If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 22 of 23 FirstFirst ... 1220212223 LastLast
Results 526 to 550 of 564
  1. #526
    Join Date
    Dec 2006
    Berg/Ravensburg, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Buiding pics Waco YMF-5 Barth Modellbau
    Hi Evert,
    Congratulation to this very fine plane....it has a very good builder [sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif]
    The bouncing by landing the model is very characteristic, mostly every pilot of the YMF-5 had made this experience.....me too
    The trick is, give just in the moment when the wheels touch the ground a little bit down with the elevator.
    The tail of this plane is heavy, and want just in this moment move downward, the working angle will increase and the plane
    lift's off again, but too slow, and it will stall. The tick down with the elevator hinders it very effectly.
    Always happy Landings with your Waco
    Bernie
    Waco Brotherhood #63
  2. #527
    Join Date
    Jul 2003
    Meise, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    last weekend at the yearly show at Tisselt, two Waco's flew together...
    http://www.youtube.com/watch?v=omElN_HucN0
  3. #528
    Join Date
    Feb 2003
    Venice, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I know it's been a while since anyone's been on this thread, but perhaps someone can help. I've been wanting to buy the Peter Barth 1/4 scale Waco. I emailed Peter and he informed me he did have a 1/4 scale kit he could ship to Proctor for my purchase. However he indicated the pre-bent landing gear wires and the cabane struts would not be soldered and I would have to solder them myself. I have soldered landing gears and cabanes before on other kits, wrapping the joints with thin copper wire and then silver-soldering them. However on those kits you usually had instructions to build a jig or other means to insure accuracy. To you who have had experience in building the Barth Waco, do you think there's enough information given with the kit to do an accurate job of this soldering?
    Mike L.
    WACO Brotherhood # 121
  4. #529
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi, The gear wire will be pre-bent to shape I think. All you would need to do is mount them tho the fuse and bring them togeather at the correct position and wrap with copper or steel wire and the use a silver solder of at least 50% silver content. You can get this type of solder at any welders supply store. Make sure you get a good flux paste with it. And use a propane torch to heat parts...a electric solder iron will never get the metal hot enough to melt that type of solder.
    Other than that I think you will have no problem with Barth's gear or kits. Peter's blue prints are usually very good and all aspects of construction can be done from them alone. I built his 33% kit and the "instruction" booklet that came with the kit was of a very bare minimum type. I know for a fact that Peter has updated his kits since I built mine and they are even a better value than before. The fiberglass parts are just beautiful and very detailed in the updated kits. I even ordered a new cowl from him because of the fantastic detail he has molded into the "new" cowls compared to my "old style" cowl. I also know he has improved the rib detail a lot compared to the old style. I enjoyed building this plane and both fly just perfect. And besides there is no more beautiful bi-plane built than the Wacos.
    Go ahead and get the kit now as it will take about 5-6 weeks minum to get the kit from Germany to the west coast. Peter ships the kits via sea transport so if you wait you may have to wait till he has more kits to send. You will enjoy building this kit and have a plane that turns heads where ever you go. And I asure you, NO ARF will even come close to your own Barth Waco. NEVER!!! This is a model to be proud of and to me 90% of the enjoyment was building the thing.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1085141   Click image for larger version.
    Attached Images Attached Images
    Let\'\'s be open minded.... But not so open that your brain falls out
    Waco Brotherhood #46
    QQ Python \"Miss Linney \"
  5. #530
    Join Date
    Feb 2003
    Venice, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the feed-back SoCalSal. Silver soldering I'm quite familiar with and have all the supplies, and you're quite correct, you would use a torch on those wires. Chuck L built the 1/4 scale and sent me his construction photos. Like you said, it looks like you would just mount the wires to the fuse, get them lined up properly, and solder them. After looking at the photos it doesn't look like doing an accurate soldering job will be that difficult. You certainly have a beautiful Waco. Thanks again.
    Mike L.
  6. #531
    Join Date
    Jul 2003
    Meise, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Waco has a new engine under the hood.
    [youtube]http://www.youtube.com/watch?v=F6U_aicqM04[/youtube]
  7. #532
    Join Date
    Mar 2005
    spring valley , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Very very nice. !!!!! Great fun this one is. Nice flying!!
  8. #533
    Aero104's Avatar
    Join Date
    Oct 2002
    Nashville, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am looking for 1/3 scale Barth Waco plans only.
    Anybody want to part with a set or copy?
    Chris
  9. #534
    Join Date
    Sep 2005
    Chapel Hill, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    http://www.vogelsang-aeroscale.com
  10. #535
    Join Date
    Jan 2009
    cape canaveral, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BigBoy99
    Hi community,
    after a few days pause I made the installation of the landing lights. I used the Seoul Z-LED P4 from Lumitromix in germany.
    What shell I say.....It hurts like hell, to look there in, I have now just an our later a little flicker in my eyes, but they are sucking a lot of
    energy, 1000 mA at 3,8V and donΒ΄t get hot after 3 minutes. The outer contour of the cover I have to cut to the final form, itΒ΄s only a makeshift
    The camera can not give it in real, because she regulates down.
    bigboy99,
    in reviewing these aids in building a waco could you please tell me what size barth kit you installed these lights in. i'm working on the 1/4 scale kit and would like to install them, your help will be greatly appreciated.
    thanks,
    chris melhus ceije brotherhood #196
    Bernie
    "Sometimes you have to build it a little wrong in order for it to be wright." -DAVE PLATT-
  11. #536
    Join Date
    Oct 2006
    Lutz, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I've finally put some time on the board with my Barth 1/3 Scale WACO. Except for my nearly non-existant german reading and writing skills the project is moving. Tonight I discovered that the GFK Main Gear Fairings and foward fuselage fairing (gear to fuse) are missing from my kit. Hopefully Steven and or Goetz at Volgelsang will be able to remedy this missing parts quickly as it is time to fit them.
    Jim
ID:	1658774   Click image for larger version.
ID:	1658775   Click image for larger version.
  12. #537
    Join Date
    Oct 2006
    Lutz, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am just in week 2 of my Barth 1/3 build. I am using the MOKI 250. How far back and what size fuel/smoke tanks did you install. I am using an electric fuel pump so distance should not pose a problem. I am hoping that with proper placement of the fuel/smoke system and batteries I can avoid needing additional "dead weight"
  13. #538
    Join Date
    Nov 2002
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I bought a semi-built 1/3 scale Barth Waco kit yesterday, the fuselage is about 60%. The manual that came with the kit is a decent English translation, but only covers the fuselage and the start of the tail feathers. Vogelsang sent me a pdf file of the manual, although it is complete, it is a broken English translation that is hard to follow. Apparently Peter lost the decent English translation version. Does any one have a copy of the decent English translation of the manual or know where I can get one? The kit is a year old and is his current design.
    Chuck
    WACO Brother #233
  14. #539
    Join Date
    Aug 2002
    Batavia, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I wish I had one. I'm trying to build now with the 'broken translation. Would welcome anything available.
    Thanks.
  15. #540
    Join Date
    Nov 2012
    Firenze, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am near to buy my One Waco.
    Please someone can kindly send to me the PDF of instruction?
    claudio
  16. #541
    Join Date
    Aug 2002
    Batavia, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    http://www.ua9.de/Modellflug-Seiten/firmen.de.html Here's a list of German model suppliers. Barth is listed on it. If you send me a PM, I think I have a PDF Instruction book.I can attach to an email.
    Mike Hopkins
    Waco Brotherhood #132
  17. #542
    Join Date
    Nov 2002
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Claudio,
    Attached is a manual of the third scale Barth Waco. Ignore my PM unless you need more information.
    Chuck
    Attached Files Attached Files
    WACO Brother #233
  18. #543
    Join Date
    Nov 2012
    Firenze, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you very much!!!!
    Claudio
  19. #544
    codiddley's Avatar
    Join Date
    Dec 2003
    Firestone, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the great build thread!
    Since I'm lacking the wad needed to be competitive in IMAC I decided I might as well go scale! Waco Brotherhood #129
  20. #545
    Join Date
    Nov 2012
    Firenze, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am very near to buy...
    Only a little doubt..
    scale 1/3 or 1/4 one?
    Claudio
  21. #546
    Join Date
    Nov 2002
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Claudio
    Go big, go big, go big!!! Do the third scale Barth.
    Chuck
    WACO Brother #233
  22. #547
    Join Date
    Nov 2012
    Firenze, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Chuck
    I probably find a 260 radial evolution too...
    Yes it is not a Moki one but I think it is not so bad like engine...
    Claudio
  23. #548
    David DeWitt's Avatar
    Join Date
    Aug 2002
    Lakeland, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by scatolina View Post
    Claudio
    Just finished a 1/4 scale, nice size and easier to transport.
  24. #549
    Join Date
    Nov 2012
    Firenze, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by David DeWitt View Post
    Thanks David.
    Please what engine did you use?
    ciao
    Claudio
  25. #550
    codiddley's Avatar
    Join Date
    Dec 2003
    Firestone, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice waco! You guys have me green with envy! Hopefully not for too much longer...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
