Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Hostetler 33% Decathlon
Reply
Old 01-24-2013, 09:06 AM
  #4101
Kellermann
Kellermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hostetler 33% Decathlon
Martin I´d be glad to send you one of mine, however the WH Design is out of scale and I doubt it would fit. WH is wider than normal...
Nevertheless, tell me the width of the top fuse and the width of the base of the windshield. Maybe with a few cuts you can make it fit.
The only real problem I see is the freight cost from Brazil to USA...
Marcus
Kellermann is offline
Old 01-24-2013, 09:17 AM
  #4102
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my gear came from fibertech and more, same as the glass parts
Bobt2 is offline
Old 01-24-2013, 09:21 AM
  #4103
martinwpb
martinwpb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Actually im looking for somebody with a mold for the 33%hostetler canopy.
Dont feel like making one if somebody has one.
Thank
martinwpb is offline
Old 01-24-2013, 09:53 AM
  #4104
Kellermann
Kellermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, I offered to pull off one of my 35% which perhaps would fit on the wider than normal 33%Hostettler design. Height would not be a problem, Just a matter of cutting off the bottm till fit.
Never mind. You´ll probably find someone closer to you anyway.
Old 01-24-2013, 10:06 AM
  #4105
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so, does anyone have a clue where my cabin top problem lies?
Bobt2 is offline
Old 01-24-2013, 02:22 PM
  #4106
tflyrc
tflyrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob: On my 30% version I saw the same problem you show w/ your W1. Easy fix is to mark w/ pencil where W1 sits now. Then take both F13 and F14 and continue the notch where it now steps up all the way to where it hits F15. This will allow you to slide an attitional W1 flush w/ the fuse. Then you just sheet between both W1s and you are done. I may have some pics of mine way back in this thread, but I'll enclose some here to give you a visual.
Tom
ID:	1843916   Click image for larger version
ID:	1843917   Click image for larger version
tflyrc is offline
Old 01-24-2013, 03:03 PM
  #4107
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
exactally what i was thinking, the lines are already drawn, but i wanted to hear it from someone else before turning the saw on. i also guess that the f13/14 only going 1/2 into the spar box will be fine.
Bobt2 is offline
Old 01-24-2013, 04:33 PM
  #4108
tflyrc
tflyrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guess you have to conclude the wing struts are critial, as are the flying wires on tail.
tflyrc is offline
Old 01-24-2013, 05:01 PM
  #4109
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
boy, i hope soooo! i will be putting it thru it's paces with scale aerobatics.powered by a da100.
Bobt2 is offline
Old 01-25-2013, 07:36 AM
  #4110
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
since i,m not going to be a scale purest with this bird, i think the simple way to retain the wings is to make the root ribs ply with eye hooks. that a few #64 rubber bands between them across the cabin roof will work fine to hold them in place.
Bobt2 is offline
Old 01-25-2013, 01:53 PM
  #4111
ludfleet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Bob, Not sure if I understand what your main concern is with the wing mounting?? Is it the inserts? I haven't heard of a failure with this design. If you go back in the posts a ways you'll find "big bird" Ken Spears, he has built this plane to the plans and put it through it's paces with no problem. Maybe you ought to contact him with your concerns. He is an excellent builder and probaby would give you some guidance. Joe
ludfleet is offline
Old 01-25-2013, 05:08 PM
  #4112
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea, those inserts in the root take up 1/2 the spar width. it has got to weaken it.out at the strut end you can at least put doublers inside the spar.
Bobt2 is offline
Old 01-26-2013, 06:02 AM
  #4113
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok, i went back and looked at the plan again.the inserts are in f13/14. not the spar,so the hole will be a lot smaller in the spar. still........
Bobt2 is offline
Old 01-26-2013, 11:21 AM
  #4114
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
all major building is now done. wings have been trial fitted to the fuse.wings need cap stripping and the struts fitted.
Bobt2 is offline
Old 01-26-2013, 12:11 PM
  #4115
Kellermann
Kellermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice Job, Bobt2!
Marcus
Old 01-27-2013, 10:42 AM
  #4116
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i,m also building a 1/3 balsa usa super cub. i have a spare set of those struts that are pre shaped bass. they are the exact same size as the decathlon. will save me hours of shapeing!
Bobt2 is offline
Old 01-27-2013, 01:37 PM
  #4117
ludfleet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Bob2, I finished my wings so long ago that couldn't remember much about them. But I was out in the shop today, got looking at my wings and the plans. On yours, did you fill between the spars with bass wood at the strut mounting bay? that would greatly strengthen that area. I almost missed that when building mine, there is a note on the drawing to that effect. Yours is looking good you've made fantastic progress considering your set back. You'll probably finish before me. Joe
ludfleet is offline
Old 01-27-2013, 03:19 PM
  #4118
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea, i filled in with 3 layers of scrap bass spar material front and rear
Bobt2 is offline
Old 01-28-2013, 09:11 AM
  #4119
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
buy the way, the room where the plane is had 4 1/2 ft of saltwater during sandy!
Bobt2 is offline
Old 01-29-2013, 05:41 PM
  #4120
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
whats slowing me up now it the tail blocks. theres enough blocks in the kit to build a boat, but what goes where is the puzzle.
Bobt2 is offline
Old 02-03-2013, 07:08 AM
  #4121
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does anyone have any good tail shots, either full size or the model.i,m not happy with the way mine is coming out. and the plans show blocks above the stab onto the fin. but the fullsize pics don't show that.
Bobt2 is offline
Old 02-03-2013, 09:29 AM
  #4122
tflyrc
tflyrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob: If the 33% drawings are like the 30%, the F-9 section view was incorrect on the drawing. There are no blocks on the 30%. The flying wires essentially hold the stab in place. As I had said earlier...they are functional flying wires. Enclosed is photo of the 30%. You can see that the stab is essentially free standing. You drap the fabic or other covering. The only blocks that I believe (remembering here) were shown were for cosmetics w/ helping to drap the covering. There may be some pics of Kens plan in the bones that show this same set up on the 30% early in the thread when he was just beginning to cover his plane.
ID:	1847533   Click image for larger version
tflyrc is offline
Old 02-03-2013, 09:37 AM
  #4123
tflyrc
tflyrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob: Check out the threads on Page 14. This shows Kens' 33% tail section. Hope this helps.
Tom
tflyrc is offline
Old 02-03-2013, 01:46 PM
  #4124
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes, i saw the pictures. but with the covering on, it wasn't clear what was under it. thanks all
Bobt2 is offline
Old 02-03-2013, 05:32 PM
  #4125
ludfleet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Bob2 and tflyrc, if the 33 and 30 drawings are different in that area where does the 30% get it's strength? the flying wires are not enough unless Hostetler has done something drastically different on that version. The flying wire would not do the trick on the 33%. the elevator rudder section seems pretty weak until you add the filler blocks. I scratch built mine so I just filled those areas in with scrap balsa and shaped it. I would guess that blocks from kit cutter that are not marked, would be a challenge to figure out. Be sure you put the blocks in they are needed. If you feel unsure call Wendell he's happy to help. Joe
ludfleet is offline
Reply
Display Modes
