Scale Percentage
Scale Percentage
If I have 1/3 scale plan, and want to have FedEx/Kinko's reduce it to 1/5 scale, at what percentage should they set the copier? I'm not sure of the figure I come up with and want to get it right the first time.
Russ
Russ
FL
RE: Scale Percentage
Multiply the width (length) of the wing x (times) 3.
Divide that number by 5.
Example:
wing width (Length) is 100 inches times 3 = 300.
300 divided by 5 = 60. That is the percentage of wht you need to shrink it.
The new drawing needs to be 60% of the 1/3rd drawing.
Example:
ORIGINAL: ulpilotrmh
Russ
Russ
1/3 X 3 = 1 (100 %). 1/5 X 3 = 3/5 = 6/10 = 60/100 = 60%.
So, 60% of your 1/3 scale plans will give you 1/5 scale plans.
Regards, Richard
Thanks Spaceworm,
That's the type of reply I was hoping for. I came up with 60%, but by a different method. It's good to be sure.
Russ
[quote]ORIGINAL: ulpilotrmh
Russ
Regards, Richard.
Russ
Russ
Regards, Richard.
I would probably determine the size of the model first based on what engine you expect to use.
Then reduce accordingly to the wing span or how the engine fits.
What's the project?
What's the project?
