top flite p-51 giant scale build
Yes, I too think this forum has ended or at least stalled completely
I'm in the way of finishing my TF p51 and I have a question about balancing this plane
from your experiences, will this plane need weight in the nose or in the tail??
I will put a DA50 on it, I know that this engine is some kind of lightweight
thank!!
I don't know if there will be too much nose weight
Roger
Nice looking Mustang; nice to see the RCAF markings; I am presently building the RTC Version; it will be an RCAF version as pictured; is your plane painted or Monokote, if it is painted, what did you use, I am glassing and painting mine and looking at different options.
Thanks, Doug.
I covered the Mustang with Monokote. A few people though I was crazy picking the P-51 as my first ever aircraftkit to build. Up untilnow,I have onlybuilt Schooners from scratch, of coursethe Bluenose is my favorite. You can see the bow sprint on my latest Bluenose sticking out from behind the TF Spitfire and Corsair kits waiting to be builtinthe photo I posted. I made a few minor mistakesbuilding the Mustang butmy previous31years in the airforce allowed for those mistakes to be corrected. I am really happy with the way it has turned out.
Whatengine have you selected to install in your Mustang?
Roger
Hi Guy's. I just discovered a big problem with my Robart 622's. I followed all Instructions to a ''T'', but something just doesn't look right. When I extend the gear and set it on my table, the gear is off and not 90 Degree to the table it sets on. Kind of looks like the gear on a M-109 where the Gear Legs tilt toward the Wing Tips and the Tires would run on the Inside of the treads. Now if I mount the gear to were the Strut sits straight on the Table as it should be, it probably will not lock in the up position, it will run out of space in the wheel well and hit the upper Skin of the Wing. What or where did I go wrong? Any help is appreciated.
Are you sure you actually have 622's? They should be 85 degree units and not 90 degree. Sounds like you have a 90 degree retract which results in the issue you describe because of the dihedral in the Mustang wing.
Hi Guy's. I just discovered a big problem with my Robart 622's. I followed all Instructions to a "T", but something just doesn't look right. When I extend the gear and set it on my table, the gear is off and not 90 Degree to the table it sets on. Kind of looks like the gear on a M-109 where the Gear Legs tilt toward the Wing Tips and the Tires would run on the Inside of the treads. Now if I mount the gear to were the Strut sits straight on the Table as it should be, it probably will not lock in the up position, it will run out of space in the wheel well and hit the upper Skin of the Wing. What or where did I go wrong? Any help is appreciated.
Roger
According to the shipping Box from Robart ( Tower) it is labeled 622-5 and I measure from on top of the rotating unit collar for clamping the strut to the Bottom of the axle nut ( 1/4x20) a total of 9 7/8'. I do believe it is the correct retract unit. I have not measured the exact angle of retraction yet to see which angle it is.
Roger
http://www.robart.com/retracts/drawings/622-5.pdf
Again, thanks for your answer.
Good day buches, things are going quite well here in the great white north. I also found a few short comings with the TF kit, but over all it’s notthat bad, in my opinion.One never getsto old to play with this hobby. As we get older we seem to strive for perfection in what ever we do to keep ourselves busyand we seemtoexpect perfectionin the products wepurchase, nothing wrong with that perspective. Don't worry; I have a feeling you will be pleasantly surprised how well your Mustang will turn out when finished. What color scheme will you be going with and what engine are you planningon usingin your P-51D?
Roger
Roger
Good day Buchtes, thanks for the compliments. I am really impressedhow well my covering job turned out. The flawed roll of Monokote I had did something strange when being applied. The adhesive seemed to separate form the color pigmentation which caused the area of the Monokote to look as if air bubbles had formed.The area in questionturned a darkcolor,I used a needle to puncture the Monokoe and tried to iron the bubble flat, it ironed flat but the darkcolor stayed. Thank goodness I only had 1/4 of the right side of the fuselagecovered at the time, re-sanding the area was a pain though, at least TF sent me a new roll. The canopy will not be moveable; I just used tape to hold it in place for the pictures. It looks as ifyou and I are keeping this thread going by bantering back and forth, which I think is a good thing. Take your time working on your son's gift, the Mustang should turn out to be a real treasure that will be cherished by him for a long time. Take care and have a good weekend.
Roger
