4 bladed prop
RE: 4 bladed prop
Check out Biela Props, they make 4 blade carbon fibre. Also Zinger will make 4 blade to your specs from wood. Not sure is Vario-prop can handle the power of gas or nitro, but they also have a new line of larger props, 3/4/5 blade. flytreetimes
RE: 4 bladed prop
Menz also makes 4-blade props in many sizes. If you can´t stand the pointy tips on a scale model you could easily sand the tips to any desired shape. Selection here, but I guess your local dealer should be able to order them also.
http://www.gromotec.de/Luftschrauben.html
