Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Great Planes 25% Pitts M-12s 3D
Reply
Old 03-01-2012, 11:56 AM
  #251
DOC
My Feedback: (57)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Great Planes 25% Pitts M-12s 3D
I love the way this bipe performs!
the LG issues were solved by installing 2 good 1/4" aircraft (5 ply) Lg mounting plates braced by (2) 7.375 x .080"Alum. L bracket ( 1.25 x 1.25 ) secured to the LG plate by the stock screws and then to the fuselage box frame by 3, 6-32 screws on each side.
We're @ 5000' and it seems to sink quite fast, so I keep the landings a little fast. 17 lbs with a DLE 55. It will do 6 vertical slow rolls until I have to level off. The stock LG seems to work fine !
DOC is offline
Old 12-11-2012, 05:45 AM
  #252
djmoose
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The links to the pdf manuals are not working. Does anyone have a copy they can post here? (or email me?)
thanks in advance!
djmoose is offline
Old 12-11-2012, 09:34 AM
  #253
357magnum
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out Tower Hobbies web site the two manuals work for me today.
http://www3.towerhobbies.com/cgi-bin...?&I=LXYBX2&P=0
http://manuals.hobbico.com/gpm/gpma1421-manual.pdf
http://manuals.hobbico.com/gpm/gpma1421-tech.pdf
357magnum is offline
Old 03-12-2013, 06:19 PM
  #254
grumman-cats
grumman-cats's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
finally started working on mine. I decided to build a tunnel between the landing gear for cooling purposes. trying to avoid cutting that beautiful cowl up. I also added some hardwood beams to the landing gear block hoping to strengthen and kind of tie things together a little better.
ID:	1861389   Click image for larger version
ID:	1861390   Click image for larger version
ID:	1861391   Click image for larger version
grumman-cats is offline
Old 03-31-2013, 05:53 PM
  #255
grumman-cats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
installed the landing gear today and found the Left main gear has a severe tow-in issue. either the gear is warped or when it was shaped and drilled for the axle it wasn't straight. Has anyone else had this issue? should I contact tower and get a replacement?
Old 06-14-2015, 01:03 PM
  #256
grumman-cats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
realized I never posted a pic of the finished aircraft.
