If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    Join Date
    Nov 2006
    Auckland, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dave platts 65" wing span spitfire kit
    Hi All
    Just a question
    Dave platts 65" wing span spitfire kit is it a 1/7 scale or 1/6 scale . Iv been told its a clipped wing version. Making it a 1/6 scale
    Your help and thoughts please
  2. #2
    scale only 4 me's Avatar
    Join Date
    Jan 2002
    Avon Lake, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Dave platts 65
    The Dave Platt / Pica 65" span kit is not the clipped wing Version,
    At 65" it actually 1-6.8 scale, so about 1/7th
    Dave designed and sells a 1/5th version with a clipped wing look here
    http://www.daveplattmodels.com/Short%20Kits/index.htm
    Pica also kitted a 1/5 kit full wing tip version, but they are long OOB
    good luck
    You're so smart,, you figured out how to read this!! Or maybe ya just got lucky??
  3. #3
    Join Date
    May 2008
    Kingston, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Dave platts 65
    Be also aware that the wing on this model has been shifted aft from its scale location. It is supposedly a Mk 9 but a friend found that if he added several inches to the rear fuselage, the proportions are pretty much on for a Mk 14.
    Martin
  4. #4
    Join Date
    Dec 2001
    Litchfield Park, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Dave platts 65
    ORIGINAL: Nieuport nut
    Martin
    This would be the case for the Mk 9 as well since, from the firewall aft, the fuselage of the 9 and 14 are the same length. In fact I believe that is pretty much true for all Marks of the Spit. The length of the nose varies as well as the size and shape of the vertical fin but I'm relatively certain that the fuselage length from the firewall to the leading edge of the stab is the same on all Spitfires.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
