Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Air Tractor 502 build
Reply
Old 11-10-2007, 03:23 PM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Air Tractor 502 build
Hi all,
Coming week I recieve my kit from Schneider Modell, it is an Air tractor 502 1:5.
Spanw. 3,25 M.
Length 2,10 M.
Engine ZG74 with 2 in 1 reso.
Total weight aprox. 12 KG.
I will place some pictures here of the building.
The engine sticks both of the cylinders through the cowl but i think that looks okee.
I hope I get with the use of a reso a RPM of 6800 with a 24x10.
Regards,
Cesar.
ID:	800769   Click image for larger version
redcesar is offline
Old 11-11-2007, 11:10 PM
outacontrol41
outacontrol41's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Air Tractor 502 build
here's a an Air Tractor 802.....h-h-huuuge!!! The size of commuter jet![8D]
outacontrol41 is offline
Old 11-14-2007, 05:57 AM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have made a two in one headerpipe for connecting my reso to then engine.
Have somebody experience with this kind of setup? In comparison with the use of two reso exhausts or cannisters.
Regards,
Cesar.
redcesar is offline
Old 11-17-2007, 04:40 PM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Today I have done some testing with the ZG74 on a test stand and with the use of a reso pipe I get 7200 rpm with a Menz-S 24x8.
I think I can get 6700 with the use of a 24x10 Menz-S. If I have the prop I let you now.
Regards,
Cesar
ID:	805841   Click image for larger version
redcesar is offline
Old 11-19-2007, 11:15 AM
Pelle Gris
Pelle Gris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My GT 80 does 6800 with a Menz S on standard exhausts, so once set up properly you should be able to get a bit more power from your tuned pipe setup.
Pelle Gris is offline
Old 11-19-2007, 01:41 PM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Pelle Gris
I let you no when I have the 24x10 prop, but maybe is the GT80 a lot more powerful as the GT74.
I dont no the factory specification of both engines, Maybe you?
Regards,
Cesar
redcesar is offline
Old 11-19-2007, 04:03 PM
Pelle Gris
Pelle Gris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
According to Toni Clark, the german importer of the Zenoah line, and might I add very experienced with these engines, states that the only difference between the 74 and 80 is around 1-200 rpm. A friend of mine runs his GT 80 on a single pipe, recording these numbers:
Engel Super Silence 22x12 3-blade prop: 7000rpm
Mejzlik 22x12 3-blade prop: 6700rpm
Both of these props provides a very silent and powerful combination. He uses the engine for aerotowing gliders up to 7 meters, weighing up to around 16kg.
Go to www.toni-clark.com and download his catalogue. Lots of nice products, and a lot of info for the Zenoah user.
Old 11-21-2007, 04:26 AM
Alexzzz
Alexzzz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi there, I'll follow this build for sure
Greetz.
Alexzzz is offline
Old 11-23-2007, 04:53 PM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Today I recieved the kit from Schneider so this weekend I am going to start with the build.
It al looks fine with a good quality wood and the parts are nice cut out.
Regards,
Ruud.
ID:	810109   Click image for larger version
ID:	810110   Click image for larger version
ID:	810111   Click image for larger version
redcesar is offline
Old 11-24-2007, 12:41 AM
Alexzzz
Alexzzz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, and it is going to be a very nice and long building-weekend here in Holland
Greetz.
Alexzzz is offline
Old 11-24-2007, 01:00 AM
BigBoy99
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ruud,
that looks like a lot of work, this kit. Nice Plane, you choosed [sm=thumbup.gif]
Does this 2cyl. engine fits under the long tall nose?
Bernie
BigBoy99 is offline
Old 11-24-2007, 05:39 AM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes indeed Alex, at the moment there is no flying weather in the Netherlands.
Hi Bernie, at first look it seems a lot of work but everything is wel cut out and the parts fit together with "locks" in German "alle Teile passen sehr gut durch Verzapfung".
For example, for building the wing you need no drawings, the place for the ribs are fixed, in the cut out, main spar. The only thing you have to care about are the right angles.
For now I am going to the field testing the engine again, The engine was in first place for some reason, make it smaller I think, converted to the smal CM-6 spark plugs but I have read somewere that the engine runs better with the standaard RCJ7Y plugs.
And no, the engine fits not under the cowl but with the both cilinders sticking out, can be a nice look. Maybe I spray both cil. with heat resistant paint in red or so.
For this airplane I do not to much on scale matters, I hope I can build it in a not so long time.
Regards,
Ruud.
redcesar is offline
Old 11-24-2007, 06:06 AM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the info Tinus, Today Iam going to do some testing again with other plugs etc.
Regards,
Ruud.
redcesar is offline
Old 11-27-2007, 05:57 PM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I started with the wing main spar end the first ribs. The mainspar is build up from spruce and plywood to get a box.
The wingtubes are precisely lined out for the right angle of the wings.
After that the ribs are glued to the box.
Regards,
Cesar.
ID:	813559   Click image for larger version
ID:	813560   Click image for larger version
ID:	813561   Click image for larger version
ID:	813562   Click image for larger version
ID:	813563   Click image for larger version
ID:	813564   Click image for larger version
ID:	813565   Click image for larger version
redcesar is offline
Old 11-27-2007, 07:09 PM
outacontrol41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You're off to a good start....nice build pics. But...what are all the heavy-looking (aliminum?) blocks used for? Just curious.
Hope the wing tube stays held in place in the spar with that epoxy!
Old 11-28-2007, 12:46 AM
Alexzzz
Alexzzz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, that is definitely strong enough
Keep up the good work!
Greetz.
Alexzzz is offline
Old 11-28-2007, 02:25 PM
BigBoy99
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: outacontrol41
What a question, they shell make the plane heavy.........heavy=fast
@redcesar
Ruud, thats an interesting building mode, I never saw. It looks good and easy.
But beware, thereĀ“s quick built in a torque in the wing.
Regards
Bernie
BigBoy99 is offline
Old 11-28-2007, 03:25 PM
Jonathan Ott
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like he is just using them as weights to hold parts down as glue cures.
Jon
Jonathan Ott is offline
Old 11-28-2007, 05:31 PM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all,
Yes, the heavy-looking steel blocks are weights.
Bernie:
That is a good comment Bernie, when the wings are covered with balsa sheets the building manual says to be aware of torque.
So I'll I be on the alert for torque in the wing.
Regards,
Ruud.
redcesar is offline
Old 11-28-2007, 11:32 PM
GPutt33
GPutt33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
redcesar - This is going to be great a build I did the 802 with the slurry bay (about 2 cups of baby powder per drop). Always a crowd pleaser and one the other guys like to come up and discuss. Good luck !!
GPutt33 is offline
Old 11-29-2007, 01:18 AM
outacontrol41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Weights! Of coarse! I knew it all along...[:-] I was just testing you.
Old 12-07-2007, 05:28 PM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am now busy with the building of the ailerons and flaps.
Regards,
Ruud.
ID:	820525   Click image for larger version
ID:	820526   Click image for larger version
ID:	820527   Click image for larger version
ID:	820528   Click image for larger version
redcesar is offline
Old 12-12-2007, 03:40 PM
BigBoy99
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Ruud,
the kit makes a good impression, all lookĀ“s very professional.
Good work, give us mor pics here!!
ThatĀ“s what I miss here in the RCU forum, more pics!
Bernie
BigBoy99 is offline
Old 12-14-2007, 02:51 PM
redcesar
redcesar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This week I did some work on the wings with the allerons and air-brakes, after I finished the inspection hatches for the servo's I go scheeting the upside of the wing.
After that I started with the fuse.
Regards,
Ruud.
ID:	825543   Click image for larger version
ID:	825544   Click image for larger version
ID:	825545   Click image for larger version
ID:	825546   Click image for larger version
ID:	825547   Click image for larger version
ID:	825548   Click image for larger version
redcesar is offline
Old 12-16-2007, 02:25 PM
BigBoy99
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ruud,
your methode to planking the wing, is the same like mine. First glue on at the leading edge, than make it wet and glue the rest...........good[sm=thumbup.gif]
The pic with the servo is the pic of the flaps, or not? Because they are hinged at the outside of the wings.
Looks all very good, very professional!!!!!!!!! I like yor work.
Bernie
BigBoy99 is offline
Reply
Display Modes
