If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 31 of 39 FirstFirst ... 212930313233 ... LastLast
Results 751 to 775 of 957
  1. #751
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gary Allen 33% Bücker Jungmeister
    Ray, that seems like a valid way to balance the plane. You should have a much better experience the next time you fly it.
    Ken
    WACO Brotherhood #70, Arlington TX home of the Dallas Cowboys, SupBowl45, Texas Rangers, World Series 2010, 2011
  2. #752
    Join Date
    Nov 2002
    stoughton, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi
    Got five flights from the Bucker today and it went very well. Appreciate support from John Glezellis it getting it trimmed out.
    CG was right on and just had to scale back the elevator/aileron travel a bit and increase the expo. On the MOKI 210 started with a 20 X10 prop but changed to a 22 x 8 and was a bit better so will stick with the 22 x 8 wood prop from now on. Flys nicely at about half throttle and no bad habits at low speed. At least so far....
    Next step is to finish the text markings and N number.
    Some pictures from the field below. Was an excellent day... :-)
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1447217   Click image for larger version.
ID:	1447218   Click image for larger version.
ID:	1447219   Click image for larger version.
    Ray:
    Flying: Hanger 9 P-47, Sig Catabria, Albatros DV, Taurus, Spartan Executive
    On the bench: Ziroli Staggerwing
    Next up balsa USA SPAD XIII
  3. #753
    fredo's Avatar
    Join Date
    Jul 2003
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi folks
    I love this thread. I have just purchased Gary Allen 33% plans and decided to scale them up to 35%. I'm saving money for Moki 150 radial. I'm guessing it should be a good match. Already started by buying spruce stock from the Sky shop. So today I spent cutting all sizes I need. I think this works out cheaper than buying spruce stringers in the hobby shop. I'm planning to cut all parts by hand. I know it's a pain but I will have plenty of time before I get the engine.
  4. #754
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: fredo
    Hi folks
    That is super Fredo (I assume that is your name). You are going to love the looks and the way the Jungie flies. Remember to keep the tail end as light as possible. This may not be as essential when using the Moki 150. I'm curious where you are going to buy your 150. A good friend experienced some valve train problems with his RCS 250 radial and it has been back at Troy Built models for quite a while waiting on parts. Seems that parts and service are scarce for these radials unlike the engines that DA sells.
    Are you going to make your own cowl since you are scaling up the plans?
    G-day y'all
    Ken
  5. #755
    fredo's Avatar
    Join Date
    Jul 2003
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    G'day
    I'm thinking of buying radial from TBM but need to save money for it first. If I see a better deal in the meantime, elsewhere I might buy that. I realise the service is not the same in comparison to DA, which are relatively easy to service and not as complicated. In my case since I live in Australia things could take a lot longer but still," I might be crazy" will do anything to get that sound..)
    Yeah I know what you mean by keeping the tail light. It can be a problem if you are using 50cc engine. As you mentioned I'm going to build cowling myself. Its diameter is now 11.5".
    Just a question. It seems like the flying wires are keeping the wings together since they are only doweled in their locations. Does this make the wing strong enough for basic aerobatic maneuvers? Or do you think the wings would be better of with wing tubes for extra strength?
  6. #756
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am using 4-40 size rod for my flying wires with solder on type Dubro rigging ends. I have put my Jungie through every conceivable violent maneuver that I can think of. Never a problem or a broken wire. Same for the first Jungie I built from Allen's plans. No need for wing tubes.
    Ken
  7. #757
    fredo's Avatar
    Join Date
    Jul 2003
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for clarification. I might do the same thing.
    BTW Fredo is a name of my dog
  8. #758
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Glad I could help. What is your name?
    Ken
  9. #759
    fredo's Avatar
    Join Date
    Jul 2003
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My name is Viliam (eastern European living in Australia) I was flying IMAC and a little bit of 3D up until now but my work has changed and allows me a very little amount of time for practicing sequencies. So I took a break and try to build something for change. I have scratch built a few planes in the past, so I'm a bid of jack of all trades if you could call it that way. A classic bipe like this one was always on my list, to build but I just never got around it.
    I thought I'll start a new thread on this but changed my mind and decided to use existing one. I'm not a fast builder but so far every single project I have started I also finished. Going by my history, this plane will definitely see the finish line in the indefinite time
  10. #760
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Viliam, I'm glad you chose to stay with this thread. It is entirely appropriate because your Jungie is based on Gary Allen's design. There are several of us that will be glad to try to answer questions that you might have. However, with your background in modeling I doubt that there will be many.
    Ken
  11. #761
    fredo's Avatar
    Join Date
    Jul 2003
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ken
    I think it's great to see you guys are still hanging around. There's always plenty of questions to ask and descisions to make. I appreciate your help.
    Just a little update with no pics. (nothing much to see yet[&:]) I have finished cutting all stringers, made up ply templates for the wing ribs. I'm using the old sandwich method. Made up servo lead paper tubes for the wings. Used old curtain metal tube 15mm in diameter, lightly coated with silicon grease and angle-rolled paper tape used for gyprock gap filling. This is a highly porous paper that can be coated with glue of some sort. I used epoxy resin which was just brushed on the surface. Result is a nice strong light weight tube. I needed to make this now as I have to drill holes into my templates
  12. #762
    Join Date
    Mar 2007
    Saint Seurin de Cadourne, FRANCE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi, i just start to build a new Bücker at 1/3 scale.
    And i just bought for it the new boxer moki 100.
    I hope the weight will be around 12 kg.
  13. #763
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: depourtal
    Hi, and welcome to the thread and RC Universe. I'm sure you will have a lot of fun building the Jungie. The Moki 100 will be a very nice engine for it. Have you checked to see if it will fit inside the cowl? Are you building yours from Gary Allen's plans? There are quite a few guys on here who will be glad to try to answer any questions you might have.
    We usually go by names on this thread so what is yours?
    Ken
  14. #764
    Join Date
    Mar 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ken, my name is Max.
    I hope you dont mind, my Bücker 1/3 is a Paolo Severin Kit.
    The moki 100 fit very well in the cowl.
    I am quite finish with the fuse, and i will soon start the covering.
    Max
  15. #765
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Max,
    Glad to have you here. Post some photos if you can.
    Ken
  16. #766
    Join Date
    Mar 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Uploaded with ImageShack.us
    here is the fuse.
    Max
  17. #767
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That plane is very good looking. Is the framework metal? Does that company have a website?
    Ken
  18. #768
    Join Date
    Mar 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, the website is :
    www.paoloseverin.it/
  19. #769
    stefanP's Avatar
    Join Date
    Jun 2002
    southington, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can I get a flying weight of this plane? Does it come close to the plans weight?
    Thanxs,
    stefanP
    AMA 612678, CG 10-300 Member #63
    IMAA 24164
  20. #770
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: stefanP
    Thanxs,
    stefanP
    If the one you are talking about is the Gary Allen design, mine weighs 27# with a Sachs-Dolmar 4.2 in the nose. No added balance weight. Ignition and battery are on the firewall.
    Ken
  21. #771
    stefanP's Avatar
    Join Date
    Jun 2002
    southington, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanxs,Ken. As for the scale Italian kit, 4,453.27 USD[X(][X(][X(][X(] Maybe when I hit the lottery
    stefanP
    IMAA 24164
  22. #772
    Join Date
    Jan 2002
    henderson, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thought you guys would enjoy a pic of Gary's latest, the 35% Jungmann. The Luftwaffe scheme model is Matt Chapman's and the Spanish scheme one is Gary's model. Both models weigh around 29 lbs., both powered by DA85s. The gear is functionally articulating so that the wheels drop a bit and cant inward during flight. I put the maiden flight on Gary's model this weekend, and first indications are that it will be a good one. Gary and I plan to campaign the Jungmann at the Scalemasters in September.
    Great thread, gentlemen.
    Dorin Luck
  23. #773
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great looking planes Dorian. Thanks a lot for jumping here with the photo.
    Best of luck.
    Ken
  24. #774
    fredo's Avatar
    Join Date
    Jul 2003
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys, I haven't put any post for a while but just to let you know I'm still with the project. I decided to scale Jungmeister to 35% and here is my latest progress. Now, I have few more questions. Just made a bracket for the upper winglet. I followed the lines from the plan but it turned out, the upper winglet's incidence is actually -2 degrees rather than -1. Not really a big drama as I can adjust it but just wondering how would it affect flying if I left it like that. Also the upper winglet ended up a slightly more forward. Again, following the lines from the plan. Have you come across to something similar?
ID:	1490452   Click image for larger version.
ID:	1490453   Click image for larger version.
ID:	1490454   Click image for larger version.
  25. #775
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't think either thing will bother the flying.
    Ken
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
