Seagull Edge 540 muffler
Just bought a Seagull Edge 540 60. Using a Super Tiger 90. Anyone know about pitts style mufflers for this combo? I looked at a Bisson 2176 or a Slimline 6002U . There's not much room in the cowl and I dont want to cut it up unless absolutely necessary. Both these mufflers seem similar in depth and have the rear angled outlet tubes. Any suggestions ? Thanks
HI
RE: Seagull Edge 540 muffler
I flew that airplane for quite a while. It was my go to everyday flyer. The stock muffler will work. I put a dubros rubber muffler extension on the muffler to lead the exhaust out the bottom. I believe I bought a pitts muffler and couldn't get it to fit. Make sure you add some reinforcement to the fire wall. The seagull kits are a little weak there. Have fun
Did you mount the engine at an angle to get the muffler in the center beneath the engine? Any suggestions on CG? Lots of people dont seem to like the recommended location.
With this lighter engine I was going to move the rudder servo to the radio compartment and use a pull-pull setup, Did you do this?
Any tips on flying characteristics?
Thanks much, Jim
Thanks much, Jim
