Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Q200 35% plug pix
Old 03-22-2015, 05:45 PM
  #51
rick hamel
Default Fairing the "Q"
cut the vertical loose after fairing it into the body-started blending the wings in---what the plane will look like in inverted flight---------NOT!
ID:	2083446   Click image for larger version
ID:	2083447   Click image for larger version
Old 03-23-2015, 04:07 AM
  #52
sensei
sensei's Avatar
WOW! You are really flying on this thing!
Bob
Old 03-23-2015, 01:47 PM
  #53
TampaRC
Originally Posted by rick hamel
Where in Ohio? I'm sure you know I'm in Pittsburgh
I'm in the Toledo area......
Old 03-23-2015, 04:47 PM
  #54
rick hamel
I think It just seems that way --everything came together all at once .
Old 03-23-2015, 05:01 PM
  #55
rick hamel
Toledo--how lucky can you get--makes going to the week signals show a breeze!!!!-usually takes me 4-5 hrs to make the trip
Old 03-25-2015, 05:23 PM
  #56
rick hamel
Default clipped wings
I started blending the wing strakes into the fuse --still need to fab the aluminum end plates to protect the airfoil shape
ID:	2084169   Click image for larger version
ID:	2084170   Click image for larger version
Old 04-12-2015, 06:23 PM
  #57
rick hamel
Default wing blending
made aluminum plates to protect the airfoil shape--matching plates assure good wing fit after making molds--again--these pictures are of just plugs for making molds
ID:	2088501   Click image for larger version
ID:	2088502   Click image for larger version
ID:	2088503   Click image for larger version
Old 04-16-2015, 04:47 PM
  #58
rick hamel
Default feather fill completed
You just can't beat that feather fill--you can see in the pictures how it changes color as it is sanded-showing low spots in the surface-but unlike primer-it allows sanding until the surface levels. I also piled it on over the canopy/ windshield juncture to accentuate the edge by sanding the surface of the windshield only---fills in pin holes in a single gun pass! Wing fairings were involved but worked out.
ID:	2089717   Click image for larger version
ID:	2089718   Click image for larger version
Old 04-17-2015, 02:13 AM
  #59
sensei
sensei's Avatar
Really looks great Rick.
Bob
Old 04-17-2015, 05:02 PM
  #60
rick hamel
Thanks Bob---I'm playing with the wheel pant plugs now-hope to have pics tomorrow
Old 04-18-2015, 05:01 PM
  #61
rick hamel
Default wheel pants
Still not sure how I want the pant to come apart--I was thinking of a side panel that mirrors the pant shape that would be removable --allowing access to the toe out adjustment and suspension install.
ID:	2090066   Click image for larger version
ID:	2090067   Click image for larger version
ID:	2090068   Click image for larger version
ID:	2090069   Click image for larger version
Old 04-19-2015, 02:06 PM
  #62
rick hamel
Default wheel pant opening
I know it's trivial but I just can't stand a raw fiberglass edge where the wheel opening occurs --decided to install an aluminum bead as part of a finished opening--again -it's a plug so that bead will appear in thefinal layup--needless to say I've got some blending to do
ID:	2090248   Click image for larger version
Old 04-21-2015, 05:06 PM
  #63
rick hamel
Default pant opening blending
The jury is still out on this one--I think I like it-I'll give it some time to simmer in my head--gee Bob -I'm givin away my secrets--good thing there is not much interest--I'm flyin under the radar--like that auto gyro that landed at the Whitehouse---Possibly reminds me of a alien victim with it chest burst open!
ID:	2090995   Click image for larger version
ID:	2090996   Click image for larger version
Old 04-24-2015, 02:25 AM
  #64
sensei
sensei's Avatar
I can appreciate what you are doing here Rick because I am an old composites toolmaker myself.
Bob
Old 04-24-2015, 05:43 PM
  #65
rick hamel
Default new ideas
Unless you're familiar with this stuff as you are--it is probably confusing at best--What can you do------ on another note--I was bending aluminum tubing for one of the wheel pants and was looking at the canopy-had an idea--see pixit will provide an outstanding finished edge not to mention a different look!
Old 04-24-2015, 05:50 PM
  #66
DMehalko
My Feedback: (42)
DMehalko's Avatar
Epic build, cant wait to see it finished!
Old 04-24-2015, 05:56 PM
  #67
rick hamel
Thanks!----It's making me epically tired--but I'm really having fun with it--of that there is no question--finding time is the real struggle-but I manage
Old 04-24-2015, 06:09 PM
  #68
rick hamel
Default Thinking ahead
I'm already picking out the paint colors--found a ford with a candy red-might look great matched up with a pearl white--decided on access panel on the side of wheel pant--panel mimics the shape of pant with 1/8 tubing--held on with a couple chrome button caps--should look cool
ID:	2091762   Click image for larger version
Name:	Q2 paint.jpg
Old 04-26-2015, 04:31 PM
  #69
rick hamel
Default more Q
I finished blending in the tubing around the windshield--I definitely like the look-next I'll hit it again with some feather fill when I spray the wheel pants
ID:	2092382   Click image for larger version
Old 04-26-2015, 06:56 PM
  #70
TampaRC
Keep up the good work!
Old 04-27-2015, 05:39 PM
  #71
rick hamel
Thanks---getting close to having the whole thing in primer---need an entire weekend--wish me luck with that!
Old 04-28-2015, 01:46 AM
  #72
sensei
sensei's Avatar
The best of luck to you Rick.
Bob
Old 04-28-2015, 05:23 PM
  #73
rick hamel
Default Pant acess panel molds
As usual -Thanks for the support---pulled a set of molds after scribing the access panel on the sides of the pants.
ID:	2092900   Click image for larger version
Old 05-01-2015, 05:20 PM
  #74
rick hamel
Default front wing
finally--pants are attached to wings and ready to be feather filled---ooh joy
ID:	2093460   Click image for larger version
ID:	2093461   Click image for larger version
Old 05-03-2015, 06:16 PM
  #75
rick hamel
Default finishing plug
Got the feather fill sprayed---now it's starting to look like something instead of all those different colors from the filler and primer--aerodynamically-it will probably trip the boundary layer along the body and screw up the airflow over the tail---just my luck-----I'm still keepin it
