Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
GP Super Stearman with 50cc build
Reply
Old 05-12-2008, 10:48 PM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default GP Super Stearman with 50cc build
I am going to start a build thread on the Great Planes Super Stearman with a CRRC Pro GF50I ( 50cc gasser ).
First things first, YES I know it is over power.
I have the two sitting and figured I will match them together.
I DO NOT plan on sreaming this plane wide open down the runway. The only time I am going to do any wide open is going to be in the verticle postition.
Well I am going to shot my expected weight of 16 1/2 lbs. ( dry ) and we will see how close I will be when it all is together.
I also am installing a full smoke system in the aircraft.
This plane should look awsome doing stall turns and monster loops with full smoke on.
These are some weights as the are now.
Built fuselage ( no radio or tank ) has landing gear, wheels, wheel pants, tail whell assy, all surfaces, deck, windsheilds, pilots
73.5 oz.
Top wing, bottom wing with all mounting braces.
65.5 oz.
Cowling, spinner, fuel tank, hardware, quick filler, fuel line
19.0 oz.
Servos:
Four Futaba S3305
One Futaba S3004
Extensions and switches
One 6V 2000 mah battery
Futaba FASST RX
Opto kill switch
11.5 oz.
Full smoker sysytem:
Sullivan Skywriter
20 oz smoke tank
6V 2000 mah battery
switch harness
15.5 oz.
CRRC Pro GF50I
Ignition, muffler, switch harness and ignition battery
62.5 oz
Prop, custom stand offs and mounting bolts
8 oz.
I will do pictures as I go along and do some numbers as I break in the engine.
2robinhood is offline
Old 05-12-2008, 10:50 PM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GP Super Stearman 50cc build
Here are some pictures of the mount I am making to hold my smokers assy.
Old 05-12-2008, 11:01 PM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Engine is a CRRC Pro GF50I
I purchased the Pitts muffler and am going to use it on this project.
Specs:
Displacement: 50cc
Bore x Stroke: 43mm x 34mm
Dry Weight: 1660g (3.63 lbs.)
Carburetor: Walbro butterfly type w/pump
Max Output: 4.9 HP @ 7500 rpm
Ignition: 4.8v Auto Timing Ignition
Fuel: 93 plus octane premixed 40:1
Propeller: 20 X 10 , 22 x 10 ,22 x 8
Old 05-13-2008, 09:57 AM
Nathan King
Nathan King's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GP Super Stearman with 50cc build
It looks good. I know this model requires ballast up front, but won't that 50cc be a little bit too much weight up there (requiring tail weight)?
Nathan King is offline
Old 05-13-2008, 06:44 PM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Nathan King
I plan on mounting my smoker assemely and batteries towards the tail. I think I should be OK by adjusting my extra items around without adding weight.
The GP Stearman needs 18 oz. of added weight to the nose to ballance with a OS 1.20 four stroke.
OS 1.20 + 18 oz of lead = 51.5 oz.
CRRC 50cc with muffler and ignition = 58.5 oz.
I think I can overcome the extra 7 oz. being on such a short segment in front of the CG.
Old 05-13-2008, 10:47 PM
Nathan King
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool. It sounds like you've planned things out well. I can't wait to see it finished!
Old 05-14-2008, 12:13 AM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a fast update.
I am using Robart pin hinges instead of the CA hinges.
Ailerons are the 3/16" pin hinges, while elevator and rudder is 1/8" pin hinges.
Fuel tank set up, of coarse a gasoline stopper, walbro felt filter/clunk, and Aerotrend easy flex gasoline fuel line.
Old 05-14-2008, 10:49 PM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pretty much got the smoker assembly finished.
Unit is assemled, mounting rails are in fuse.
Just need to mount the switch and fuel dot for the smoke tank.
I used velcro between tank and mounting plates, between smoke pump and tank, between battery and tank.
Then used zip ties to secure everything.
Assembly as you see it with a switch harness is 16.3 oz.
Old 05-17-2008, 02:18 PM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just took my CRRC Pro GF50I ( 50cc ) out of the box.
After 8 oz. of fuel run, needles at factory settings, I did some quick 5 second burst of wide open for some rpm numbers.
Xoar 19 X 8 @ 8200
Xoar 20 X 8 @ 7500
Zinger Pro 22 X 8 @ 6900
APC 22 X 10 @ 6700
JFX 23 X 8 @ 5600
Old 05-17-2008, 05:38 PM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New numbers for the CRRC 50cc:
After 16 oz of fuel run.
Xoar 19 X 8 @ 8400
Xoar 20 X 8 @ 7900
Zinger Pro 22 X 8 @ 7100
APC 22 X 10 @ 6900
After 24 oz of fuel.
Zinger Pro 22 X 8 @ 7200
Vess 22B @ 6800
Majzlik 22 X 10 @ 6800
Old 05-17-2008, 06:39 PM
Nathan King
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Those numbers look really good to me! [8D]
Old 05-21-2008, 12:14 AM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Update:
A little further, engine is mounted, wings are on, and control surfaces are glued.
Next will be plumbing smoke lines and control linkages.
Old 06-01-2008, 10:41 PM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got a little more done.
Mounted servos and Opto kill switch.
Each elevator half has it's own servo, instead of connecting two pushrods together.
Hardest part was getting the throttle linkage past the smoke system and having it get the throttle to stick position correct.
I put the wings on for a quick balance check.
No RX battery or ignition battery in in yet, and it balanced perfectly to the manuals CG.
I should be ok, and able to adjust batteries around and not ad any weight to the plane.
Old 06-18-2008, 08:56 PM
2robinhood
2robinhood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm still alive.
Just been trying to get my 33% in the air.
I'll keep you posted.
Old 06-23-2008, 12:20 AM
nitro wing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This just looks like it will be a disapointing disaster.Thats just my thought on this.But its almost done,might as well finish it.
Just my opinion,and easily ignored
nitro wing is offline
Old 08-05-2008, 11:01 PM
sskianpour
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DA-50 is what I had in mind since I have an extra one sitting on the shelf. My only concern is prop-clearance (I live in Colorado and am not too worried about over powering). 2Robinhood, I can't tell by your photos, but what size Mejlik prop do you have mounted, and how does your clearance look to the ground (at least 2-3 inches?)
Shaz
sskianpour is offline
Old 08-05-2008, 11:02 PM
sskianpour
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
woops, just noticed you have a 22X10, thats GREAT! How's clearance?[sm=thumbs_up.gif] or [sm=thumbs_down.gif]???
Old 09-26-2009, 02:13 PM
Shubova
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I'm not sure if you’re going to use 2 or 4 servos in the wings. There seems to be a lot of debate about the subject. I guess it comes down to personal preference. I'm using 4 servos and it flies great.
A word of caution if you don’t already know it…When you assemble the wings and horizontal stab make sure they are at”0” degree incidence to each other before gluing and screwing. You may have to force the top wing to the ”0” position before screwing the bracket down but if you don’t your going to have a lot of problems with it. I know I didn’t realize it was going to be off and I ended up making and installing wood shims to bring the top wing to”0”.
Another thing…RCU changed their format for the forum [sm=confused.gif]and there is a long forum that goes back a few years, can anyone point me in its direction.
I posted some instructions and pictures on how I assembled the Y connect in the wing before I put them together which leaves you with only one connector to plug in. I read it in the long Stearman forum I’m looking for, it works great.
There again I can't find it, so I can’t tell you were to got to see it.
Anyway Thanks and Happy Landings!
Shubova
[8D]
Shubova is offline
Old 01-01-2015, 09:10 PM
SebastianRC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow I got a 42cc Quadra engine for my Stearman.. what prop do you think guys I need to use?
SebastianRC is offline
Contact Us Archive Advertising Cookie Policy
