OS 160 Twin
OS 160 Twin
Well I have Done it now..The dog will be warm tonight . I have ordered the motor for my BUSA 1/4 Cub.. I followed the advice of a few of my fellow builders and decided to go for the OS FT-160 Twin 4-C It is expensive but after all this is my Cub that it is going on and it will sound so nice purring along making slow passes...I would like to hear from anyone with experience with this engine , as to weather it needs an on board glow for the idol ect . ect .The best way to set it up , mount it , fuel tank set upand location to the needle , All that kind of advice and tips would be very welcome as for me this is a big investment andI do not want to screw itup...Also designs for large dog houses would be welcome..Just kidding..My wife is great..She supports me 100%... Thanks
RE: OS 160 Twin
I have done it both ways on a 120, not really necessary but it ensures good idle and no flame outs. Used 5Ah battery switched by micro switch at the low end of the throttle servo travel. Very useful for starting.
AUS11594
AUS11594
RE: OS 160 Twin
Have you thought about going to ignition? I had a FT300 for a short time, got it from one of our club members. He had put a manual advance ignition on it and when he got things right with the advance linkage, that engine would pop tick over at an astounding slow speed. This was using glow fuel. Steady as a rock also. The weight gain would be just a few grams more than an on board glow system.
Don
Don
RE: OS 160 Twin
I had a OS FT-120 (30 yrs old although was never run till recently) on my 1/4 Cub which weighed 16lbs.It was underpowered, the 160 would be ideal although I dont think it would work if u go over 20lbs.
The sound of the FT is REALISTIC and worth every penny. Make sure u adjust the valve gaps after u run it in.
It will flame out or one cylinder will stop firing if it is running rich otherwise no nead for a glow driver. The seceret is in fine tuning it, didnt take much.
Good luck
Rafeek
Good luck
Rafeek
My Feedback: (14)
TX
RE: OS 160 Twin
I ran both the 120 and 160 twins from 1990 to 2003 with great success. The 160s are much better performers than the 120 Gemini IIs were. The bulk of my flying was in a Great Planes SuperSportster built in 1990 and then the Hanger 9 and Sig CAPs.
In all cases the planes weighed from 11 to 13 lbs and were good aerobatic planes but not 3-D capable.
As for the engines they were dead reliable running on Morgan pink 10% in the summer and 15% in the winter such as it is here in the Dallas Ft Worth area. Never had a problem dropping a cylinder in flight or coming up from idle. Since my engines were cowled, I used two dubro remote glow extensions and plugged in a glow igniter for each cylinder. I removed the choke setup as all of the engines would fire up from idle in 5 to 10 seconds using a Sullivan starter. Allow it to idle for 30 seconds or so before removing the igniters and things are good to go. The needle valve and idle seldom require any adjustment day to day unless there is a 30 to 40 degree temp. change.
The valves need to be checked and lubricated maybe once every 100 flights or so. I found the a light grease seemed to do a better job than just the blow by oil but I never saw any evidence of under lubrication of the valve train.
The OS-F glowplugs will go through as much as 20 gallons of fuel or more with no problems so they seldom require attention.
Overall they are fun and reliable powerplants, money aside. I still have two of the here with no idea as to what to do with them at this point in time.
Enjoy lots of good flying from your 160 twin.
RE: OS 160 Twin
Gremlin Castle can you tell me if you need a motor mount or do you just use the motors own boltholes? I see they sell a motor mount for the motor...Do you want to sell the two motors that you have ? Are they both 160 , s , and are they high time motors... I looked in your gallery, There is some nice stuff in there...I love the little Piper Skycycle and the Aeromobile....Did you build them??
RE: OS 160 Twin
Yes, would be switched on automatically at (say) 1/4 throttle. I can't quite remember now but I assume I also had a master switch on it so it could be permanently off otherwise you run the risk of leaving the glow driver on when you don't want it on and flattening the glow driver battery.
My Feedback: (14)
TX
RE: OS 160 Twin
I used the mount that is supplied with the engine and built a box from the firewall forward to space the motor correctly with the cowling.
Yes I built the two planes that you mentioned primarily for the SMALL event held ion LittleRock every year.
Send me a pm abouit the two 160s
RE: OS 160 Twin
Sorry to be late getting in on this. I have been running a FT 160 for several years on a 1/4 scale Spacewalker II. I ran it with onboard glow for most of the time until I had a minor accident (ie, flew into a tree). One of the glow plugs broke off in the onboard glow cap and I haven't figured out a way to extract it. I took the system off and went without onboard glow. I cannot see any difference in the performance. It's a beautiful sounding engine and idles great without the onboard glow system. Good luck!!
RE: OS 160 Twin
ORIGINAL: welchcb
RE: OS 160 Twin
I appreciate your reply. The tip of the glow plug broke off in the wire cap that comes from the remote glow plug unit. It did not break off in the engine.
Thanks for your efforts though.
RE: OS 160 Twin
I dont know if yours is like mine but if it is you should be able to put your fingers on the cap while pulling back on the wire. this should relese the grip the cap has on the glow plug and it should pull out of there fairly eaisly...Its just a little clip on deal with a spring...You will feel it when you pull on the wire...Good luck...
RE: OS 160 Twin
I remember your post earlier when you were deciding what engine to use in your Cub, glad to see you went with a 4 stroke twin rather than a rattly big 2 stroke, you'll forget about the price in no time & every time you start it up you'll smile & know you made the right choice!
Good to see you spent the extra on the OS over the ASP, same deal, you'll look back in years to come & the extra dough you spent will mean nothing.
Made your will out yet? Treated properly these engines last practically forever so you may be passing it on! - John.
RE: OS 160 Twin
The ASP 160 is the same engine just sold under a different name.
Found suppliers here:
http://www.nitroplanes.com/72p-ft160ar.html
http://www.hobbyking.com/hobbyking/s...w_Engine_.html
Mine was a bit fiddly to get going reliably but seems ok now. Only time will tell how long it lasts. - John.
OR
RE: OS 160 Twin
just currious i have a sullivan remote glow starter and i want it to come on when throtleing down from 1/4 to all the way off this is because i mounted a 120 ax upside down and i was told by OS it might be A GOOD IDEAL TO USE THE GLOW STARTER I HAVE SET IT UP BUT IT SEEMS TO ONLY WANT TO WORK WHEN THROTLING UP NOT ON THE WAY DOWN LIKE I WANT CALLED SULLIVAN BUT NO RESPONCE YET I WAS MESSING AROUND WITH IT AND HAD IT WORKING COMMING DOWN BUT NOT IN THE RIGHTSPOT AND NOW CANT FIGURE OUT HOW I GOT IT TO WORK THIS WAY AND THERE ARE NO INSTRUCTIONS ON HOW TO SET IT UP LIKE THIS ON THE STATER PACKAGE
RE: OS 160 Twin
here are the instructions for setting up the Sullivan OnBoard glow driver.
For automatic operation, set your throttle stick to the position that you want the plug to come on. Push the white button under the SET hole, and the LED will begin flashing about twice a second for several seconds. Increase throttle on the transmitter while the LED is flashing.
This orients the unit for high vs low throttle direction. When the flashing stops, the setpoint and direction is stored in memory. You can redo this as often as desired. Check the setpoint by moving the throttle up and down through
the setpoint. The LED will indicate that the plug is on or off.
