A-1H Skiraider 2 26cc.
Last summer decided to make the plane under motor 26сс and chose A-1H Skyraider scope of 2.2 meters.
In the Internet founded drawings finalized them for the model.
Began to build a model, first fuselage.
RE: A-1H Skiraider 2 26cc.
This stabilizer
The stabilizer is removed and disassembled into two parts, the standard Sanwa servos are all located in the fuselage.
The appearance of the fuselage with the stabilizer.
And looks like the back of the fuselage with the removed cell stabilizer and a servo.
Mechanization on the plane the whole, like the original, flaps, landing gear, flight fires, dropped bombs on three suspensions, brake pads.
My Feedback: (32)
Hello Maverick,
You have a nice project there and it looks like it will be pretty light, but are you sure a 26cc motor will be enough for 2.2 meter warbird? I would think a 40-50 cc would be better. You have done a lot of cutting!
Your middle photo of the camoflaged A-1H is of 6T 609 named "Bad News" when it was based at Pleiku, Vietnam. It was later landed gear up at a dirt strip in Laos due to battle damage while based at NKP, Thailand with the markings TS 609. It was repaired and flying about 3 weeks later. It would make a great subject. You can find it's story on the internet. Look for "Bad News on the PDJ"
Looking forward to watching you build this plane,
Brad
Brad
Thanks for the interesting historical information, 26ss engine is enough to open a small Secret aircraft already flying and a little later and I'll post the video too. I apologize for my English I use Google translator, and thus you do not always understand it, but thanks for the ATTENTION to my project. Updates will spread further.
And this is a central part of the wing, it will be non-removable, removable console .
And already covered with the back of the fuselage with the stabilizer. Decided to strap a plane foil metallic.
If Quick here are pictures of my projects, and the story will continue the pro Skirayder. http://fotki.yandex.ru/users/fed-zuz/albums/
That is some terrific scratch building. You put a lot of thought and heart into it. I thought I should ask now before it is too late for you to address: the wing looks like it might have a weak point in design at the landing gear bays. The wing tube is not continuous through the bays and it does not look like there is extra reinforcement to make up for the break in the main spar/tube. If you have considered and constructed extra reinforcement for this area, and I just cannot see it, please excuse me. Once again though, very nice work. Jon
Thanks for the advice but I have already said the plane flies and everything is fine, running in front of say that seechas upgrade chassis, and everything is fine.
Then he began to make the chassis, they are tricky to Skyraider when cleaning around the front wheel is turned 90 degrees.
Much has been devised to torment the landing gear, but the solution was found, the basis for using the angle drive gear.
Maverick, your Skyriader looks GREAT. you are a very good builder. over the past years i have built ten[10] or more Skyraiders A-1H/ AD-6. my favorite build was from Ziroli plans. wingspan is 101". engine was a Quadra 75cc. please continue to post your build. don
Thank you all for your active participation in the discussion, I have not figured out the forum, read personal messages but I can not understand yet how to answer them, in this regard, I can give to your inbox who need [email protected].
My Feedback: (16)
TX
Индивидуалист. *то - одно удивительное, строят. Вы можете сказать мне, кто сокращал части и как Вы измеряли планы правильно? Я хотел бы строить одного из них, но не уверенный, где начать.
Спасибо,
Зак
Спасибо,
Зак
Drawings models do myself as the basis of the drawings take the plane, line-up, too, developed by me. At the moment, we have partnered with RC Composit, which in my drawings makes kits, at the moment there is no kit Skyraider but it all depends on desire.
Let's just say A-1H is a prototype but if you are interested in then there will be kits
http://www.youtube.com/watch?v=9gGOF3YlZks
My Feedback: (131)
I am very impressed- and I rarely say that.
Great work !
I can't wait for the flight report !1
Keep us all posted
On another note- We need to get you a 26cc engine that is rear ported so that giant velocity stack isn't sticking out of that beaitiful cowling.
Great work !
Keep us all posted
My Feedback: (16)
TX
В порядке это, чтобы написать Вам на вашем родном языке? Я действительно интересуюсь комплектом. *то было бы возможным для Вас соединить другой деревянный комплект для этого и продаться мне здесь в США?
