Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
30cc Battery Setup Question
Reply
Old 07-31-2018, 10:56 PM
Malcolm King
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 30cc Battery Setup Question
Hello all!
I have a quick question about the battery setup on my 30cc Edge 540. Currently I've got a two-battery setup, one 5-cell NiMH battery to the receiver for flight controls, and one to ignition. I've got a few flights on this setup, but I'm looking for a slightly more redundant system. I'm not too fond of the current setup as it offers no redundancy for flight control power whatsoever in the event of a battery or switch failure. I came across this as a potential solution: power the receiver with two separate NiMH batteries, each through its own individual switch and each plugged into its own receiver port. I would then power the ignition via a IBEC out of one of the ports of the receiver. Has anyone flown a setup like this? Is this advisable?
Thanks so much for any and all advice!
Malcolm
Malcolm King is offline
Old 07-31-2018, 11:22 PM
Steve Percifield
My Feedback: (14)
Steve Percifield's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are going to get a hundred different opinions, so here is mine. I have used the redundant battery set up you mention many times, over many years without any issues. 2 batteries, 2 switches, plugged into different receiver ports. But I don't and never will power my ignition from any battery connected to my receiver. I always use a separate ignition battery. Yes, that makes 3 batteries to charge, big deal. But a warning. You cannot charge the 2 receiver batteries at the same time. You will have to charge them 1 at a time. Go for it guys!!
Steve Percifield is offline
Old 08-01-2018, 01:48 AM
RBACONS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A Tech-Aero IBEC will allow you to use 2 batteries for your receiver and power the ignition module at the same time. Perfectly safe and no interference issues to worry about.
RBACONS is online now
Old 08-01-2018, 06:24 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Exactly. Have this setup on several planes and it works like a champ.
BarracudaHockey is online now
Old 08-01-2018, 11:50 AM
Malcolm King
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great, thanks so much for the help!
