Mike Hurley Extra 300LX Build
I'm excited to say I am finally picking up on a project I've had in limbo for many years, the AMA Project Extra from January 2003.
I wanted to solicit input from anyone who's built this awesome plane asking whether to go with the vacuum bagging method of wing fabrication vs. a traditional layup of balsa sheeting over the foam cores? Can I obtain the same results without vacuum bagging? |
2 Attachment(s)
I have never used vacuum bagging. Good old gravity has served me well for dozens of plane. Dan
Excellent thanks for your feedback Dan! Picture is great. ~ Joe
Rudder Horn Placement
I’m wanting to know from anyone who’s built the Hurley Project Extra (AMA Jan-2003) as whether the plan is correct with regards to the servo horn placement on the rudder as referenced on the blue print. I set it to spec but it appears it could interfere with elevator when it put in down position. I would appreciate any information that clarifies this. I haven’t installed radio yet which could lead to the answer but I’m sure someone has encountered this to confirm. |
Fly
Are you finish and fly it?
have you any picture from finished this plane? |
