OOOOOHHHHHH Very large Wilga, advice.
Hi
In a very week moment, i bought a very big Wilga, its build with ply ribs anf formers and covered with thin mahogny, the only thing left too build from wood is ailerons, flaps and wingtips, this build started in Denmark many years ago, and have 2-3 owners before me in Norway, i am going too make it flyable, but i have too go the budget way ( no Moki ) i doo need some advice:
This is build from downsized original fullsize plans, there is no hardpoints under the wing skinfor the hinges for ailerons and flaps, can i cut slots and fasten them in the wingribs?
Do someone know how the ailerons and flaps should look like, and how they are hinged on the fullsize?
What engine too choose?
The wings has hardwood main spar that continues into the top cabin, but how should i lock them in place? (too thight fit for the moment)
Covering, fiberglass and resin?
The model is 10 kg and has a 5 meter wingspan, final weight mayby as low as 25kg.
All comments are welcome...........
Viggo
Viggo
IA
RE: OOOOOHHHHHH Very large Wilga, advice.
There are links to a couple of three views that show the size of the ailerons and flaps at [link=http://www.rcuniverse.com/forum/m_10022910/anchors_10022910/mpage_1/key_/anchor/tm.htm#10022910]here.[/link]
You might try contacting PZL in Poland. They are the makers of the plane. They are located at the Warsaw, Poland airport. Their address is:
EADS/PZL
Aleja Krakowska 110/114
Warsaw, Poland
If you wish to all them, their phone number (from the US) is:
011 48 22 577 22 02
011 for an international call
48 for the country - Poland
22 for the city - Warsaw
the rest is the phone number
EADS/PZL
Warsaw, Poland
011 48 22 577 22 02
