Dynatron starter battery pack?
I have a Sullivan Dynatron with a miller gear reduction unit. I want to make a little more portable with an attached battery pack. Anyone out there done it and what are you using? I was thinking of Lipos or A123's.
My Feedback: (15)
RE: Dynatron starter battery pack?
I have a dynatron on two 3c 2200 lipos. It works great. It will start all my 30cc engines with no prob. My 50cc need a little help, just hit the prop when it stops and it will turn it over. But on the 30's it turns it ovet so fast that when it pops and you take off the starter you still have time to turn off the choke and the engine stays running. hope this helps.
CA
I am using my 6S 5000 mah packs and it starts my DA-50 easily. I have the Miller belt reduction setup on mine too and it really works great.
Jeff
Jeff
