If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 12 of 23 FirstFirst ... 2101112131422 ... LastLast
Results 276 to 300 of 564
  1. #276
    Join Date
    Dec 2005
    Victoria, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Buiding pics Waco YMF-5 Barth Modellbau
    Is that a modification, or is that the way the kit builds?
    I have thought about getting this kit...
    Justin
    If you can\'\'\'\'t dazzle em with brilliance,baffle em with BS
  2. #277
    Join Date
    Dec 2006
    Berg/Ravensburg, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    @kochj
    that´s my own modification. But if You built the origin version, the stab is adjustable
    by a screw too, but not pretendable!
    @redcesar
    I´m anxious, how your baffles are working. I think, it depends too from the air temperature.
    I cross my fingers
    My second vacations start in september, we don´t travel to anywhere, and that means:
    building, building and building
    Regards
    Bernie
    Waco Brotherhood #63
  3. #278
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys,
    here again a little report of building my Waco. I would absolute have the belanced rudder, and I did cut it,
    you can see it on the first pic. At the next pic is the square tube to see, it´s integrated in the nose of the elevator.
    At the next is to see the cut out of the tail fairing, I had to be very careful, because I had only one try, if it fails,
    the part would be lost. But I had luck, all went good and it fit´s.
    At the last pic you can see the drive shaft of the elevator.
    Regards
    Bernie
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	731706   Click image for larger version.
ID:	731707   Click image for larger version.
ID:	731708   Click image for larger version.
ID:	731709   Click image for larger version.
  4. #279
    redcesar's Avatar
    Join Date
    Jul 2005
    Rotterdam, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice pictures Bernie I like your work on the Waco.
    Yesterday was the wether great so I take the Waco to the field. I am now become litle bit use to the plane.
    I put a litle video on YouTube.
    http://www.youtube.com/watch?v=VEVcq11ZRNs
    Regards,
    Cesar.
  5. #280
    Alexzzz's Avatar
    Join Date
    Sep 2004
    Bergen op Zoom, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That prop-sound[:-]
    Nive vid!
    Greetz.
    TX: T14MZ. Flying: Giant Scale 3D.
  6. #281
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wow,
    that´s great, I love this plane! Very good flight, the way she make the turns and the rolls[sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif]
    And the landing, very smooth, good done....compliment. That prop sounds really good!
    Very good video, I had to look it triple. I wish, my Waco would be ready just now!
    What about your cooling problem, does it still exist´s?
    I´m now busy with making the servo and stearing wires for the rudder and tail wheel. The tail wheel is driven directly from the servo,
    because when I remove the stab for transport, I must not mount and demount the wires for the tail wheel.
    But in the end of the fuse, there´s not a lot of space for the wires, I have to drill some wholes.
    In my mind is growing a plan, to make the rear cockpit including the windshield takeoutable, for better access to the RC Components.
    How are you thinkin about this?
    Regards
    Bernie
  7. #282
    redcesar's Avatar
    Join Date
    Jul 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BigBoy99
    Regards
    Bernie
    Hi Bernie,
    Take good care about the choice of strength of the two springs you got to use for the tailwheel dont take them to weak because with a litle side wind when you taxie the tail get out of course.
    The cooling problems are over but the aluminium baffles where no success they rip appart because of the vibration.
    I have now made two air guides fixed inside the cowl made of lexan that guides the air to the cillinders and that works oke to me.
    It is indeed a good idea to make the entrance to your RC better accessible, I have not done that and with my big hands through the cockpit pffff. I have learn now how to fix a ty-rap with one hand.
    I have placed my video also on photobucket and I think the quality is a litle bit better.
    http://s15.photobucket.com/albums/a3...acokort1-1.flv
    Cesar.
  8. #283
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ruud and others,
    my last work of the past week was to install the stearing for the rudder and the tail wheel.
    The tail wheel drive is direct from the servo, not from the rudder, because it´s easier to mount the
    pretendable stab, I must connect only the wires for the rudder. The first springs where too soft and
    I had to change them.
    The wires are 1,3mm cevlar and strong protected against abrasion. They have a breaking load of 111kg.
    The carbines are from the fisher shop with a breaking load of 40kg.
    The whole 4 lines I can set under tension with the one screw in the front of the servo-sledge.
    Now I can play guitar on this lines, so much they are under tension.
    See self:
    Regards
    Bernie
ID:	735667   Click image for larger version.
ID:	735668   Click image for larger version.
ID:	735669   Click image for larger version.
ID:	735670   Click image for larger version.
  9. #284
    redcesar's Avatar
    Join Date
    Jul 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi all,
    After about 12 flights I notice that the landing gear on my Waco is verry jumpy, If the landing is not 100% you get verry quick a jumpy landing. Maybe are my landing skills not so good but the airplane bounces up also as I put it on the ground so soft as possible I nottice that today after alot of landings.
    but I think that I can improve the suspension on the landing gear.
    Now it is only a spring that do the work which is I think not enough for a model with a weight of aprox 20 KG. The spring that came in the kit is I think much to strong and to short.
    So the first thing I do is put a longer and softer spring in the fuse.
    But I want also something with a shock absorber, Maybe a shock absorber that is used in 1/4 scale cars.
    Who can help me out and give me some idears.
    Regards,
    Cesar.
    Also I nitice that the suspension is not independently, if one wheel hit the ground the spring do not work.
    I think I am going to build two springs in the fuse.
  10. #285
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ruud,
    the first that come up to me is......your Waco is to light.......hahaha, it was a joke
    That was my first impression, when I saw this spring first time, it looks very strong. But if you want to make a longer and softer spring,
    you´ll expose, that the landing gear will be bent. The suspension way is than longer!
    The shock absorbers from the RC cars are in my opinion constructed, to absorb a push movement. in this case you only have a pull movement,
    but in this subjekt I´m not a specialist, that´s only my first mind.
    Best is, to contact Peter Barth, what to do.
    Did you cut out extra because of this the front lower fuse section? You can´t have enough control and service hatches at this plane,
    and I will regard it at my Waco.
    Best wishes for a good solution of your prob
    Bernie
  11. #286
    redcesar's Avatar
    Join Date
    Jul 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Bernie,
    The importend thing to me is that the suspension is not independently.
    I have got the Waco upside down on the ground and if I put down one wheel the only thing wat is happened is that where the endpoint of the axle is it will pull side ways in the wooden blok.
    I think I cut the wire in the middle and attach two springs to it and mount them in the fuse.
    Cesar.
  12. #287
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cesar,
    Century Jet, http://www.centuryjet.com/webstore/m...roduct_ID=1016 , has Landing Gear for the Gensis Waco in 1/3 scale, as you probably know, that operates in the same way the full size does (oleo struts). As they say "fantastic gear" with a fantastic price, about $800 US for the Mains and Tailwheel.
    Your plan with the two springs is much more economical and should not be hard to do. Looking good in the video.
    John F Howard (aka skylarkmk1)
    AMA 10955, WACO Brotherhood #26, AWC, NWC
  13. #288
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I mean, when you take this solution, you will have probs with the crossing of the two wires.
    What is, when you make the suspension outside of the fuse like this:
    Regards
    Bernie
  14. #289
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bernie, Cesar,
    If the 2 wires are staggered slightly, fore and aft, the scale look will still be retained when viewed from most angles.
    With spring in the middle of the inner strut, the scale look will be gone. The struts are pretty thin.
    The inner struts on the full size just pivot a little with the gear, while all the shock absorbing is done in the main struts, only 4" (10 cm) travel, not much.
ID:	738008   Click image for larger version.
ID:	738009   Click image for larger version.
ID:	738010   Click image for larger version.
  15. #290
    redcesar's Avatar
    Join Date
    Jul 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maybe not the most elegant solution but I have got the same in the Pitts "16,5 Kg" from Weiershauser and that works fine so i give it a try.
    I can adjust the tension in practice and the suspension is verry smooth and now independently!!
ID:	738087   Click image for larger version.
  16. #291
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think, your first suggestion is better, no, it looks better.
    My suggestion is, to make a block, alu or hard plastic, drill two holes in an angle of 45° cross with a distance of 2 mm one to the other
    and fix it with 2 screws in the fuse. But you can see it better in the drawing I made, see here:
    Regards
    Bernie
  17. #292
    redcesar's Avatar
    Join Date
    Jul 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bernie,
    You are right, if the solution works with the elastic rubber bands I wil change that in your design that looks indeed much better.
    I have got more things I want to change, nice work for the winter period.
    One thing I have to say, I have got now about 15 flights with the Waco and be more crazy about the Waco with every flight . If you fly with it you get a good feeling on the sticks.
    It is rather difficult to explain but it flies so solidly, yes for me the finest model I ever own.
    Regards,
    Cesar.
  18. #293
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh yes,
    I believe too, it was a good choice, the Waco.
    If your experience with the new suspension is good, I will make this changes too.
    When you take progressiv springs, the first way of suspension is soft, and then it gets harder. that protect´s your gear from bent.
    Bernie
  19. #294
    Join Date
    Nov 2002
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I built the quarter scale Barth Waco and am having some problems with it. Actually, I'm somewhat afraid to fly it for fear of wrecking it, and it's been sitting for two months. Anyway, I want to get it back in the air and need to do a couple of things to it first. I need to add some right thrust because it really wants to torque to the left on takeoff, plus there is a fair amount of right rudder trim. The wheel pants need to be attached better than I did initially. These items I can handle, but I have a question on how tight to make the flying wires. I switched to Kelvar from the steel wire that Peter provided because I was having a serious interference issue. It turned out to be the electronic ignition failing. The last time I flew the plane, both wires (Kelvar) used on the upper wing center section broke. I need to replace them but am wondering if I had over tightened them. I've considered replacing them with steel, but it is a real bear to do the way the plane is setup. Any advice would be appreciated.
    Chuck
    WACO Brother #233
  20. #295
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Chuck,
    to your prob with the flying wires I cannot say much, I´m still in the building phase. The Barth wires have a breaking load of 1,6kN I mean.
    I´m using cevlar wires for steering the rudder and it have 1,1kN , try stronger cevlar. I would not recommend to us them as fling-wires.
    Or change to a 2,4GHZ Radio, there you don´t have interferences.
    Torque to the side at take off could have more reasons, your springs of the tailwheel are too soft, side pulling of the engine is not enough, it should
    be 1,5° to the right. When you say, it torques to the left, you have to increase the side pulling, my opinion.
    Regards
    Bernie
  21. #296
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys,
    I hope you all had a beautiful weekend, I spend my time in the catacombs by my waco
    Now I made the cockpit to take out for better access to the RC components and other things.These own constructions costs a lot of time.
    My wife said, it looks like a bird house.... ......women
    The plywood of the deck covering is very thin, so I made a strengthening around the cutting edge.
    The cockpit will be saved by two screws, one in the instument panel and in the rear one under the headrest.
    here the pics:
    Regards
    Bernie
ID:	740696   Click image for larger version.
ID:	740697   Click image for larger version.
ID:	740698   Click image for larger version.
ID:	740699   Click image for larger version.
ID:	740701   Click image for larger version.
ID:	740702   Click image for larger version.
ID:	740703   Click image for larger version.
ID:	740704   Click image for larger version.
  22. #297
    ByLoudDesign's Avatar
    Join Date
    Sep 2005
    Mesa, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Beautiful work! I have learned a lot from your many photos. Thanks!
    Charlie
    Kits: F11C-2 1:4, Do-24T 1:8, P-3 1:10, H 500 1:5, XFY-1 1:4, SR-9 1:4, V-22 1:6, B-25J 1:4, F+W C3603 1:5, B314 1:11, Projects: 350i King Air 1:4, 156X Beaufighter 1:4, DHC-4 1:10, TBM 1:4 www.bylouddesign.com
  23. #298
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ruud,
    how is your progress with your landing gear?
    @ByLoudDesign
    Hi Charly, thanks for the flowers reading this, is like honey!
    Regards
    Bernie
  24. #299
    Join Date
    Sep 2005
    Mesa, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Too many people are not able to admit there are those that can really get the job done admirially! Fine craftmanship is a rewardable attribute! I hope I can glean enough from all the wonderful projects that are displayed here on RCU. I have taken my Goshawk back to the drawingboard a couple of time after seeing some of the work do.
    Charlie
  25. #300
    redcesar's Avatar
    Join Date
    Jul 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BigBoy99
    Hi Ruud,
    Hi Bernie,
    I am back from a short holiday in Austria "Nauders" and I have made not yet a test fight with the renewed landinggear. Maybe I test it this week if the wether is ok and I wil tell you the results.
    Your removeable cockpit looking good Bernie.
    Cesar.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
