If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 20 of 23 FirstFirst ... 101819202122 ... LastLast
Results 476 to 500 of 561
  1. #476
    Join Date
    Dec 2006
    Berg/Ravensburg, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Buiding pics Waco YMF-5 Barth Modellbau
    @SoCalSal
    Thanks Steve for your tips, now I can imagine, what a monster this engine is.
    I want to hold her with four cords, attached at the cabane struts and at the gear on both sides.
    So I have a 4 point attachment, think, that´s enough. I will lash her on the foot of my 3 meter garden sun-umbrella(150kg).
    One question I have, the adjustment of the two needles, L+H, I didn´t change it since delivery. I heard, before shipping they
    make a test run and you should not change these adjustments? Is that right?
    Bernie
    Waco Brotherhood #63
  2. #477
    Cybertom's Avatar
    Join Date
    Dec 2002
    Streetsboro, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is there and electric starter large enough to start a 215?
    Real airplanes have 2-wings and round engines!
  3. #478
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BigBoy99
    @SoCalSal
    Bernie
    Hi bernie, the adjustments on the needel valves will be just fine for the first start up of your new engine. You may have to change them later due to your weather conditions. But just remember these two points. Make sure engine is at the correct running temp. before changing them, and 2 the engine is very very sensitive to very small turns on the screws. It only takes a tiny bit of turning to get results.
    Have a great day Bernie.back to work on the Stearman for me now.
    P.S. Bernie I still recommend you have someone there with you when you start the engine.....what if the really bad situation happens and you need to get medical help quickly???? If it were not for my son being home the day I got hit by the prop I would have bleed to death before the medics got to me.it was that bad!!! my son saved my life by knowing how to control the bleeding till medical help arrived.
    Steve
    Let\'\'s be open minded.... But not so open that your brain falls out
    Waco Brotherhood #46
    QQ Python \"Miss Linney \"
  4. #479
    redcesar's Avatar
    Join Date
    Jul 2005
    Rotterdam, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Steve,
    I have seen the pictures of your injurys at home by Kris and I now wat you mean to be extra careful. That is with every engine but particularly with the strong moki.
    Ruud.
  5. #480
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ruud, yes Kris talked to me by telephone yesterday. He told me that he has shown those photos all over where you live. Hope it neve happens to anyone ever again. Besides it hurt!!!!!!!!!!!!! like all get out. In fact I was screaming like a little ***** all the way to the operating room. Hurt worse than when I got shot in Viet Nam many many moons ago.
  6. #481
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Puuuuhhhhh................
    lovely expectations, I promise, Ido my best.
    But there´s a little bit time (2-3 weeks) until than.
    Steve, how do you handle the choke, do you use him only to soak the gas to the carburator,
    or do you use him to start with ignition on?
    Bernie
  7. #482
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BigBoy99
    Bernie
    Bernie I use the choke like this..........close throttel, then close choke....flip prop through 3-5 times. Then open choke and use high trim on throttel servo then turn on ignition current and flip prop a few times. Make sure you have throttel open to a high idel as engine will not start cold on a low idel setting. After engine is warmed up for a couple of minutes it should start with just high idel setting. You should only need to use the choke when engine is cold like the first time you start it for a days flying ( might be different were it is colder) like Germany. Bernie remember to mount the prop in such a position that when you flip it it will be at a 1 oclock or 11 oclock position on a commpression stroke. You can use the cylinder in the vertical position for the referance point if you wish.
    .S. Keep choke closed at first when starting............the engine will fire then stop..............then open choke and high idel and it should start right up. Engine will idel good at 850-900 rpm after it is warm. I belive starting instuctions are included in the owners manuel.
    Steve
  8. #483
    WacoNut's Avatar
    Join Date
    Jan 2005
    Blanchester, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I received a reply from Proctor telling me I needed to order direct from Barth and they gave me a link to the Barth site and the site does not work. The front page loads and that is it, all the links on the site are broken and you cannot browse their site or get any contact info. Does anyone have any contact info for Barth?
    Thanks!!
    Anthony
    WACO Brother #30 Cub Brother #17
    It's not the hours you put in It's what you put into the hours.
  9. #484
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: CubNut
    Thanks!!
    Anthony
    Try this link http://www.fmbb.de/
    It worked for me. And it has a English version as well
    Steve
  10. #485
    WacoNut's Avatar
    Join Date
    Jan 2005
    Blanchester, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well it doesn't work for me,
    The Block at the top of the web page where all the links are appear as little blocks with red "X" in them, the links will not work for me. This is getting very frustrating trying to buy a cowling and wheel pants.
    Anthony
  11. #486
    WacoNut's Avatar
    Join Date
    Jan 2005
    Blanchester, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I received another e-mail from Proctor Enterprises giving me the e-mail address for Barth. I have sent them an e-mail requesting a phone # and also asking whether I can order a cowling and wheel pants directly frm them.
    Anthony
  12. #487
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: CubNut
    Anthony
    Do you have your pop up blocker activated on your computer? That is what happens if I have my pop up blocker activated( little red x's)
    Check and see if that is what is causing your problem if not let me know and I'll get Peters phone number for you.
    Peter is an engineer on the Euro Fighter project so he travels a lot in his job between Spain and Germany.
    P.S. here his his phone number off the web-site +49(0)80639482
  13. #488
    WacoNut's Avatar
    Join Date
    Jan 2005
    Blanchester, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am not sure what my issue is with the site, I turned off pop-up blocker and it still wouldn't work, I got on here at work without an issue. I think I see the Waco cowling in the price mlist but I am not totally sure since I cannot read German. I will try and call them on monday.
    Thanks!!
    Anthony
  14. #489
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Anthony,
    I´m sitting here in Germany, perhaps I can help you.
    Tell me what you want, and I will do my best
    Bernie
  15. #490
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BigBoy99
    Anthony,
    Bernie
    Bernie. he wants to order a cowl and the wheel pants and the strut covers on the landing gear. But he doesn't know the cost or how to order them.
    Steve
    Your going to like that Futuba radio Bernie............. REALLY LIKE IT!!
    Steve
  16. #491
    WacoNut's Avatar
    Join Date
    Jan 2005
    Blanchester, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the help,
    I have received an e-mail from Peter and we are making the arranagements to get my cowl and pants.
    Thanks Again!!
    Anthony
  17. #492
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: CubNut
    Thanks Again!!
    Anthony
    Anthony you are more than welcome. BTW I'm a member of the Waco Brotherhood myself I'm not sure of my number at this time.
    Tell the "Brothers" to forgive me but I'm building a big Stearman at this time. I still have my Barth Waco though.... It is just a beautiful bird and flys very well at 46 lbs. I plan on doing some improvements to it after I get the Stearman in the air. Things like providing more acess hatches to get to the hardware inside a bit eaiser and improving my landing gear pants.I keep cracking them on some landings so I want to cure that as well.
    Steve
  18. #493
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: SoCalSal
    Steve,
    I couldn´t wait until monday and I went to my model dealer and got it TODAY!!!!!!!!!!
    It´s a great radio, especially the short response time, it feels like directly steering, when you know, what I mean.
    BUT: there´s a big bug with my powerbox, the reciever 6014 FS has only a impuls voltage of 2,76V and that could
    be not enough for my powerbox, when she gets warm over 50°C. There was a warning notice today on the german
    website of robbe, thats the distributor of futaba here in germany.
    I hope, I can get help by the manufactor of my powerbox.
    That´s the first reciever of futaba, which is working with an impus voltage of 2,76V, all other recievers are working with 3,3V.[>:][>:][>:]
    Regards
    Bernie
  19. #494
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Steve,
    You are Brother #46. Anytime you forget, got to any page ending in 0 (zero) to find the Waco Brotherhood List. The later in the thread, the more current the list.
    John F Howard (aka skylarkmk1)
    AMA 10955, WACO Brotherhood #26, AWC, NWC
  20. #495
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BigBoy99
    ORIGINAL: SoCalSal
    Steve,
    Regards
    Bernie
    Bernie..what model powerbox are you useing??? I have one the 40-16 EVO I think it is. I have no idea about what you are talking about in regaurdes to the impuls voltage???????????? That stuff is way beyond may understanding. But I hope I can use my powerbox with it. How do I find out what my impulse voltage is on my reciver?? could it be different than the reciver used in Europe??
    Maybe we should contact Futuba support to see what they say.
    Steve
  21. #496
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: skylarkmk1
    Steve,
    Thanks for the info!!!
    #46 signing out for now
  22. #497
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Steve,
    only the reciever 6014 is working with 2,76 V impulse voltage. In your case with the 40/16 Evo powerbox there is the possibility,
    to make an alteration at Deutsch Modellbau, the manufactor of your powerbox. You have to ask your dealer!
    In my case with the 40/24 Competition I don´t know, what´s to do.
    These 2,76V could be not enough for the powerbox, when it get´s warm over 50°C, and ONLY than!
    I sent on friday an e-Mail to Deutsch Modellbau about this problem. I will report, when I get response.
    Bernie
  23. #498
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys,
    now I´m at a point after nine month building time, where I can say: SHE`S READY!
    What´s to do is the final installation of the RC components and make it´s coordination.
    Also the rollout and offcourse the maiden flight..................puuuuuuuuuuuuuh!
    But I MUST say it now and here: I LOVE THIS PLANE!
    See self:
    Bernie
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	881127   Click image for larger version.
ID:	881128   Click image for larger version.
ID:	881129   Click image for larger version.
ID:	881130   Click image for larger version.
ID:	881132   Click image for larger version.
ID:	881133   Click image for larger version.
  24. #499
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    and a few pic´s more:
ID:	881159   Click image for larger version.
ID:	881160   Click image for larger version.
ID:	881161   Click image for larger version.
ID:	881162   Click image for larger version.
ID:	881164   Click image for larger version.
  25. #500
    redcesar's Avatar
    Join Date
    Jul 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    gratuliere! Bernie.
    Es seht super aus, es ist ein atemberaubend modellflugzeug.
    I wish you all the luck with the coming maiden, take your time for it and control everything at least two times.
    Regards,
    Ruud.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
