Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
plumbing question 101
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 08-20-2012, 07:55 PM
orthobird
Default plumbing question 101
will this set up work. need to use 2 tanks for smoke oil, due to space constraints on plane.
Old 08-21-2012, 02:27 AM
Tony Hallo
Default RE: plumbing question 101
The fill linewill need to be air tight after filling, typical hopper tank setup, go for it.
Old 08-21-2012, 02:48 AM
orthobird
great, thank you.  i will notify you of how it works!!
Old 08-21-2012, 02:04 PM
orthobird
it worked great!! the smoke pump worked like a champ.
there are two tanks.  on tank has a fill line and a line to the pump.  the vent line is connected to tank #2 pickup line.  the 2nd tank has a vent, that is it.  when i fill tank #1, once it fills all the way with fuel, the fuel then overflows into its "vent line" which then fills tank number 2 thru the clunk pickup line.  i had a great smoke trail.  i also decreased the pumps speed to about 1/3 speed, even then, there was still some oil on the wings, i may have to further decrease the rate.
