Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Hostetler 33% Decathlon
Reply
Old 01-10-2013, 02:34 AM
  #4076
John La Belle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hostetler 33% Decathlon
HI Guys; I had the same concern with the screws in the spar so I used a 10/32 blind nut inside the inboard wing ribs and bolts from the inside of the fuselage cabin. it must go thru 2 cabin ribs so I used a piece brass tubing for a guide to line up the bolts with the blind nut in the wing has worked out well maybee an option for you to consider cheers John
John La Belle is offline
Old 01-10-2013, 04:04 AM
  #4077
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
actually, thats the way you mount the wings on the balsa usa super cub. it's a pain to get your hands inside the cabin door with a allen key and than get up to the wing mounts.it works but..........
Bobt2 is offline
Old 01-10-2013, 05:03 AM
  #4078
Kellermann
Kellermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys my ,02c
a) Spar x struts mounting: I use an L shaped (an U-Channel would be even more scale) like the pix below screwed onto the spar on my planes - and they┬┤re 3/8 x 3/8. Enough, considering there┬┤s a wing tube also. For more security, I could drill 1/8 holes thru the spars and place a lock nut on the otherside. I don┬┤t know on the WH design, but on mine there are 1/8 ply shearwebs along the entire span of the wing, providing for additional strength in both length and width, regarding to the spar itself.
b) Wing securing against the fuse sides: I use a bolt inserted from the root inside (fixed), and a wingnut from inside the fuse. Simple and easy. If you wanna go really scale trade the wingnut for a locknut, it┬┤s less visible.
Cheers
Marcus
ID:	1838823   Click image for larger version
Kellermann is offline
Old 01-10-2013, 06:28 AM
  #4079
RickP
RickP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob,
Not a bad Idea, maybe I'll stop over. It's supposed to be nice weather though, maybe flyable. It all depends on where you drill the hole, but your judgment is sound, I trust it's drilled in the wrong place. We will have a look.
RP
RickP is offline
Old 01-10-2013, 10:38 AM
  #4080
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes, i like the idea of bolts in the wing and nuts inside. i have wing mounts from da that are 1/4-20 threads and nylon knobs. i use them on my imac extras. i will retro fit a set into this bird. thanks for the idea
Bobt2 is offline
Old 01-12-2013, 06:05 AM
  #4081
martinwpb
martinwpb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
Wings are almost done will post a picture tomorrow. What do you think about the Hitec HS-5685MH for each surface? On a 2s lipo. Are these strong enough?
Also i have 4 piece of W1 rib? I only need 2 right?
Martin
martinwpb is offline
Old 01-13-2013, 03:43 PM
  #4082
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
should be more than enough.
Bobt2 is offline
Old 01-21-2013, 03:48 PM
  #4083
martinwpb
martinwpb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
pics 1
ID:	1842995   Click image for larger version
ID:	1842996   Click image for larger version
Old 01-21-2013, 03:50 PM
  #4084
martinwpb
martinwpb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ID:	1842998   Click image for larger version
ID:	1842999   Click image for larger version
Old 01-21-2013, 03:52 PM
  #4085
martinwpb
martinwpb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ID:	1843001   Click image for larger version
ID:	1843002   Click image for larger version
Old 01-21-2013, 03:55 PM
  #4086
martinwpb
martinwpb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One questions guys,
For some reason i have all the leading edge double for the elevator. 1/4 inch thick and 1/2inch thick.
Any idea whats going on here? E1, LE stabs, etc
Martin
Old 01-22-2013, 05:01 AM
  #4087
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have the same in my kit. eric said there were 2 ways of doing the build. if i remember, 1 with sheeting, one w/o
Bobt2 is offline
Old 01-22-2013, 05:12 AM
  #4088
Kellermann
Kellermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Martin, well done! Starting to look the part!
Old 01-22-2013, 09:57 AM
  #4089
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice tips, makes me want to copy them.
Bobt2 is offline
Old 01-23-2013, 06:30 AM
  #4090
martinwpb
martinwpb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Marcus,
Can someone verify that the height for the landing gear should be 10inch for a 33% decathlon.
Plans shows 6-1/4inch.
Martin
Old 01-23-2013, 09:06 AM
  #4091
Kellermann
Kellermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
6 1/4 seems pretty low to me, my calculations tell me about 8 inches would be right, added to 2 1/2 radius of a 5-inch-wheel gives 10 1/2 from the ground to the LG base plate.
Check the front view drawing and do your own math...
Marcus
Old 01-23-2013, 09:28 AM
  #4092
martinwpb
martinwpb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Marcus,
Just calculated again. I come to 8-8.5 from top of the landing gear to center of the wheel.
Old 01-23-2013, 10:26 AM
  #4093
Kellermann
Kellermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great, Martin
Old 01-23-2013, 03:54 PM
  #4094
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my gear is 8 1/2 high.i am confused on the wing center section on the 33 % plans and the kit itself from the plans. f13 and 14 are cut so that the inner w1 is about 5/8 in outboard of f15. should not w1 sit on top of f15 and that the outer w1 be placed an inch or so outboard of that. also f13/14 only go into the wing box 1/2 way into the spar box. sounds like a failure about to happen..
Bobt2 is offline
Old 01-23-2013, 04:37 PM
  #4095
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
whats that about what a picture is worth
Bobt2 is offline
Old 01-23-2013, 04:39 PM
  #4096
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
another
Bobt2 is offline
Old 01-24-2013, 07:58 AM
  #4097
ludfleet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Martin, I calculated 8.250" using a three view that I have, from axel to top of gear. I made mm gear from the plans but made the mounting tabs a little longer so it measures approx 7.000". With that I'll probably have to use a 3 bladed prop or make another gear.
ludfleet is offline
Old 01-24-2013, 08:00 AM
  #4098
ludfleet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob2, Did your gear ciome with the kit or where did you gert it?
ludfleet is offline
Old 01-24-2013, 08:53 AM
  #4099
Kellermann
Kellermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That would be the scale height of the landing gear.
Anything highr or lower will spoil the scale look of the model.
Old 01-24-2013, 09:01 AM
  #4100
martinwpb
martinwpb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Yeah gear should be around 8.25inch. I bought a 3blade 25x12 for my dle-111. Should give plenty of clearance with a 5inch tire.
I try to get graphtechrc to make me a Carbon fiber gear. Should be around 80dollars.
Does somebody have a mold for the canopy and is willing to make me one? I'm willing to pay for it.
Martin
Reply
Display Modes
