.
These are just some examples of the attention to detail that have been put in this aircraft. With no compromise on quality and performance and using only the very best materials for the construction we promise you a model unlike any other in both build quality and flying performance.
THE KIT WILL BE AVAILABLE WITH THE DEALERS SOON.As we are in the process of finalising our distribution
Kindly refer to the attached PDF file for details on the construction, more pictures and contact info
ID:	1253638   Click image for larger version
ID:	1253639   Click image for larger version
ID:	1253640   Click image for larger version
ID:	1253641   Click image for larger version
rcxtreme is offline
Old 08-10-2009, 12:29 PM
coronabob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sbach 342 The wait is over!! FINALLY RC!
Congratulations! Beautiful aicraft and powerful design features. I am anxious to get more details.
coronabob is offline
Old 08-10-2009, 01:06 PM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
let me know your email address and i will send you the details
rcxtreme is offline
Old 08-10-2009, 02:06 PM
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW!! Congratulations! beautifull!! can you send me more info?? my mail is tuny90@hotmail.com
tuny is offline
Old 08-10-2009, 02:12 PM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tuny thanks for your comments, email has been send please check
Regards
Team Xtream
rcxtreme is offline
Old 08-10-2009, 03:28 PM
Rob Swire
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is a welcome change to the Yaks et al. Pls send info to robswire@verizon.net
-Rob
Rob Swire is offline
Old 08-10-2009, 04:37 PM
msayewich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can I get some further information. my email is matthew at sayewich dot ca
msayewich is offline
Old 08-10-2009, 10:41 PM
MetallicaJunkie
MetallicaJunkie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
whats the price shipped to USA
MetallicaJunkie is offline
Old 08-11-2009, 02:25 AM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: MetallicaJunkie
Retail price is 680US$, rite now we are in the final stages of setting up distribution channels with the dealers.Will be at your nearest dealer approx in 60 days.
rcxtreme is offline
Old 08-11-2009, 07:51 AM
victorzamora
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
$680 USD, shipped??? You might have me as a customer!! I've been looking for a cool 50cc plane to throw around. If it flies half as good as it looks, I'll never want to fly another plane again.
victor_a_zamora@hotmail.com
victorzamora is offline
Old 08-11-2009, 08:42 AM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
victorzamora
The price dosent includes shipping cost, we will post flying videos by tomorrow, its aewsome in flying
rcxtreme is offline
Old 08-11-2009, 09:05 AM
maineflyer
maineflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
$680 is the street price? Who are the US distributers? It is gonna be hard to find buyers at that price for an unproven airframe. Are there going to be any introductory price reductions?
Jeff
maineflyer is offline
Old 08-11-2009, 09:08 AM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We are at the final stages of setting up distribution channels with the dealers.Will be at your nearest dealer approx in 60 days.
rcxtreme is offline
Old 08-11-2009, 10:11 PM
TailTouch
TailTouch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Darn.
I knew a guy who was in Lahore a month ago
Could have asked him to pick it up for me.
TailTouch is offline
Old 08-11-2009, 10:23 PM
msayewich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know I want one. Already got my eyes out for an engine. Thinking 3W.....
Old 08-15-2009, 02:52 PM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3W 55 will be awesome for this model
rcxtreme is offline
Old 08-15-2009, 03:49 PM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cheack out the video at the following thread
http://www.flyinggiants.com/forums/f...ally-rc-8.html
rcxtreme is offline
Old 08-17-2009, 11:57 AM
maineflyer
maineflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This plane is going ot be great... Can't wait for the production model.
Jeff
Old 08-17-2009, 06:29 PM
SunShyne
Moderator
SunShyne's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
congrats my friend, any other offerings coming soon?
SunShyne is offline
Old 08-18-2009, 12:15 PM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BTW guys ... we are working full swing to get our 100 cc plane flying. it looks just the same lets hope it flies well too. may be we can tweek it out enough to make it available by this christmas near you.
The 150 cc should follow in another month after the release of the 100cc . as both planes are being developed with a months gap.
i will try to get some build shots of the two planes soon.
rcxtreme is offline
Old 08-18-2009, 12:16 PM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
opps forget to write down the specs of 100 cc sbach 342
fuse 99 inches
wings 109 inches
14 inches wide nose at first former.
stab width 46.5 inches
wing area 2401 sq/inches
but dont tell anyone i told you this.
rcxtreme is offline
Old 08-18-2009, 05:05 PM
Shahid
Shahid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RCXtreme...sent you an email.
Shahid is offline
Old 08-19-2009, 02:16 AM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Email replied
Quote:
ORIGINAL: Shahid
rcxtreme is offline
Old 08-19-2009, 12:29 PM
rcxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here are some pictures of today flying session
ID:	1259196   Click image for larger version
ID:	1259197   Click image for larger version
ID:	1259198   Click image for larger version
ID:	1259199   Click image for larger version
ID:	1259201   Click image for larger version
ID:	1259202   Click image for larger version
ID:	1259203   Click image for larger version
ID:	1259204   Click image for larger version
rcxtreme is offline
Old 08-19-2009, 01:13 PM
SunShyne
Moderator
SunShyne's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that thing has beautiful lines, gorgeous! well done
what do I need to do to talk you guys into making a 50cc CAP 232 now?
SunShyne is offline
Reply
Display Modes
