Suggestions for component setup
FL
Im building up for a gas engine 120 scale type aircraft (Aeroworks 90-120 Yak)and wanted to know what type setup should I use. Running DLE 30 with 4 Hitec 5645 and rudder 5985. I purchased a MPI adjustable regulator because I want to run lipoly batteries. I dont know what size batteries or if lipoly is the right choice. I wanted to go that route because Im already setup with charger and battery stuff from other planes.Im using a spectrum radio and ar7000 receiver. I also purchased a remote ignition shut off which will utilize an aux channel on receiver. Any suggestions on battery and/or more stuff to add.. Thanks for your time New to Gas Paul
