Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Would you install your elevator servos in balsa?
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 12-24-2012, 07:42 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Default Would you install your elevator servos in balsa?
I'm a bit perplexed right now. [&:]
I am assembling a VQ giant scale Fly Baby. After cutting out the covering for the horizontal stab, I was able to see inside the fuselage. There are areas cut out of the wood for mounting the elevator servos. Only thing is, it looks like just plain ol' balsa wood to me. [X(]
Personally, I would not install servos in balsa sheet on even a park flyer. But maybe my thinking is flawed......
What's you guys opinions?
Old 12-24-2012, 08:49 PM
foodstick
foodstick's Avatar
Default RE: Would you install your elevator servos in balsa?
Servo screws into ply of some type is my rule... Can you cut some small rectangles of ply and glue to the balsa area? Sometimes it needs to go behind the existing mounting surface so the servo will sit down inside flush..
Old 12-24-2012, 09:11 PM
Kmot
My Feedback: (24)
Kmot's Avatar
I agree with you foodstick. Needs ply at a minimum. I will be able to do something, not sure what yet. I can reach inside with a tool to place pieces of plywood. Just seems so strange to me. I am wondering if it is not balsa, but some sort of Viet Nam jungle wood that has the look of balsa. Tomorrow when it's light outside I am going to poke it from the inside with an Xacto. I suppose I should have done that already. It just really threw me for a curve.
Old 12-24-2012, 10:09 PM
rafeeki
rafeeki's Avatar
If u cannot get another layer of thin plywood under it u could pour some thin CA on the balsa wood surface, this will harden it thereby make it stronger.
Rafeek
Old 12-24-2012, 10:58 PM
Giant_Scale_Gasser
My Feedback: (84)
Screw them into ply or else you'll regret it, guaranteed.
Old 12-24-2012, 11:28 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Yeah, I hear ya!
Old 12-25-2012, 06:42 AM
s3nfo
My Feedback: (14)
Into ply or it don't fly........
Old 12-25-2012, 08:18 AM
mikmerl
You should be able to glue plywood reinforcements internally on the balsa through the hole intended for the servo.
If it is impossible to access the servo mount from behind for reinforcement and if the balsa is thick enough. What I have done with good result in the past is to enlarge the holes in the balsa to about 6mm (1/4 inch).
Then I have cut lengths of hardwood dowels and glued then in the enlarged holes, flush with the outside surface. New holes were drilled in the dowels for the servo screws, add a few drops of thin CA in the hole and all this becomes like concrete.
mike
Old 12-25-2012, 08:40 AM
Kmot
My Feedback: (24)
Kmot's Avatar
Thanks guys.
And Mike, that's a great tip!
Old 12-25-2012, 09:36 AM
foodstick
foodstick's Avatar
you need some forceps with a angled head, tape the ply piece to the forcep, apply glue to the upper face ..slide it in ,position it and gently clamp it with the forcep.. Also a small clamp will work in many cases as well.
Old 12-25-2012, 10:53 AM
Kmot
My Feedback: (24)
Kmot's Avatar
Now that it is daylight again and I had all my worklights on I took another look inside, and poked it with my Xacto knife. It's definitely balsa wood that I am looking at.
However, epoxyearl (from another thread) was spot on about it possibly being "balsa plywood" because in a cutout below I can see the thin ply sandwiched between two thin sheets of balsa wood.
I will reinforce it though to be safe.
Thanks guys!
Old 12-25-2012, 03:43 PM
straitnickel
straitnickel's Avatar
It's good you saw that before you put the stab on, now it will be easy to reinforce the servo area with plywood or base wood. Better safe than sorry
Old 12-25-2012, 04:15 PM
Airplanes400
My Feedback: (349)
Airplanes400's Avatar
ORIGINAL: Kmot
And that's only one structural flaw that you can see. Check the rest of the plane for other questionable design flaws like this.
Old 12-25-2012, 08:37 PM
vertical grimmace
vertical grimmace's Avatar
Imagine how many issues like this go by the wayside by the inexperienced ARF assembler? Kinda scary really.
Old 12-25-2012, 11:00 PM
nitro wing
all good advice above
Old 12-26-2012, 09:54 AM
Kmot
My Feedback: (24)
Kmot's Avatar
Thanks everyone!
