Balsa vs Fiberglass kits.
NY
To be honest I did not do a full search so I hope this isn't a rehashed subject.
I have begun my research to build a giant scale P-47 with a Tuskeegee Airmen's theme. I am looking for a relatively straight forward kit. So far I am considering a Top Flite kit as this will be my first GS build. As part of my research I have been reading some threads involving fiberglass kits and I am curious to get feedback on the difference in building a Balsa vs Fiberglass kit. Would a fg kit be an "easier" build?? Are there any advantages in terms of flyability. maintainence etc????
RE: Balsa vs Fiberglass kits.
I built a Byron Corsair and feel I could have built a balsa version lighter weight. Can't beat the toughness of a FG fuse though, plus the panel lines etc are molded in. The FG version is probably a quicker build. Methods are very different in that i used hot melt glue to position the formers and then fiberglassed them in. I thought the landing gear mounting method was actually quite good on the Byron and not hard to repair.
My Feedback: (158)
A balsa kit will be more work just for the fact you'll have to build 100% of it. With a "fiberglass kit", you'll only have to build the wing/tail feathers.
Typically a fiberglass fuse will be lighter over all compared to a built up, but not much depending on weather you glass/paint or use iron on covering.
Yellow has a p-47 that is mostly prefabricated and very pricey
Zirroli offers two plan set sizes, the larger having a Fiberglass fuse option, Kit cutters offer both, Ziroli offers the misc fiberglass parts/canopies etc.
The Top Flite kit is the least expensive option by far for a complete kit, even after adding the aftermarket fiberglass parts
Good luck
Good luck
