First non "commercial" gs kit
In considering my first Giant Scale kit by someone other than a kit manufacturer (i.e. Kit cut from plans from designer such as Ziroli, Bates, Hostetler, etc. ) does it make any difference in difficulty if I re-scale the plans? Can I even get the one-off size cut by a reputable cutter? Thinking about having a Bates P-36 enlarged to 111" (exactly 1/4 scale)... what drawbacks will I have?
The new plans will show enlarged wood, but it doesn't mean that the model should be built with it.
For instance, say an 82" model may have 1/8" sheeting. That same 1/8" sheet can be used on the expanded 110" model. The same is true with dimensional sticks
Not everything needs to be correspondingly enlarged. To do so will result in an unnecessary weight gain, with no significant gain in strength.
In my opinion, it takes advanced building skills to build from expanded plans. Knowledge of structure and materials is required.
You can't go by any dimension, printed on the plans. They aren't recalculated during the printing process.
What the OP is planning, can be done, but it takes some advanced skills to do so. If he posseses those qualities, there is no reason to hold back.
I think I may stick to original plans for my first few designer kits. Have no clue how to mold my own glass parts and probably am not well off enough to purchase one-off gear.
Readily available parts are a big plus.
I hope that you have an enjoyable plans build. Do you still plan to build the Bates P-36, or something else ?
