If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 12 of 12
  1. #1
    Join Date
    Nov 2002
    Hartland, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    U.S. Male Biplane
    I bought an estate, and part of it was a biplane that was passed over by several guys before me, so I got it as part of the "package".
    I have determined from the plans that I found in another box that this plane was scratched, and is called "U.S. Male".
    Flat bottom wings,biplane, N struts, weighs about 12 pounds without gear, has an ASP 108 in it, 81" span.
    Without a doubt, it is the most hideous looking model I have ever seen, and I've seen a lot of bad stuff.
    Orange paint over some sort of fabric, obviously painted on with a brush because of the blotchy appearance. Probably dope.
    My intent was to salvage the engine and have a nice centerpiece for the next bonfire, but there is not any real structural problems except for a bent trailing edge on one wing. I bet it would fly if I put gear in it, if only because the grass would try to push it away.
    So, if I kept it, I'd want to strip it and recover, some major surgery in the cabanes, etc ... but is it worth it? I have fun flying anything - last weekend was a 42 cc gas engine 3DCAP232, and today was training a guy on a Senior Telemaster. Love both kinds of flying.
    Anyone ever fly one of these things? Or even hear of it?
    I'll post some better pics tomorrow.
    ... I DO read the instructions ...
  2. #2
    Join Date
    Nov 2002
    Hartland, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: U.S. Male Biplane
    Poor pic.
    Barbie was going to be the guy's pilot I guess ... she needs covering too.
    Oh, and the metal on the front? That is the section of dryer vent tubing called for in the plans. Innovative ...
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1806247   Click image for larger version.
ID:	1806248   Click image for larger version.
ID:	1806249   Click image for larger version.
  3. #3
    Join Date
    Oct 2007
    Leominster, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This plane looks surprising close to a Phaeton biplane. I have the 40 size and it flys very nice if it is the redone kit. If it is the older kit, circa 1980's it will be too short in the fuse which makes it very reactive and hard to fly unless you have LOTS of experience. I kept my original plane for over 28 years. It really is a fun plane to fly.
    From your pictures, it appears that someone cobbled the nose. You can definitely do something with the nose around the engine compartment to improve the aesthetics... If it were mine I would put the time in!!!
  4. #4
    Join Date
    Nov 2002
    Hartland, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks. More photos to come.
    So I pulled the cloth covering off the left side of the bottom wing on the bottom.
    Came off effortlessly, and boy did I get a surprise. I was amazed at how light it is and now I understand why.
    I think I have the first giant scale foamie on record.
    The ribs are all some sort of creme colored foam board, with lightening holes all through them. Substantial spruce spars and stringers.
    Pretty solid structure actually.
    So the orange paint bled onto the structure and would need to come off to cover it without showing through. Sanding with a big block shows that the paint comes off, and it looks like the foam board has been "capped" with Titebond. I'd have to be careful if I used Monokote or Ora.
    Hmmmm .....
  5. #5
    soarrich's Avatar
    Join Date
    Feb 2002
    Middletown, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Lightning Fan
    The ribs are all some sort of creme colored foam board, with lightening holes al through them.*
    http://www.aircraftspruce.com/catalo.../lastafoam.php
    Rich Border AMA 77727
    Sig Kadet Brotherhood #2
  6. #6
    Join Date
    Nov 2002
    Hartland, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    More photos.
    Maybe if it weren't orange.
    The nose is per plan, believe it or not.
ID:	1806487   Click image for larger version.
ID:	1806488   Click image for larger version.
ID:	1806489   Click image for larger version.
ID:	1806490   Click image for larger version.
  7. #7
    Join Date
    Nov 2002
    Hartland, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That tail. The vertical stab sort of looks like a Fleet. But it makes no sense with the horizontal, which actually looks OK. It looks like a slab that got stuck on by accident.
    Surgery.
  8. #8
    Join Date
    May 2008
    Kingston, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It's a plan published in Model Aviation in the late 70's IIRC. I may even have the original article still.
    A guy in our club had one, powered by an HB61,(again IIRC). It was a fly-around plane to shoot touch and goes on calm days. Kind of like a kite actually. The wing loading was very low. It may have even been 3-channel.
    The foamboard ribs work fine. Foamboard is a good cheap alternative for large low-load parts like ribs. White glues work quite well, and if you are sheeting or cap-stripping them covering is no problem. I have a friend who used it for fuselage formers in a 30% Goon racer.
    Martin
  9. #9
    soarrich's Avatar
    Join Date
    Feb 2002
    Middletown, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It almost looks like fanfold foam, but I've only seen it in blue. Yea, for ribs and fuse bulkheads it will work well.
  10. #10
    Join Date
    Nov 2002
    Hartland, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, Nieuport Nut helped me strike paydirt. Here's the MA article:
    https://library.modelaviation.com/ma/1982/12/us-male
    The article says to use dress liner as the fabric, doped on. It was also set up to be three channel with a lot more diheral than is in mine, which has ailerons. Looks like I have a one of a kind here.
  11. #11
    Join Date
    Nov 2002
    Hartland, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And here is something interesting.
    These links show this thing could be made to resemble a Douglas M2 Mailplane ...
    http://www.abpic.co.uk/photo/1075451/
    http://jn.passieux.free.fr/images/Mailplane_3.jpg
    Nice color scheme ... Aluminum and maroon ...
  12. #12
    Join Date
    Jan 2003
    Winamac, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lightning Fan,
    I had one of these back in the ninties with a K&B .65 Sportster for power. It was a real floater a previously stated. One word of caution, it did NOT like wind. Anything over about 10MPH and it got a little hairy.
    Good Luck and keep us posted.
    Jim Widner
    Falcon Models
    Custom Building Service and Model Supply
    Team Hitec, Team SebArt RC
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
