Zimpro Laser 200
My Feedback: (90)
Zimpro Laser 200
Hello,
Was wondering if anyone had flown one of these airplanes a Zimpro Laser 200-QS http://home.comcast.net/~zimpro/laser.htm
It has a removable wing that uses a square main spar that is laminated plywood and foam.
The plane that I am looking at weight 16lbs for a 80 890 sq in wing area. To me that is too heavy. The guy that has it pull on one of the elevators and the hinges pulled out. Kind of scary, so it will have to be completely re hinged. The engine is a Webra Bully which should pull it pretty easy.
