Buiding the 33% Waco YMF-5 Barth Modellbau
#453
RE: Buiding pics Waco YMF-5 Barth Modellbau
Well I got the 1/5 scale download and took it to kinko's and had them enlarge it by 40 %. which gave me what I wanted. Now I have the plans and parts templates for a 30% Waco YMF-3 . I have many 1/3 scale plans and I can change the parts that need be stronger ... no problem. It has 100" wingspan, 12"dia cowl, I'm going to power it with my mvvs 116 , I'll do a full picture post for those of you that might be interested in the build. I was thinking of going to 1/3 scale as the one I read earlier in this thread that had the same engine. But I wanted not to be under powered because where I fly it usually is pretty windy and one needs the power at times. I've seen lots of great ideas reading the thread so far and hope it goes on.
Frequent Flyer
WACO brotherhood # 91
Frequent Flyer
#454
Hi Frequent Flyer,
nice to hear, that gou got your plans enlarged. I think, it´s not so easy, to built a model with an enlarged plan.
Especially in the case, from 1/5 or 1/6 to 30%. That´s a big jump, you have to measure every stringer etc.
The drawed lines are too thicker, I think, you have to measure in the middle of the line.
My next object will be an enlarged too, I ordered at Ziroli a plan of a F8F Bearcat in 90 inches wingspan, and will
blow it up to 113inches. But this is only a 25% jump, not like yours, a 40%!
But for a good modeler like you are, it will be not a problem.
The advantage is, when you get the plan additional on CD, you can print every part on paper,
glue it on plywood or balsa and cut it out, and this 1, 2, or 3 times, if nescecary.
The MVVS 116 is in my opinion a good choice for a 30% Waco, redcesar does fly it in his, and the videos are great.
Soon I´m ready with my Waco 33%, and it would be great, when this thread doesn´t die.
Bernie
Bernie
#455
Hey Bernie
It's good to here your coments.[8D] After seeing the vidio of the 1/3 WACO fly, and it was beautiful, I am thinking that maybe the 116 engine I have is ggod power for a 1/3 scale and I might go a little bit bigger. What do you think? It seems like the 1/3 size flies great! I was affraid that it might be under powered, but by the video , that does not seeem to be the case. Bigger is easier to see and in my case the bigger the better where I fly because of the wind. I did get all the templates which I also enlarged for the bulkheads and ribs etc. from the downloads. I know there are area to beef up and modify and that's what the hobby is all about. The thread has a wealth of info and without it I would be on my own. There has been alot of great ideas within the thread here and the ones under antique scale aircraft for the waco. I am thinking of going for the 1/3 now. I have the can mufflers ofr my engine and that should give some good power I'm hoping. Making all the molded parts might take a little effort but that's O.K. I love building. I guess I'm a liitle nuts. I have about 25 planes now and about 8 kits I haven't opened yet. I'm building a Zirolie AT-6 Texan and a Liberty Sport Bi-Plane that has an 8' wingspan.
Don aka Frequent Flyer
Waco Brotherhood #91
#456
Bernie
Could you lay out how you set up your 1/3 scale plane servos , recievers etc. ? Do you use a power commander, How many batteries? Do you use a regulator? Do you use a dual battery set up? I always like to see what the othe guy has had success with.
Thanks Don
Frequent Flyer
Thanks Don
Frequent Flyer
#457
Hi Don,
I use HT 5955 TG for elevator, rudder and for stab adjustment. Ailerons ar HS 645 MG on each (4pcs.) Throttle is too a HS 645 MG.
Additional I use the powerbox competition with 2 LiPo batteries 2800mAh each.
Transmitter will be the Futaba T 12 FG 2,4GHZ with the reciever 6014.
I hope, you know what it means, to built a plane in such a size only from an enlarged plan!
But I cross my fingers and wish you luck and constancy, to make it ready [sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif]
And it would be great, when you continue this thread, when I´m ready!
Regards
Bernie
Regards
Bernie
#458
Thanks Bernie , I have those servos and I just also bought the Futaba 12 channel 2.4 radio. Finally a radio that I do not have to worry about someone else turning on my frequency!!!!!Hal a lou ya! I lost two planes to such mishaps in the past 40 years. As soon as I reengineer my plan and get cutting I will post Pictures for you to see. I think your'e gona like it.
Does that 116 engine give plenty of power on your 1/3 scale plane? The Video looks like its doin fine. Great looking plane. I was looking at all the pictures you posted , did you build two different planes?
don
don
#459
Hi Don,
the Waco with the MVVS 116 is the Waco from redcesar, he started this thread.
Mine is the yellow with the RCS 250 and will make in 1-2 month the maiden, so I hope.
Ruud´s Waco with the MVVS is flying very well with this engine, it has some about 22kg weight,
Mine has 24,5 kg with full tanks (Gas, Smokeoil )
I´m still waiting for the radio, and I´m a bit afraid about the maiden, here we say: I have pudding in my knees
I´m very anxious for your first pics.
Bernie
Bernie
#461
Bernie
Thanks for clearing that up , I quess I got a little confused reading the thread and looking at all the build pictures. I love that RCS radial, my friend has one on his War Plane . It is very impressive and the sound is to die for. You will love it. You will probably find yourself starting it up just to here it when its raining outside,LOL
WACO Brotherhood 93
Don Carlson aka Frequent Flyer
WACO Brotherhood 93
#462
RE: Buiding the 33% Waco YMF-5 Barth Modellbau
Cesar
I guess I got you and Bernie's Planes mixed up and I asked him a question that should have been directed to you. Here it is, I am getting ready to build a waco with a 100" wing and I have the engine you have on your plane , the mvvs 116 ...... Do think that it has good power for your 1/3 scale WACO? It seems to fly great in the video I saw. Also that is a great looking plane!
Waco Brotherhood # 91
#463
Hi Don,
The power from the MVVS116 is more than enough for my Waco, you can see on the video that it is verry strong in vertical flight.
But it is all a matter of weight, my waco is about 19 KG and for good vertical performance is that important.
So try to keep your model so light as possible if you use the MVVS116.
Regards,
Ruud.
http://www.youtube.com/watch?v=g5GFpjCOXtI
http://www.youtube.com/watch?v=VEVcq11ZRNs
Regards,
Ruud.
#464
Just an observation. Seems like she wants to climb a lot. Like it needed more down thrust or more incidence on the stabilizer.
#465
ORIGINAL: Cybertom
The climb after takeof is steered by myself, the power in the MVVS is more than enough to do this.
For the rest is the Waco verry neutral in flight as well in normal or inverted flight. Also with various air speeds.
Regards,
Cesar.
#467
What did the "All Up" weight turn out to be? She really floats a lot like the full scale. Have you calculated the wing loading?
#468
ORIGINAL: Cybertom
The flying weight is 19 KG and the wing loading is aprox. 70 gr/ square dm.
Because of the light wing load you can make the landings with a litle bit practice very slow so you can land it almost on the spot.
#469
Hi guys together,
here again a little report of my work from the past two weeks:
The covering of the front cockpit is nearly ready, first sheet is 0,4mm plywood with a thin foam bolstering, over this comes a thin stretch fabric holded by the snap buttons.
Next step was, to hide the servo cables from the upper wing down to the fuse. For this I used the gas pipeline, it are thin 4mm alu-pipes and the cables fit in perfectly.
Also you can see a few details of the upper middlepart and a decal with my pilot name, and the buffles ar now in black.
Bernie
Bernie
#470
Nice scale details Bernie.
About the engine, have you already tested the Moki on a stand or are you do the initial running of the engine mounted in the fuse so as it is?
Ruud.
Ruud.
#471
Hi Ruud,
nice to see you, the engine is up to now a real "virgin". I only want to make a few minutes testing and than the rollout, to check all.
If than all is OK, I will try it.........cannot stand this imagine, my nervs will be very very down.......help!!!!!!!!!
Bernie
Bernie
#472
My Feedback: (16)
CA
ORIGINAL: BigBoy99
Hi Ruud,
Bernie
Hi Ruud,
Bernie
That being said the engine is just a perfect match for the Waco and runs very very well once you have it broken in. I recommend that you re-set the valves after about one hour of running it in. All the valve train parts will start to set in about that time.
Just a warning from a guy who learned the hard way.
Steve
#473
Does anyone have any contact info for Barth? I would like to purchase a cowling and wheel pants from them. Any help would be appreciated.
Thanks!!
Anthony
Thanks!!
Anthony
#474
My Feedback: (16)
CA
ORIGINAL: CubNut
Thanks!!
Anthony
Thanks!!
Anthony
The parts arne't cheap belive me.but either is the quailty of the parts.
