97" Gee Bee Senior Sportster
Anyone familiar with these aircraft? It is my understanding the cowl is 12" in diameter? If that is the case how about a DLE 61 twin for a power plant? They measure about 10 1/2" overall and look like they have the correct weight and power.
My Feedback: (7)
I happen to have one that I've been flying for about 6 months by now, it has a twin BME 61 and it is just a joy to fly, for prop I'm using a 22X10 Xoar prop, mine is V1 with a one piece wing and wires for the main gears.
Let me know if you need any more details,
http://www.rcuniverse.com/forum/gian...en-ii-arf.html
I had a G-62 in mine. Beautiful and graceful. After about 3 years the joiner tube bent during a flight. I got it down in one piece but never trusted it again. I did replace the aluminum tube with one made of carbon fiber, but the planes structure, internally, was damaged by the tube failure. I eventually scrapped it.
already a topic off it : http://www.rcuniverse.com/forum/gian...en-ii-arf.html
i got one with a zenoah g62, it fly's realy great,so easy...;it's like a scooter in the air!
I'm assuming the Maxford is the Pacific? Did you make any changes/mods to the Gen II? Hopefully all the shortcomings of the first version were corrected with the second. Landing gear seemed to be the major complaint, maybe the struts will do the trick.
Jimmy, i bought my geebee second hand, so it is installed with a g62 (CDI ignition) and a tony clark muffler.
Mine has oleo struts http://www.rcuniverse.com/forum/gian...ml#post8142735
and i changed the foam tires to du-bro inflatable tires 5.5TV http://shop.dubro.com/p/5-1-2-dia-la...-treaded-wheel
this give's me way more shock absorbing !
at the moment, i fly it with a wooden 22x10, but i will soon try this prop fiala 24x8 on recomandation http://www.vrtule-fiala.cz/shop/inde...mart&Itemid=53
ID
I own one now about 5 years with a dle 111 with smoke check it out on my web site www.silverhillsrcflyers.com I'am the founder of silver hills rc Tim Mcgee here in N Idaho Athol Id. it is a pacific aero model oleo struts flies at about 110 down the runway awesome.
