Enough power?
Enough power?
I've decided to build a BUSA 1/4 scale sopwith pup. Most people run a 23cc or bigger 2 stroke but I'd like a four stroke gas engine. The new Saito FG-19R3 is 19cc. Will this be enough power? a 15-6 is the largest prop recommended by Saito.
I'm going to find out the weight diffence between the 33 and a 23 two stroke.
OK the 33 is 50.8 oz
a 26 two stroke is 53.6oz, a 23 is 51oz.
This could be a good fit.
Ya, I don't think you can add too heavy of a motor to these pup's. I read a post from a guy who used a 26 2 stoke and he had to add FOUR lbs to the front. He obviously built it tail heavy, but it came in at 20lbs !!
