Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
OV-10 Bronco
Old 02-20-2017, 05:17 PM
Mike Haddox
Default OV-10 Bronco
I saw on youtube a gentleman from overseas flying a giant scale Bronco. It has a 14 ft. wing span. any info would be appreciated. I have a couple JetCat turboprops I need to put to work. Thanks, Mike
Old 02-20-2017, 07:51 PM
Chad Veich
My Feedback: (60)
That would most likely be well know designer Tony Nijhuis' big Bronco. According to his web site "It will NOT be available as plans or woodpacks." However, his prototype is apparently for sale.
http://tonynijhuisdesigns.co.uk/Bronco.htm
Old 02-20-2017, 09:55 PM
Mike Haddox
Thank you
Old 02-21-2017, 03:52 PM
jetmech05
The full scale Bronco had counter rotating engines I'm pretty sure both engines turned inboard. I wonder if a model would have to have counter rotating engines too
Old 02-23-2017, 03:54 PM
pattnut
I have owned/operated TWO 1/5th scale OV-10 models. One gas powered and my new one is electric powered. Neither had/has counter-rotating props. I have NO problem handling "P" factor; it's insignificant...
Old Dawg
Old 02-24-2017, 09:26 AM
jetmech05
Not counter rotating props. Both engines turned inboard toward the fuselage. I was wondering about the p factor.
