Scale Propeller Size For 1/5 J-3 Cub?
I'm powering an 8# 1/5 scale J-3 W/an electronic ignition Saito FA91 & want to swing a 16-4 propeller for maximum thrust @ WOT & scale speed @ part throttle.
That 16" scales out to an 6'8" prop. What is the full sized propeller diameter for a J-3? Would a 16" prop look appropriate on a 1/5 scale Cub?
My Feedback: (19)
RE: Scale Propeller Size For 1/5 J-3 Cub?
ORIGINAL: SrTelemaster150
That 16'' scales out to an 6'8'' prop. What is the full sized propeller diameter for a J-3? Would a 16'' prop look appropriate on a 1/5 scale Cub?
If I go 14 X 4 I will likely overspeed the engine if I go full power. Going 14 x 6 will make it hard to throttle back for enough for scale flight speed. I want the thrust for vertical performance when I want to play aerobat but still be able to float around like a full sized Cub @ part throttle.
A 15 X 4 prop should not look too far off. That would be 75" scaled up.
