Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Topflite Giant P-47D "Tarheel Hal"
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 05-23-2013, 02:10 AM
Lifer
Lifer's Avatar
Default RE: Topflite Giant P-47D
http://www.youtube.com/watch?v=ZzPiCEolZ8s
Old 05-23-2013, 02:31 AM
pacoflyer
My Feedback: (23)
Thanks guys
Old 06-02-2013, 06:43 PM
lancairmustang
lancairmustang's Avatar
I am going to be so nervous and scared the first flight with it, what is the flying characterists like? For instance what should I look out for on landing and takeoff? How does it fly?
Old 06-03-2013, 02:13 AM
Lifer
Lifer's Avatar
How does it fly? Watch the video! Balanced at the rear of the recommend range, flown on the recommended lows rates, 70 degrees of flap with about 3/32nds down elevator mixed in with the flaps. Hold a lot of power on when the flaps are down til about 3 feet above the runway.
P-47's are VERY well mannered!
Old 06-13-2013, 06:44 PM
lancairmustang
I was wondering, I'm in Canada, and our hobby shops are great hobbies, but it says for 599.00 can get the DA 50r but for 649.00 I can get the DA 60. But I am concerned if it is too big?? Any suggestions?
Old 06-13-2013, 07:57 PM
  #31
nitro wing
..can tell your 14, dont tell every one here you are good and show poeple how to fly etc. you are very green and have many years to get into the real experience of build and set up.
Dont let this detter you, much can be learned from the forums. You asked all the right questions so far, many may not be answered as fast as youd like, but the replies will come, take the time to set this up and have it checked over and over, You will end up with a 3000$ aircraft, dont toss it away with haste and ignorance.
The DA60 is not physically much bigger or heavier than their 50 and would be a good choice, and you can run a bigger prop, better for looks and power for sure.
Old 06-13-2013, 08:02 PM
  #32
nitro wing
the DLE55 has plenty of power also for it, its very loud on the stock muffler and maybe banned at some fields on stock pitts supplied.
Old 06-15-2013, 12:23 PM
  #33
David DeWitt
My Feedback: (289)
David DeWitt's Avatar
If you install the DLE 55 rear exhaust engine you won't have to cut a slot in the side of the cowl for muffler clearance on the Top Flite P-47. The side exhaust engine won't fit inside the cowl without cutting out a 2" hole so the front of the can muffler will clear. I am using a Zoar WW2 style 22/10 prop with good results.
Old 06-15-2013, 01:05 PM
  #34
apalsson
apalsson's Avatar
ORIGINAL: nitro wing
I agree. I have an MVVS58cc in mine. The output is probably on par with the DA60 or even a tad better and I don't find the plane over powered.
I know of people who have bolted in a DA85 in their and state that the plane still flies well. Personally, I feel anything in the 80cc class is an overkill but each to their own.
Remember, this is a 10.5Kg plane with all the gear in it and the wing is big. Once airborne, she is a big Pu**ycat to fly, both stable and predictable.
Only downside to bigger engines is the side torque on takeoff is somewhat more. I have a 3-blade 24x10 on mind and need to be on the rudder a bit on takeoff. The trick is to be gentle on the throttle and allow the tail to come up as you build up speed. Steer the plane straight down the runway with the rudder and you will have very impressive takeoffs. The plane lifts off (if you let it) at speeds well below any meaningful rudder response.
Regarding the flaps, - I have stuck with the throws as per the manual. I find that when I drop the flaps, there is hardly any pitching or need for down pressure on elevator. In fact, low rates on all controls as set out in the manual are quite good for the initial flights.
As long as you come in on final under a couple of clicks of power and gently flare when you are a foot or so above the deck, you can "let gravity do it's bit" and get the most beautiful wheel landings after you cut power to idle.
Old 06-16-2013, 02:08 AM
  #35
Lifer
Lifer's Avatar
Check the video in post #26. I have a DLE 55 with the stock exhaust and did not have to cut the cowl. Rotate the engine to the 7 o'clock position and everything clears. Look at the front of the cowl at the start of the video and you can clearly see the cylinder position and the factory muffler. You do not have to buy an after-market muffler!
Old 06-16-2013, 02:11 AM
  #36
Lifer
Lifer's Avatar
Pictures
ID:	1892184   Click image for larger version
Old 06-16-2013, 10:50 AM
  #37
apalsson
apalsson's Avatar
Hi Lifer,
This is perfect!
I bet the 55cc suits this plane very well. I obviously used what I had on the shelf for mine. I considered the 50cc as well but the plane was originally assembled for an air racing event where you were allowed up to 62cc so the 58 was my choice
Old 06-16-2013, 12:24 PM
  #38
Lifer
Lifer's Avatar
apallson,
The big P-47 is sweet flying airplane. I enjoy it very much!
Old 06-17-2013, 04:34 PM
  #39
lancairmustang
Thanks everyone for all the help, I got the DA 60 in it now. Nitro wing, don't tell me what I can and cannot do, I have a 3m comp arf 330 and fly it with my good friend Spencer Nordquist , we both are flight instructors. We can Fly...
Old 06-19-2013, 10:16 AM
  #40
nitro wing
ORIGINAL: lancairmustang
Why so nervous then? And asking the basic of basic
Questions?
It's common knowledge that's an easy plane to fly for an intermediate pilot.
Old 12-07-2015, 05:20 AM
  #41
Timbers
Are any of you running the Robart electric retracts? I just picked up a Tarheel Hal and am thinking of buying the Robart electric retracts since they have a good deal on them here for Christmas. Guy at the field told me Robarts bend. I know you can't make a blanket statement against all Robart retracts because one set failed someone long ago. Let me know your opinions thanks!
Old 12-13-2015, 06:44 AM
  #42
Thunderbolt47
My Feedback: (8)
Thunderbolt47's Avatar
All gears bend when you hit the ground hard
Old 12-13-2015, 07:56 AM
  #43
Lifer
Lifer's Avatar
You always have the option of mounting the gear with nylon bolts. They will shear rather than allow structure to rip out. I used 6-32 nylon bolts on my last several Top Flite giants and they work fine.
Old 06-20-2016, 01:40 PM
  #44
nc-17154
Hi
I"m flying with DLE 55 and pitts exhaust, more than 120 flights, sensational, fantastic, when you put slow flying like real.
Angel
Old 06-20-2016, 01:55 PM
  #45
Lifer
Lifer's Avatar
I believe the Tarheel Hal is rapidly going away. Tower has dropped the price to the mid-500's and change. This usually indicates that it's going out of program. If anybody is so inclined, buy one now!
Old 07-06-2016, 11:12 AM
  #46
CARS II
My Feedback: (7)
CARS II's Avatar
How will this P 47 fly with a twin 40 in it?
Old 07-06-2016, 12:49 PM
  #47
Lifer
Lifer's Avatar
In my opinion, it isn't enough power to safely fly the plane.
Old 07-30-2016, 08:57 PM
  #48
Saillfish
My Feedback: (17)
I just finished the TF Razor back giant P47. I have a DLE 55 in her. Has anyone had to add 2.7lbs of weight to the nose to balance it. Thanks
Old 07-31-2016, 12:36 AM
  #49
Lifer
Lifer's Avatar
32 ounces in mine, plus batteries just behind the firewall..
Old 07-31-2016, 04:28 AM
  #50
nc-17154
Hi:
I just put Life 2200 batterie in firewall for engine and another behind tank in fuselage and fly great.
