Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Gary Allen 33% Bücker Jungmeister
Reply
Old 08-12-2008, 02:26 PM
  #626
Kellermann
Kellermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gary Allen 33% Bücker Jungmeister
Or he will even put a turbine in it and make it a narrow nose bird...
all kiddin aside, Ken, that looks awful. OK for practical operation, but the scale look is gone. In my judgement it's the same as putting a 3-Blade prop on a P-51...
Isn't there anyone out there able to make a steel wire or even machined, springloaded scale tailwheel for this bird?
Ken, sorry, you know, nothing personal...you know me by now.
Marcus
Kellermann is offline
Old 08-12-2008, 02:29 PM
  #627
CharlieK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks like it should last for a while Ken. Maybe I should make mine from 1/4 wire when I get that far.
Charliek
CharlieK is offline
Old 08-12-2008, 02:51 PM
  #628
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kellermann
Marcus
I love it Marcus. I'll try to keep it in a knife edge so no one will see the tail wheel. By the way, I taped the pull/pull cables in place in case someone does make a sprung tail wheel. The SD kit came in today.
CharlieK 1/4" would probably work. That's all of the mods I'm going to make for now.
Big_Bird is offline
Old 08-12-2008, 02:57 PM
  #629
rabacon
rabacon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ken, your post got me thinking about my tw. During my build I went straight to the 5/32 wire for my tw. It is mountend per plans with the nylon nosewheel bracket as well. I brazed a tiller bar to a collar that retains the tw wire and there are springs on the tillerbar ends that attach to a hard point on the tailpost. sort of a spring damper as my tw is free castoring with built in stops per se.
There is a space in the nylon bracket where I may be able to add a small spring which, with some stops added, would give a shock absorbing effect. As built in the access panel on the bottom of the tail, I think I may do this while I wait for my graphics. If I get some time I will post a pic of this, before and after, if I do the mod, which based on what your experiencing I just may well do.
rabacon is offline
Old 08-14-2008, 09:55 PM
  #630
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It may work Roger, I don't know.
Take a look at my new build thread.
http://www.rcuniverse.com/forum/m_78...tm.htm#7846239
Big_Bird is offline
Old 08-15-2008, 08:17 AM
  #631
rabacon
rabacon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
42% anything is way cool. I'll be watching that one.
rabacon is offline
Old 08-15-2008, 08:14 PM
  #632
CharlieK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ken,
The Decathalon is only about 2 ft. short of a Pitts - you ought to put a seat in it and fly it yourself . How did your Waco turn out, it should have flown well. It would be interesting to compare the Decathalon to the full size for flying characteristics, the Sig cub I built flew exactly like a full size J-3. Looks like fun to build, if I ever get the Jungie done.
Charliek
CharlieK is offline
Old 08-21-2008, 08:25 PM
  #633
Tipover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awsome looking planes guys.
Can someone tell me the inside cowl width on the GA 33% Jungmeister? I have a nice running 3W 78B2 looking for a home, needs a good 12" inside clearence.
Anyone have experience with the Wendell Hostetler 26.5% Bucker Jungmeister plans? Wondering how they compare to Gary Allens version.
Kevin
Tipover is offline
Old 08-21-2008, 09:05 PM
  #634
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi CharlieK
The Waco turned out very good. I plan to put the maiden flight on it this coming Saturday morning.
As for the Decathlon, my 1/3 scale Super Decathlon flies in a very scale manner. It has more horse power for it's size than the full scale 180 hp model. There is no reason not to think that the 42% will not fly exactly like the real thing.
Big_Bird is offline
Old 08-22-2008, 08:04 AM
  #635
rabacon
rabacon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kevin, I will measure mine tonight unless someone here gets the info for you today, but I think youre going to come up short. Havent seen the WH Bucker plans.
rabacon is offline
Old 08-22-2008, 03:22 PM
  #636
CharlieK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The cowl I have is 11 in. at the back end. It is probably 10 - 10 1/2 at the forward end but you may be able to fit it in the blisters. The Decathalon is a good flying airplane Ken. The real one is not very strong so you have to limit the g's you pull but it sure is fun when two Cessna's make a pass at you and you can peel off and chase them
Charliek
CharlieK is offline
Old 08-22-2008, 04:18 PM
  #637
Tipover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for measuring CharlieK. Sounds close for my 78, I was a little conservative with my 12". I measure 11" across my plug caps. What concerns me is the right thrust kicking the forward plug cap way out on the left. Probably not the best airframe for this engine. Sure wish there was a nice 1/3 scale kit of this plane on the market, not sure if I'm up to the scratch build. Sure is a nice looking bipe. My 13 year old son drools over meisters ever since seeing the white one in the Great Waldo Pepper movie. Wonder what ever became of that plane?
Edit) I guess the Bucker plane was yellow & red in the Waldo Pepper movie. Also had a none radial engine.
Kevin
Tipover is offline
Old 08-22-2008, 09:11 PM
  #638
Jennyboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The steerable tail wheel design from the Pica P51 seems to work very well in the Bucker.It withstands a good pounding and does not strain from excessive castering....Bob
Jennyboy is offline
Old 08-22-2008, 10:35 PM
  #639
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, thanks.
Big_Bird is offline
Old 08-23-2008, 03:07 PM
  #640
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys, the maiden flight of my Waco YMF-5 was an unqualified success and so was the second and third. The only trim required was a little down elevator. I need to tighten up the tail wheel pull-pull linkage a little. The only thing that surprised me was the slow roll rate. I would guess that it was exactly scale. Takeoffs and landings were very easy. Loops and Cuban eights were very easy. Inverted flight required very little down to maintain altitude. I had a little trouble maintaining altitude in knife edge flight. I use rudder all the time for co-ordinated turns and that made them look perfect. In fact I just about use rudder more than ailerons. Several people remarked how realistic it looked in the air.
A friend took some air shots and I'll post them when I get them.
Big_Bird is offline
Old 08-23-2008, 09:39 PM
  #641
Tipover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Congratulations on the maiden flight. Wish I had the patients to turn out beautiful models like yours.
Kevin
Tipover is offline
Old 08-23-2008, 11:06 PM
  #642
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a lot Kevin.
Here is the video of the first flight. It's pretty shaky but I would rather have it that way than not at all.
http://www.youtube.com/watch?v=YxRnGXP7610
Big_Bird is offline
Old 08-26-2008, 02:43 PM
  #643
CharlieK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats a really good looking airplane Ken, glad the first flight came out well and it flies well.
Charlie
CharlieK is offline
Old 08-26-2008, 02:55 PM
  #644
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Charlie, I'm real happy with it. I won't be flying it again until I take it to Bomber Field in 3 weeks.
Big_Bird is offline
Old 09-05-2008, 01:45 PM
  #645
Vermilioncliffs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ken,
Been silent for a long time. Have been assembling the bones for my Jungie. I find I need some information since I don't want to re-invent the wheel.
I noticed on one of your entries that you have photos of your servo, linkage set-up, etc. I am particularly interested in the elevator. Did you use dual servos w/ pull-pull setup or what. I would appreciate any pic's you might have. Those on the thread are not as detailed as I seem to need. If you wouldn't mind responding by e-mail I would appreciate it, as I'm sure I'll have additional questions. kgcarp@xpressweb.com. As always thanks for your assistance. Kirt C.
Vermilioncliffs is offline
Old 09-17-2008, 10:53 AM
  #646
rabacon
rabacon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok things are looking up for finishing my Bucker this fall. Spent some time over the past week with a flying buddy who has been helping me with my graphics and masks. Picked up the proofs last night and they look great when put up to the model. Some masks, some vinyl, some dry transfer. The only decision I need to make is whether to use vinyl or paint masks on the big graphics. The vinyl I have access to is .3 mm and I wonder how well it will lay over rib tapes and stiches. I have my concerns going this route. Anyone have any insight? Vinyl gets it done sooner than masking and painting and as I am in year 3 on this project I really would like to wrap it up. Been busy with work and family as of late. Hope you all are well. Roger
rabacon is offline
Old 09-17-2008, 01:56 PM
  #647
Homepylon
Homepylon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Rabacon:
I used paint masks on my Jungie for most of the graphics and am happy with the results. It takes a bit longer but you get an exact color match and no problem going over surface detail.
Good luck with yours.
Brad
ID:	1035141   Click image for larger version
ID:	1035142   Click image for larger version
Homepylon is offline
Old 09-17-2008, 02:03 PM
  #648
rabacon
rabacon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What paint mask material do you use? My pal has a nice cutter/plotter that cuts the masks off rolls of material but we are both wondering what the best material would be for model use. He currently has a semi stiff white paper-backed mask. I have used some flexible airbrush masking material for free-hand work but it has no backing and wont work on his cutter. the finish on your bucker is outstanding from the pics. Thanks, Roger.
rabacon is offline
Old 09-17-2008, 05:22 PM
  #649
Homepylon
Homepylon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Roger:
Gary at getstencils.com did all my masks. They were superb. Unfortunately I don't think he's doing paint masks anymore. Shame, as he did nice work at affordable prices.
The mask material you describe sounds like the same stuff I used. Be sure it has a low tack adhesive that does not leave a residue. My biggest gripe with frisket paper is the residue left behind.
The trick to getting a good result is to seal the mask's edges with the base coat color and apply really light coats. I used my airbrush and just misted on coats.
Old 09-18-2008, 08:21 AM
  #650
rabacon
rabacon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Brad. No Gary is no longer doing the stencils. Was working with my friend at our club meeting last night, using the proofs he provided I made all my adjustments and he is going to cut my stencils this weekend. I have to get my airbrush out and do some practice and compatibility checks and then I am going to shoot the stencils. Its good to get motivated again and finish this project. Thanks for your insight Brother. Roger
rabacon is offline
Reply
Display Modes
