Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
balance problem
Reply
Old 04-15-2018, 04:06 PM
left seat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default balance problem
I have a giant scale 109 in taylorcraft which I built from a Lanier kit. CG is 4" and I have been encountering big problems balancing the plane. Using the horizontal tail plane for my level I have discovered a slight warp. I am not too sure what to trust here since both give different readings on the level. The warp is slight but noticable when using the level, and looking down the fuse. I have flown other planes with simiular defects and , with a little trim, they have flown fine. So I assume, from past experience, that with a little trim there should be no issues. My problem is how can I accurately balance my plane? Since I don't know what part of the tailplane is accurate can I use my angle of incidence meter to accurately balance the plane? Also, according to the level on the rear tailplane I concidered accurate I need about 2lbs of weight in the nose to balance the plane. I have put floats on which are 47in long. They protrude about 3in past the prop, any thoughts?
left seat is offline
Old 04-15-2018, 06:00 PM
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vanessa CG rig and a small tubular bubble level on the stabilizer.
Tom Nied is offline
Old 04-15-2018, 07:36 PM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
According to page 29 of the manual, the wing is at zero and the stab is positive. I would use the wing. Dan.
All Day Dan is offline
Old 04-15-2018, 07:48 PM
All Day Dan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dan.
Attached Thumbnails 99240.pdf
Old 04-16-2018, 08:01 AM
All Day Dan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check page 31 for the correct location of the CG. Is that where you have it?
Old 04-16-2018, 02:28 PM
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not so sure about that.
Tom Nied is offline
Contact Us Archive Advertising Cookie Policy
