to flap or not to flap
NJ
doing a 105in stick(AMR KIT)...fuse.... 84,,,,, power..... 70 twin ......wing 105...? is would you put in flaps or not........and would they work on this type plane.......
RE: to flap or not to flap
I have them on my 1/4 scale stiks. The plane doesn't need them and I'm sure the giant scale one doesn't need them either ...but they are fun to have . Depending on the radio, you can set-up crow and do some short field, fast high altitude landings, set-up air brakes, and set-up full wing ailerons .
BC, CANADA
why not
Be a good plane to experiment with flaps, then when you build a scale model, it will be easier to adjust and get used to flying with them.
