1/4 Scale Sig Cub - Want to make the 84" wing a split wing
I've acquired a Sig 1/4 scale clipped wing, and can't get it into any of my vehicles easily. I am in the process of removing the Sig colors and going to cover it with Cub Yellow Coverite, and in the process, wondering if it is possible to make the wing a 2 piece (split) wing?
Monte
Monte
My Feedback: (19)
There are a number of excellent 1/4 scale CUB builds here on RCU in various forums. Represented are the J-3 both in full span and clipped versions as well as the Super Cub .... plus others. Both the SIG and Balsa USA kits are also shown. Here is a link to just one very excellent thread. Do some searches for some other threads and you should find enough reading for days.
http://www.rcuniverse.com/forum/kit-...cub-build.html
In these various threads, several change the cabin top in several different ways to incorporate a two piece wing. Some modify the cabin top for easier wing installation or to strengthen this weak part on a J-3 fuselage. You should be able to get some excellent ideas from these threads. The wing center section as used on the full span SIG J-3 has always seems a bit clunky and way off from scale. A pain to build and it just doesn't look right on the plane.
I'm currently building a highly modified SIG J-3 and doing away with the bolt on center section design. The center section is now incorporated into the fuselage structure allowing for a more scale top stringer arrangement, etc. I'm using a 1" wing tube to support the individual wing panels as is common with most airplanes today. Like most CUBs, the struts are 100% so I don't depend on the tube to support flight loads.
Thanks fellows! I'll check things out further. Also, I did purchase the full-wing kit from Sig, and will open it and look at the plans.
I really appreciate your input.
Monte
Monte
