JFX vs ZOAR 22x8
UT
JFX vs ZOAR 22x8
I was curious if anybody has done a static pull test to compare how zoar props pull versus Jfx props. I'm not looking for rpm tests here folks, I'm looking for lbs of thrust. Thanks!
UT
I don't have a fish scale to make a setup, otherwise I would. I do have a few different props. The reason I was wondering is because I noticed the blade width of the Zoar was 46mm and the jfx was 43 or 42mm. I'm willing to bet the Zoar is a better 3d prop. Surely someone has done this test already.
