Plan gluing
AB, CANADA
Plan gluing
Been a builder for long time and have always had an issue with getting the plan cutout off the ply and balsa. I've usually used a contact type spray to glue the plan part (wing rib, etc) to ply or balsa. Then before I can glue things I have to sand off the paper as glue doesn't stick to paper. What are you guys using for this that works good.
3M 77 sprayed real light (dusted) on the paper template.
Cut out your part/parts immediately.
Peel the paper off immediately.
I've never had an issue with the template sticking down so hard on the balsa/ply that I couldn't peel it off unless I sprayed way too much glue down.
carl
carl
