If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 62 of 72 FirstFirst ... 12526061626364 ... LastLast
Results 1,526 to 1,550 of 1787
  1. #1526
    Join Date
    Nov 2009
    Eganville, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RC Guys Super Decathlon coming
    Hey Igot some pics to load up.
    Dan if your watching this thread you can use these pics on your website.....hint hint
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1748804   Click image for larger version.
ID:	1748805   Click image for larger version.
ID:	1748806   Click image for larger version.
  2. #1527
    Join Date
    Dec 2001
    Tullahoma, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks. I have the BH L4 and I just started checking out mounting my engine and like to know if I'm going to run into something. So far it looks as good or better than any ARF I have ever seen. Brian
    ORIGINAL: joebob
    There is a thread on the plane over on the giants site that talks about it. I don't know if it has been fixed or not. Apparently the placement of the servo interferes with the struts somewhat. I don't remember, but it might just be if you want to fold the struts up for storage. The guy that identified the problem simply moved the horn location in the aileron over and flipped the servo around. Definitely not a huge deal. The only reason I mentioned it was that I had been doing so much reading and really didn't remember which planes had which problems.
    I certainly didn't mean to imply that there are major problems with the BH planes. As far as I know, they're top notch. I think the quality probably is a cut above the RC Guys. They're really in a different class.
    Brian P. Smith Bismith2@hotmail.com
    AMA 1044 IMAA 21141 W4BPS <><
  3. #1528
    joebob's Avatar
    Join Date
    Aug 2002
    Crestview, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, I'm not going to make this weekend. Ordered the engine and prop from WrongwayRC on Sunday night. WW was great and got both sent out Monday via Priority mail, but he had to use separate boxes. The prop got here yesterday, but the engine is still not here. Got a note saying they tried to deliver today but no one was home. Don't know why they didn't just leave it on the poarch like they always do. Anyway, I have to wait til tomorrow for redelivery and there's no way to get the engine mounted and cowl fitted before Saturday. Plus, I screwed up and drilled out my spinner and prop too large. It was my fault, but I have an excuse. I ordered a GP precision metric prop reamer from Tower that said it had 3 step sizes: 7, 8, and 10mm. Since the shaft size of the JC30 is 10mm, I just chucked the reamer in the drill press and reamed everything out to the largest size. Didn't realize until I tried to fit the prop on my drill guide that the hole was way too big. Apparently, they substituted a newer reamer with *4* step sizes, of 7,8,10,and 12mm. So now I'm having to find a bushing that will fit the shaft and prop hole. Had a guy offer to make me one so I'm going that route for now.
    It's always something.
    Joe Andrews
  4. #1529
    joebob's Avatar
    Join Date
    Aug 2002
    Crestview, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finally got everything mounted and ready to go. The JC-30 was a little bit of a chore to install, not because it was too big, but too small! The standoff-prop hub distance on this engine is only about 5.5", so I had to find some 1" extensions for the standoffs to get the hub out far enough to clear the cowl. I decided to use the stock muffler since it looked like it would fit neatly inside the cowl with only the exhaust tube sticking out the bottom. After cutting the hole for the tube I realized that the muffler also hit the front of the cowl, so I had to carve out a clearance hole for it, too. [] Oh well, it still doesn't look bad.
    Got out Friday and tried to run the engine. Took FOREVER to get it to draw fuel. But I expected that as it is common with a dry carb. Finally shot some gas in the carb and got it to start pumping, but still couldn't get it to pop. After about 30 minutes of flipping, checking spark, resetting needles, shooting gas in the carb, checking for flooding, etc, I gave up and used a starter on it. Got it cranked and adjusted the needles so it would stay running and I could hand start it. Top end was around 7500 with the JC 18x8 and idle around 1700. Not too bad. So now the only thing left to do is make sure everything is Loctited, remount the door (don't ask how it got knocked off), and she will be ready for maiden. Shooting for ths weekend.
    Joe Andrews
  5. #1530
    joebob's Avatar
    Join Date
    Aug 2002
    Crestview, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maiden day!
    Perfect weather for a maiden. No wind, no clouds, temps in the high 70s-low 80s Had a little trouble with assembly due to me not knowing the best sequence. I realized that the left wing should go on first because it is much easier to reach the wing bolts that way! The JC-30 didn't want to fire right off, but with the help of a starter it roared to life. Running very nice. Subsequent starts were accomplished easily by hand. It was idling at 1600 and top end hit 7800 cold. With all preflight checks done, nothing left to do but fly. She tracked straight down the runway and lifted off in just a few feet. The JC-30 pulls it perfect. However, something wasn't right.
    She required a LOT of left aileron and left rudder to fly level. Not sure what the problem is yet. I didn't put an incidence meter on it before flying, but it sure seems like there's a twist in the wings. I will check it tonight when I get the chance. I suspect the struts are misaligned pulling the wings out of whack.
    Roll rate was SLOW to me, but it may be because I've been flying 3D birds for the last 7 years. I dialed them up as much as I could and it helped a little, but was still pretty slow. Elevator, however, had plenty of authority. And I can tell I will need to practice mor ewith coordinated rudder turns or add some aileron-rudder mix.
    All in all, I'm fairly satisfied with it, as long as I can get the trim straightened out. Flew a total of three times and brought it back in the same number of pieces I started with, so that's good!
    Joe Andrews
  6. #1531
    Join Date
    Nov 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Congrats Joe!
    Mine had a bit of bank one way to the first time I flew. I just trimmed it out and thats it. Your probly finding the roll rate slow because of flying 3d planes. I know the manual calls for some aileron differential but I took mine out. The full scale Decathlon doesn't use any differential so I said the heck with it and it rolls pretty nice now.
  7. #1532
    joebob's Avatar
    Join Date
    Aug 2002
    Crestview, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If it was just a few clicks I wouldn't worry about it but the ailerons and ruddder are almost 1/4" off center, so something is amiss. Just tried my incidence meter but it isn't wide enough to fit the wing so I'm going to have to borrow one or get a longer bar.
    I tried the differential, also, but didn't like it either. It seemed to roll better without it.
    Joe Andrews
  8. #1533
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi
    anyone think the da 60 cc gas engine is too much for this bird?
    AMA # 982277
    Carden Extra 300 Pro, almost done building it (DA 200 with KS cans)
    Carden Extra 300 Pro, in the works (DA 150 with KS 1090 tuned pipes)
    Dalton Extra 300 SP, finished and crashed, RIP
    Dalton Extra 300 ML, DA 200
    Dalton Yak 54, DA 200
    Great Planes Matt Chapman Eagle Cap DA 120
    Top Flite Gold Edition Giant P51 DA 85 (in the making!!)
    Extreme Flight YAK 54 91" DA 70
    Extreme Flight Extra 300 91" DA 85
    Extreme FLight Extra 300 78" DA35
    JETI is the only way!!!!
  9. #1534
    Join Date
    Nov 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WAYTOOMUCH.....LOL Ithink a 40cc is a big engine for this plane. There is a couple guys using DA-50's and DLE-55's in them. is get unlimited vertical with them. Ithink the DA-60 would rattle it to death.
    ORIGINAL: orthobird
    hi
  10. #1535
    outacontrol41's Avatar
    Join Date
    Nov 2004
    Girdletree, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bradleyban
    WAYΒ*TOOΒ*MUCH.....LOL IΒ*think a 40cc is a big engine for this plane. There is a couple guys using DA-50's and DLE-55's in them. is get unlimited vertical with them. IΒ*think the DA-60 would rattle it to death.
    ORIGINAL: orthobird
    hi
    I agree. I've got a DLE 55 in mine but I would definately not go bigger at all...I'm at my limit. Ideally a G38 would work great.
  11. #1536
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ouch,
    oops
    i ordered the plane and the engine
    should arrive this week.
    well, it will be interesting to see what happens.
    i compared to dle 55.
    DLE 55 weighs 1550 grams
    DA 60 weighs 1517 grams
    DLE 55 HPis 5.5
    Da 60 HPis 6.0
    the mounting area for DA 60 is slightly smaller than for the dle 55
    quite comparable i believe.
    the reason i went big is because the last sup decath i had, the dynaflite, had a 4 cycle fg 36 saito, and the plane weighed in at 19 pounds or so, and it was way underpowered. i know this bird is slightly bigger than the dynaflite.
    i guess will keep you al posted on how it turns out.
    AMA # 982277
  12. #1537
    Join Date
    Nov 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ithink this plane is considerably lightly than the Dynaflight. Ifly mine with an FG-36 and it has lots of power. No 3Dmachine but it will pull straight vertical for at least 500 feet before it semi hangs on the prop and starts slowy falling back down. Lots of wing on this plane
    If your going DA-60 Istrongly recomend a 3 blade prop for it. Idon't think you will have much clearance for a two blade. Them 60's swing a big prop
    ORIGINAL: orthobird
    ouch,
    oops
    DLE 55 HPis 5.5
    Da 60 HPis 6.0
  13. #1538
    Join Date
    Aug 2011
    Kernersville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for all the good information on the Decathlon.
    I am one of those people waiting for the new order to ship 6/15 or 6/18. Packaging problem not RC Guys problem.
    I am going to take a different route as I live in an apartment right now and gas is out.
    I purchased the Hobbyking G160 motor.I have run it on a test stand and it wants to pull the stand apart. The power is unbelievable. I an a G46 from them in a Decathlon 40, think I like the plane. The G160 will run on 2 5000mah 5 cells in a series. I ran run it with a 19/12 and a 20/8. I am getting allmost 2750 watts of power out of it. Will give the DlE 30 a run .
    When guys like you do the great job you did spelling out a few things that need to be watched or repaired it makes the job for us coming after you much easier.
    I have one question on the Doculam covering if I spelled it right, I can over find it in rolls of over 500 feet. Is there any other source where we can get a role like our cover material size?
    Again than you all for the good info.
    I will post pictures of my electric as I start to build it and will update on any improvements or changes RC Guys has made.
    I just think it is one heck of a plane for the money.
  14. #1539
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    engine and plane arrived, pics to follow on build.
    has anyone installed the rudder servo in rear near to tail?
    AMA # 982277
  15. #1540
    Join Date
    Dec 2001
    Tullahoma, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Watching.......... . I may want one. Brian
    ORIGINAL: orthobird
  16. #1541
    Join Date
    Jan 2007
    Urbana, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had to throw as much weight as possible forward.
    Left mine in standard position.
    Good luck.
  17. #1542
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi
    how much does your engine weigh
    what engine are you using on it.
    my engine weighs 3 pounds
    this does not include electronic ignition, battery, and muffler though?
    AMA # 982277
  18. #1543
    Join Date
    Sep 2006
    Weed, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looking for prop selection help. Just ordered one from Dan. I will be using Saito 220 on it. Fun flyer is what I am mainly. Loops rolls and basics. I usually run W series APC 2 blade props or 3 blade style props on my Saito 100 on my U Can Do. Would like some recommendations on props needed in both 2 and 3 blade if possible for the Decathlon. Elevation is around 2800 feet normally but air density does change. Anywhere from 1800 up to 4200 corrected altitude with weather.
    Thanks for the help
    Quickdraw Tech.
  19. #1544
    Join Date
    Nov 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: quickdraw
    Thanks for the help
    Im using a Xoar carbon 18 x 8 on my FG-36. Your 220 is the same motor but glow. Ibelieve the glow is slightly more powerfull. Should be able to use a 19 x 8 - 20 x 8 no problem. The xoar carbon have a very light load and spool up quick
  20. #1545
    Join Date
    Nov 2010
    Madisonville, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Did you use a Pitts style muffler or the stock muffler that comes with the DLE55?
  21. #1546
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    airplane is almost finished.
    it has a da 60 cc engine
    Jr tansmitter
    Jr receiver
    rototank 24 ounces
    weighs 17 pounds and 1 ounce
    3 blade prop 21 x 10 biella
    just turned engine on
    got 6300 rpm with throttle WO
    measured 25 pounds of thrust.
    any thoughts?
    will it fly consistent, or will it be wild??
    should i fly at only 1/2 throttle??
    AMA # 982277
  22. #1547
    Join Date
    Nov 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: orthobird
    Jr tansmitter
    Jr receiver
    rototank 24 ounces
    any thoughts?
    Ithink she will be wild at wide open but hey you don't have to fly wide open all thge time right.
    Try to get a video of that thing flying Iwanna see it go with a 60 on it
  23. #1548
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    AMA # 982277
  24. #1549
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    AMA # 982277
  25. #1550
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    does the airplane have to fly with the wing struts?
    AMA # 982277
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
