Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
top flite p-51 giant scale build
Reply
Old 06-03-2015, 09:02 PM
  #1601
go_hercules
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the replies about the battery. Now the question is: If I get a new 6V nicad, it will need a formation charge. BUT the only wall charger I have is a 4.8V 50mah wall wart. And the only smart charger is an Accu-Cycle Elite. The Accu-Cycle only does peak detection so is not good for the first forming charge. How the heck are you supposed to get around this? Is there some cheap adjustable constant current charger available for something like this? Maybe I'll ask in the battery section as well but figured you guys are more likely to use nicads.
go_hercules is offline
Old 07-26-2015, 03:29 PM
  #1602
iahawkflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is there a good way to convert a top flite D model ARC to a B model? I know there was a company making a fiberglass turtle deck conversion for the p-47. I am wondering if there is one for the p51.
iahawkflyer is offline
Old 07-26-2015, 08:14 PM
  #1603
spitfire66
spitfire66's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Leo Spychalla I know used to and probably still does. Its about $135 for everything you need. You will just have to look him up and email to see if it's still available. I too would love a B model.
spitfire66 is offline
Old 07-27-2015, 04:51 AM
  #1604
iahawkflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the reply Spitfire.
Old 07-27-2015, 08:35 AM
  #1605
sam2013june
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool p51d scale,all wood, i need parts,prints,the company that made the kit
i have a scale p51d kit, wing-span,65in. all wood, i was out of town working, my wife call trash man to clean garage,my shop,she tells him take this,take that. the box i under my work bench was took. my prints,my wood,conapy,tail section,cowling for the front.i have the fuseloged,most of the wing done,my linkage is in the fuselodge,also in robart air main algear in wing. my prints 4or5 sheets. i can not remeber the name of the kit. it suppost to i heard a collector kit. i do not know, it has pvc parts in the front,on the oil cooler it has two doors like the real one.they both work.all are pvc. otherwise everything is wood. i saw one done, at a show, in white planes, ny at the county center hobby show. i am really despart to fine the company that made the kit. thank-you.
sam2013june is offline
Old 08-12-2015, 12:19 AM
  #1606
piperjon
piperjon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gee I would call the guy back ask him dump the wife in the bin.
piperjon is offline
Old 08-12-2015, 06:23 AM
  #1607
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you post some pics of what you have there,, Top Fight makes a kit in that size but what you have sounds like it has more scale details,, maybe a Dave Platt kit?? ,, but we'd mostly be guessing with seeing what you have
scale only 4 me is offline
Old 12-24-2015, 04:16 PM
  #1608
rdperformance
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question if any body is still out there, does the c/L offset for the motor create the 3 degree right that is needed or do I have to now angle the motor to the fuse C/L, Or does the bulkhead have the offset builtin.
Thanks jets do not plat this game.
Rich
rdperformance is offline
Old 12-24-2015, 04:27 PM
  #1609
Tomcat_104
My Feedback: (42)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Every P-51 I've ever built had the 3 degrees built into the bulk head.
What are you building?
Pica 1/8, TF Gold, TF Giant Gold, CJM 1/5
Tomcat_104 is offline
Old 12-24-2015, 04:28 PM
  #1610
eric_monster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I recall, the offset was built in when following the plans.
eric_monster is offline
Old 12-24-2015, 05:42 PM
  #1611
rdperformance
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tomcat its a TF giant gold but the fuse and wings were built befoe I got it. putting a DLE 55 in and reading a build thread on hear I see the C/L offset of the engine. The problem is the I have the half cowl and the the top of the fuse over the engine is built and when I mount the engine offset it is no longer centered in the cowl where it meets the spinner base. I might be better off cutting that off an going with the fiberglass full cowl that available.
eric, I don't have the plans and found the manual but no plans on internet. I am not sure how this guy assembled the firewall.
Thanks Rich
Old 01-30-2016, 05:16 AM
  #1612
TampaRCGuy
My Feedback: (282)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All,
I just got in the TP P-40 Giant Scale ARF and DLE55RA motor,
I did not see this question posted anywhere in the thread. Has anyone made the Stab removable instead of gluing it to the fuse?
Looking inside from the inside end of the stab, there is some space between the sheeting and the tube socket that would need to be filled in with some hard balsa or ply. Then drill and tap through the bottom of the stab into the tube to secure the stab. All my IMAC giant scale planes have a similar setup except they are sheeted foam and not built up. it may require a bolt into each tube, front and back on each stab half.
Thoughts?
TampaRCGuy is offline
Old 01-30-2016, 09:41 AM
  #1613
Zeeb
My Feedback: (41)
Zeeb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by RC Accessory View Post
Hi All,
Thoughts?
Perhaps this question would be better asked in a P-40 thread instead of this P-51 Mustang thread?
Zeeb is offline
Old 01-30-2016, 05:37 PM
  #1614
FBaity
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
P-51 I thought............man RCU is screwed up with the new format..
FBaity is offline
Old 02-05-2016, 07:40 AM
  #1615
mljim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Need Direction
With wing sitting in wing saddle and center of wing on CL of fuselage there is approximately 3/4inch difference in the distance from the center of the aft end of the fuselage and the outer tips of the left and right aileron using the "string method" of measurement. Moving the CL of the leading edge of the wing corrects the difference, but really is not the answer for this large of difference. Suggestions please.
mljim is offline
Old 02-05-2016, 04:12 PM
  #1616
mljim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got it within 1/16 with careful measurement and establishing the true CL.
mljim is offline
Old 02-20-2017, 10:01 AM
  #1617
Rc_Dave37
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Dragonfly24
I have a question about the wing sheeting as you have done it and might be able to help. I have made one skin at this time and i test fitted it and it dont fit. am i suppose to cut the sheeting to fit? and why does it tell you to glue the sheets 1/4'' off?
Rc_Dave37 is offline
Old 02-20-2017, 10:05 AM
  #1618
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You must trim the sheeting to fit or else..???
Not a big deal. Just be careful that your wing doesn't develop a warp while sheeting. Make sure your wing is as it should be during that process.
BobH is offline
Old 02-20-2017, 10:21 AM
  #1619
Rc_Dave37
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi BobH
So i then have to trim the sheet so it will fit properly? Anyidea why the manual says to have an offset of 1/4" when edge gluing them?
Old 02-20-2017, 11:12 AM
  #1620
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave,
long time since I built the kit so I don't recall.. But yes trim the sheets so they fit as best as you can.
you'll need to do that for the tops and bottoms.
the GOOD thing about a wood kit is.. no matter what.. anything and everything can be fixed )
BobH is offline
Old 02-20-2017, 12:45 PM
  #1621
Rc_Dave37
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob
Thank you for your help. I do agree with being it is wood most everything can be fixed. i just want to make sure im doing this right. this is my first big build and im learning this as i go.
Old 05-11-2019, 09:48 AM
  #1622
ezugner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fuselage Drawings Needed
I am trying to complete a Top Flight Mustang (1/5 scale Gold Edition) that I purchased in 2001. I just realized that I have all the drawings except for the front half of the fuselage. I called the number on the front of the build manual (217-398-8970) to get a copy and they informed me that the drawings are no longer available.
Does anyone still have access to the drawings for this kit? If so, will you please let me know so I can get a copy, or the original?
Thanks for your help.
Eric
ezugner is offline
Old 05-11-2019, 11:13 AM
  #1623
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Eric,
I built this kit years ago. Let me say that the front of the TF kit is really messed up. I mean REALLY messed up. It no way resembles the full size plane at all.
I ended up redrawing the nose profile on the plans using a GOOD drawing. Ultimately I had to make a few new formers but that was easy.
Take a look at that approach and No I no longer have the kit drawings.
BobH is offline
Old 05-11-2019, 12:26 PM
  #1624
pilotdude57
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the Top Flite full giant scale P-51 kit, and I will take a look at it and see what I can find. My email address is pilotdude2@hotmail.com Tracy
pilotdude57 is offline
Old 05-12-2019, 04:57 AM
  #1625
Appowner
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Eric
Worse comes to worse you might try downloading the best Mustang plans you can find. Chad Veich IMHO has the best at 1/4 scale. But he charges for them so I can't give you a set of those. But you can find good sets out there. It won't be the TF plans but they will give the outlines and with the help of a good print service, you can get them sized right as well.
Appowner is offline
