Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
TMMY Scale Composites 35% scale Cessna
Reply
Old 05-18-2012, 07:03 AM
  #1526
mifsudm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: TMMY Scale Composites 35% scale Cessna
Yes style fly,
I finished up adding about 2kg of weight due to some inner structure reinforcing at the back of the fuse also because i did re-paint my Cessna (the original paint wasn't up to my standard) being my self by profession a vehicle spray painter.
didn't you check your CG before flight?? it is suppose to be @ approx 175mm to 180mm back of the leading edge. i made a home made cg checker my self.
regards
Martin. [img][/img]
ID:	1763703   Click image for larger version
ID:	1763704   Click image for larger version
ID:	1763705   Click image for larger version
mifsudm is offline
Old 05-18-2012, 07:35 AM
  #1527
style fly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Mifsudm , great CG stand Yes I did check the CG and it lifted fine (when It rose up it did not tilt) but the test pilot suggested it could use a bit more nose weight... I too added re-enforcement to the fuse interior as well as repainted the empennage- so it became more tail heavy
style fly is offline
Old 05-19-2012, 02:10 AM
  #1528
Parrot Girl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Martin, how did you strip all the paint off to repaint it? I am wondering if I should get mine unpainted and get an auto painter to do it.
Parrot Girl is offline
Old 05-20-2012, 12:41 PM
  #1529
TSHARK203
TSHARK203's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a quick pic post from Joe Nall I will post more later. 3 good flights and she is back at home not much worse for the wear.
ID:	1764239   Click image for larger version
TSHARK203 is offline
Old 05-20-2012, 06:50 PM
  #1530
cgcrc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All;
Just back in from a few days away and got caught up on the 182 thread.
First up, congratulations to stlye fly and George with your maiden flights, a great sense of accomplishment and of course always nice to get the maiden behind you.
George, great pics from “Nall”, I really wish I could have made it this year and joined you fellows with my 185 .
I’ll give you a call when you return home re the lighting system on your 182.
Strut Attachment Point
Re the wing lift strut attachment point at the fuse.
You are definitely correct it certainly needs something to secure it firmly in place. Either blind nut or threaded insert.
Did Tommy use a threaded insert?
The only mod I will be making to the 185 in this area are the struts themselves. I don’t know if you 182 folks have experienced the same problem but at low RPM the wing strut vibrates. Once the RPM is increased the transfer of vibration decreases.
I’m hoping the fix will be moving to an aluminum air foiled strut providing the weight is not that much.
Split Cowling
Re the cowling, it is certainly nice to have a split cowling or access to the upper portion of the engine compartment especially if you have engine baffling. Interesting with his modified cowling arrangement for the 182.
Painting the Model
Hi Parrot Girl, there are a lot of advantages receiving the model in primer gray as I found with my 185.
Just a thought, there were approx. 18 separate pieces in total with my model, not hard to paint but did require some set up on how to hold all the pieces.
If you go this route I can send you a number of pics on the methods I used.
Have fun with your 182’s, they all look great.
Best regards
Randy
cgcrc is offline
Old 05-21-2012, 02:59 AM
  #1531
style fly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Tshark , nice photos of you and your cessna Iwish I could have been there-, maybe next year- Did Scott from SKS video interview you????Here are some photo of me and Mario on Sunday at Floyd Bennet Field in Brooklyn N.Y. These are the First Photos on this forum thatI have seen with two TMMY Cessna together- lets see if we can get 3 in one photo.........
ID:	1764593   Click image for larger version
ID:	1764594   Click image for larger version
ID:	1764595   Click image for larger version
ID:	1764596   Click image for larger version
Old 05-21-2012, 03:10 AM
  #1532
spidernad
spidernad's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks great Sal. Good flying with you on saturday.
Maybe when I get mine done we can get three together!
spidernad is offline
Old 05-21-2012, 03:37 AM
  #1533
style fly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Dan , Yes i had a fun time flying on Sat with you- if the weather is good this weekend I would like to bring my cessna down and Mario with his as well
Old 05-22-2012, 02:40 AM
  #1534
style fly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok, by now im sure your sick of seeing photos of my cessna-(im not) LOL- I just wanted to post Mario and Iat the Brooklyn N.Y. airfield. A nice guy named John Dinkins (professional photographer) that was hanging around the club took these great photos- so Ihad to post them..........
ID:	1764991   Click image for larger version
ID:	1764992   Click image for larger version
Old 05-22-2012, 03:27 AM
  #1535
moteckracing1@bigpond.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys, just been looking at the nice pic's of your 35% Cessna's and notice that they all seem to sit way to low on the rear. Do you guys have trouble when landing as wouldn't you be almost scraping the rear on the ground to keep the nose wheel from striking first? I have this same issue with my 27% and have shortened the front srut to avoid this happening. I think on one of my other posts I mentioned the very unscale look of the wheel pants and wheels as the pant looks to deep and the wheels to large. See photo's of the fullsize that I sent Parrot girl. Has anybody taken that up with Tommy or do you guys think there is no issue. I see in talking with him that he is not only adding the split cowl but adding more rivet detail and more slope to the rear window.
Nice aircraft guys.
Kosty.
moteckracing1@bigpond.com is offline
Old 05-22-2012, 04:21 AM
  #1536
style fly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well with Mario's cessna his axels need to be changed- he has had many , many landings so they bent in some making the tail drop -and he has the thinner main gear that has bent out alittle- agian he has A-LOT of flights onhis cessna-He may hold the flight recored-(Tommy switch to a thicker metal since) on the Blue cessna it has one flight and as you see in the photos it has a higher stance with the tail higher off the ground- Now if you look at photos of real 182's and look at the nose gear and the sping arm and see it just touches the bottom of the cowl-I tried to match mine up just so- any higer and it would be in the cowl - so you only have so much to play with (unless you use a smaller nose wheel)-again look at a full scale 182 and it has some slight tail drop- Also Mario has not had any tail scrapes on landings........
Old 05-22-2012, 05:15 AM
  #1537
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah that's cool. Composite landing gear solves the problem. Have a look at my post #1515 for the correct stance of a unladen 182. I have many such photo's showing similar aircraft stance and the pant to wheel aspect. The only reason I've made the comment is I will ask Tommy to correct this when he makes my 35% aircraft as the 27% is closer to being correct.
Once again nice aircraft guys.
Kosty.
Old 05-22-2012, 05:24 AM
  #1538
style fly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
NICE - I like that Tommy keeps improving his kit with our suggestions- thats why this forum has so much activity- I will check your post - thank you
Old 05-22-2012, 03:58 PM
  #1539
spidernad
spidernad's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: style fly
Sorry, I forgot to reply.
That sounds cool!
I don't think the guys at my club would protest if I break the "one guest at a time" rule. lol
Especially if they see those two big Cessna's looking so fine!
Old 05-23-2012, 09:38 AM
  #1540
mifsudm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
very nice TShark.............. it seems all went good on you first flights, it encourages me more when i arrive to do mine. are there any tips you suggest before the test flight, or is it another fly on rails model?? i am using a DLE-170 engine i think it should be enough for it..........right?? the runway of our club isn't too long it's about 600 feet in length.
regards
Martin 9H1DL
mifsudm is offline
Old 05-25-2012, 12:25 AM
  #1541
TSHARK203
TSHARK203's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mifsudm
regards
Martin 9H1DL
Hey Martin
just fly her. It is going to fly let a big heavy trainer. Your runway is ampel. I just drag my takeoffs out tring to go for a scale look. The plane will come up quick if you want it to.
Old 05-26-2012, 03:15 AM
  #1542
Sergey Alekseev
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all! Tommy finished my model ... Tommy looks like? There are photos of him from whom?
Sincerely Sergei.
Sergey Alekseev is offline
Old 05-26-2012, 08:44 AM
  #1543
spidernad
spidernad's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Sergey Alekseev
Sincerely Sergei.
Hi Sergey,
You can see him in this Youtube video.
I think he is in the white shirt holding the radio @ 2:25min.
[youtube]http://www.youtube.com/watch?v=p-D99PULt68[/youtube]
Old 05-28-2012, 02:47 PM
  #1544
mario tavarez14
mario tavarez14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sal apice cessna 182 video http://youtu.be/-bcEGA5hXEo
mario tavarez14 is offline
Old 05-28-2012, 06:43 PM
  #1545
style fly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://youtu.be/RYfYoi-Oug8 this video has Mario and me flying toghter
  #1546
Sergey Alekseev
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
   Hello!   Great movie, thanks!
   What engine is installed in Cessna number N182SA?
   Good luck!
   Best regards, Sergey.
Old 05-28-2012, 07:24 PM
  #1547
spidernad
spidernad's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: style fly
this video has Mario and me flying toghter http://youtu.be/RYfYoi-Oug8
Looks great Sal.
If you put the the videoaddress in between these two youtube boxes [youtube][/youtube] ,it will put the video viewerin your post. You can edit your post to change it.
Dan
Old 05-28-2012, 07:48 PM
  #1548
style fly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its a Desert Aircraft 150cc (DA 150) glad you liked it
Old 05-28-2012, 07:53 PM
  #1549
style fly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 05-28-2012, 08:24 PM
  #1550
Sergey Alekseev
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for your answer!
What is the take-off weight for your Cessna?
Sergey.
Reply
Display Modes
