Q200 35% plug pix
#58
feather fill completed
You just can't beat that feather fill--you can see in the pictures how it changes color as it is sanded-showing low spots in the surface-but unlike primer-it allows sanding until the surface levels. I also piled it on over the canopy/ windshield juncture to accentuate the edge by sanding the surface of the windshield only---fills in pin holes in a single gun pass! Wing fairings were involved but worked out.
#62
wheel pant opening
I know it's trivial but I just can't stand a raw fiberglass edge where the wheel opening occurs --decided to install an aluminum bead as part of a finished opening--again -it's a plug so that bead will appear in thefinal layup--needless to say I've got some blending to do
#63
pant opening blending
The jury is still out on this one--I think I like it-I'll give it some time to simmer in my head--gee Bob -I'm givin away my secrets--good thing there is not much interest--I'm flyin under the radar--like that auto gyro that landed at the Whitehouse---Possibly reminds me of a alien victim with it chest burst open!
#65
new ideas
Unless you're familiar with this stuff as you are--it is probably confusing at best--What can you do------ on another note--I was bending aluminum tubing for one of the wheel pants and was looking at the canopy-had an idea--see pixit will provide an outstanding finished edge not to mention a different look!
#68
Thinking ahead
I'm already picking out the paint colors--found a ford with a candy red-might look great matched up with a pearl white--decided on access panel on the side of wheel pant--panel mimics the shape of pant with 1/8 tubing--held on with a couple chrome button caps--should look cool
#75
finishing plug
Got the feather fill sprayed---now it's starting to look like something instead of all those different colors from the filler and primer--aerodynamically-it will probably trip the boundary layer along the body and screw up the airflow over the tail---just my luck-----I'm still keepin it
