If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 7 of 72 FirstFirst ... 567891757 ... LastLast
Results 151 to 175 of 1787
  1. #151
    Join Date
    Jan 2006
    Lexington, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RC Guys Super Decathlon coming
    Need some advice here, guys. I'm getting ready to order a spinner, and need to have a pretty good idea about prop size. I'm using an OS 1.60 2-stroke for power. First time for something that size and am wondering what you'd recommend for a prop....
    Al
    MobyAl
  2. #152
    Moderator SunShyne's Avatar
    Join Date
    Dec 2002
    Centreville, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mobyal
    Al
    depends what you want to do with it. If it were me id go with the 18-8 or somewhere in that size. Spinner in the 3.5" class size should be fine.
    Revver Bro #86
    Visit RCU\'\'s E-flight Only Website: www.WattFlyer.com
  3. #153
    mrbigg's Avatar
    Join Date
    Oct 2004
    Streator, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: DiabloKid
    ORIGINAL: mobyal
    Al
    depends what you want to do with it. If it were me id go with the 18-8 or somewhere in that size. Spinner in the 3.5" class size should fine.
    I second that.
    Smooth, like Keith Stone.
  4. #154
    Join Date
    Jan 2006
    Lexington, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mrbigg
    ORIGINAL: DiabloKid
    ORIGINAL: mobyal
    Al
    I second that.
    Thanks you all...
    I was thinking about an 18/8, and if I get one cut for that, I can always go down a little.
    Al
    MobyAl
  5. #155
    Join Date
    Feb 2002
    Jacksonville Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Decathlon aficionados,
    I am still waiting on someone to report on flying the RC-Guys Decathlon as I need to know if I can hang a Zenoah G45 on the nose.
    I am sending my Zenoah G45 to Brillelli Engines for a weight reduction tummy tuck...!!
    It currently weights 5.4 Lbs in the full stock configuration...see photos without the CH Ign KIT
    I am expecting it to be around 4 Lbs when it comes back......Is that possible?? I need it for my Decathlon..!
    What Xoar prop is best for this motor..?
    Martin
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Attached Images Attached Images
  6. #156
    Join Date
    Jan 2006
    Mead, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the fuji 43 hanging on mine. Don't see why G45 wouldn't fit also.
    Longmont Aircraft Modelers Association
    Longmont, CO visit our site at www.lamarcclub.com
  7. #157
    Join Date
    Oct 2002
    Chapel Hill, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It sounds like maybe I wont get this plane now. Seems it's a big glow motor plane. I have a DA50 just begging to be used, but sounds like this is too much weight/motor for this plane. Even though I am not trying to 3D the thing, I just need somewhere to put the motor...
    Where there is confusion, there is profit.
    AMA # 403098
  8. #158
    Join Date
    Feb 2005
    simi valley, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Why not the Da50, little over 3lbs with mufflers that's not to much. reinforce the firewall, cut new spacers to fit cowl ( the DA is a little long with stock spacers) and use some throttle management. The G38 is way heaver then the DA and a G62 is a boat Anchor, my RCGuys Decathlon will be at my door by Tuesday and the DA50 will be pulling it with authority when needed for aerobatics and at quarter throttle for a slow Sunday flight.
  9. #159
    Join Date
    Oct 2002
    Chapel Hill, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think I will use the DA 50 after all. I got an email back from RC Guys today! They said just beef up the firewall and it should be fine. I hear the cowl will be friendly to our big single's as far as hiding it in there for that scale look...
    AMA # 403098
  10. #160
    mrbigg's Avatar
    Join Date
    Oct 2004
    Streator, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bonnie
    I wouldn't want to hear the DA's midrange burble at cruising speed. Unless your lucky and have it tuned out.
  11. #161
    Join Date
    Oct 2002
    Chapel Hill, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have learned to tune out the burble... mentally that is... It's 5 times the motor that a G-62 is. I think it would be a great motor for this plane.
    AMA # 403098
  12. #162
    Join Date
    Jan 2007
    Urbana, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi all.
    Update from the build.
    Main gear assembly..have a good 5/32nd 10" long hex or good 1/4" socket set with tip (magnetic really helps).
    Tail wheel assembly..screws provided are junk. Powder coating closes hole, pre-drill w/ 7/64 (I think).
    Wheels..glad I sprung for Dubro per prior post..ones provided are throw-away.
    Assembly order..I'm piecing together as I see fit. Wanted to get main gear (sans wheels and pants) on ASAP for stablility on the bench.
    Engine..mounting instruct. given are pretty sketchy (I have only 4 ARF's in my history).. will proceed with MUCH CAUTION.
    Saito 180 on the bench..gets minimum gallon test run for smoothing and leaning.
    Later
    Scott
  13. #163
    Join Date
    Oct 2002
    Chapel Hill, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    sdossett , what motor are you gonna run?
    AMA # 403098
  14. #164
    Join Date
    Jan 2007
    Urbana, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Saito 180
    Dan (I think) at RC Guys likes the 200 OS I guess..... the 180 is well in range, will fit a 120 chassis in the future and my goal is to get everything in the cowl and scale aerobatics... not prop hanging
    Peace
  15. #165
    Join Date
    Oct 2002
    Chapel Hill, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maybe I am way off base, and truthfully, I have not seen this plane in real life. It has all of the specs of a 50cc plane. Wing loading, wingspan, fuse size and all of this glow motor talk seems grossly underpowered... Like putting an OS .46 AX in a 1.20 glow bird. It will fly it, but thats about it. I hope I am wrong, but I am planning on making this a 50cc bird that it seems like it is.... Keith
    AMA # 403098
  16. #166
    Join Date
    Jan 2007
    Urbana, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This is the first big build for me... the Saito LOOKS big and the MAN article certainly showed flight and general test/aerobatic satisfaction with the OS200...think the Saito is ~.4HP smaller.....we'll see, our club has it's giant scale fly-in late this month..hope to put this bird in the air mid-next week. I'll post here.
  17. #167
    Join Date
    Oct 2002
    Chapel Hill, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good luck, she's gonna be very underpowered.
    AMA # 403098
  18. #168
    Join Date
    May 2005
    Smithfield, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have zero experience in this size model so any advice is welcomed. I just received the SD from RC guys and I'm considering engines.
    You're recommending a gas 50cc based on wing loading. Although not built yet the box says 13-15 lbs flying weight( if accurate). Does 50cc seem to fit in this range as a good choice? Plan to recover it eventually to match my full scale paint! Cant wait to see them side by side!
    Thanks in advance.
  19. #169
    Join Date
    Oct 2002
    Chapel Hill, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am not trying to sell you on any particular motor, but here you go.
    I have an SD Models Extra 260 airplane. I built it light, but not trying too hard to cut weight. With a Canister Muffler (longer and quiet pipe) and a 16 oz gas tank etc, she weighs right at 17 lbs. I could have gone with a shortie muffler and carbon fiber landing gear etc, and been at 15.5-16 lbs. It has an 87" wingspan and has 1290 sq inches of wing area. Their next size up, which would be a 33% Extra 260 weighs 20 lbs, and has a wingspan of 95" and an area of 1612 sq inches. This should kind of give you an idea of what size plane/motors the gas guys are using. Granted, a 50cc in the 30% mentioned above would be overkill, nothing says you have to use it! The 33% mentioned above would fly with an 80-85cc gas motor.
    A DA-50R 50cc gas motor would weigh in at at 3.40 lbs with ignition. These are the best little motors ever in my opinion.$599
    A Saito 2.20 (bare minimum for this plane in my eyes) would weigh in at around 2.8 lbs with muffler and mount,etc. =$499
    The gas motor will have a greater resell if you decide later to sell it. DA's barely even drop in value over new. email me if you have any questions. Keith
    dart373@aol.com
    AMA # 403098
  20. #170
    Join Date
    Oct 2002
    Chapel Hill, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This is the same price as a new Saito 2.20, and it comes with a prop too. Just trying to stir the pot a little guys. Not saying pro this or pro that..
    Do a search on some of the other sites for a used DA 50R.
    AMA # 403098
  21. #171
    mrbigg's Avatar
    Join Date
    Oct 2004
    Streator, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Dart373
    Exactly.
  22. #172
    Join Date
    Jan 2006
    Lexington, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm using an OS 1.60fx in mine. Should be plenty -- 3.7hp -- for what I want it to do. Hope so, anyway....
    I am a bit concerned that I'll have to add some nose weight. Lot of stuff back there in the tail area, servos, flying wires, triangle stock reinforcemen, and I'm figuring the OS aluminum mount, engine and muffler at around 42-45 oz.
    We'll see how it goes.
    Looking forward to some flight reports on here.
    Al
    MobyAl
  23. #173
    Join Date
    Oct 2002
    Chapel Hill, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mobyal
    Al
    Really? I think a lot of scale flyers are not reading the book, but just the cover. RCGUYS have done their homework and this seems like the best Decath made yet for modelers. It has the sq inches and the wingspan/weight of a 33% airplane guys. A 1.60 will fly it , but think about it. Theory says that an 80cc motor should fly this plane in the 3D world. In scale world, a Zenoah 26? In reality, a 45-50 cc motor. I am so proud of the guys at RC Guys for making a way cool plane first off. However, look at their specs.... A .90 2 stroke to a 40cc gasser. Folks, wake up a little, that is 14.912 cc's of glow 2 stroke to 40 cc's of 2 stroke gas. Do the math. I am not trying to be a jerk, I just want to make it clear to folks out there as to how big this plane really is! Happy trails and great luck guys. It will be a fantastic plane.
    AMA # 403098
  24. #174
    mrbigg's Avatar
    Join Date
    Oct 2004
    Streator, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Dart373
    ORIGINAL: mobyal
    Al
    I know a guy that had the 1.60 in the Hangar 9 Taylorcraft. Flew that plane excellent. About the size of the plane, I'm right with you. Look at the pics in MAN when they are assembling the wings on the bench. That thing has a huge chord.
  25. #175
    Join Date
    Oct 2002
    Chapel Hill, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Seriously, don't be overtaken by this plane. It is a 1/4 scale Aerobat! It needs some motor, not to mention servo size can't be Futaba 3004's
    AMA # 403098
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
